Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree2Likes
Old 10-04-2012, 07:05 AM   #9976
defcone's Avatar
Trader Rating: 15 (100%+)
Originally Posted by tcdrvr2 View Post
So I've been running offroad for a while with the v3 and I like the feel, but I'm thinking of getting back into Touring car again and I've been wondering how the V3 stacks up against the competition in 17.5 spec mode. I ran an RS last year and it was too much of an on/off feel to be smooth, however I've been told the V3 can't keep up with RS. Anyone have experience with this?
What? Blinky speedies have different performance?
defcone is offline   Reply With Quote
Old 10-04-2012, 07:31 AM   #9977
Trader Rating: 88 (100%+)
I thought they were all supposed to be equal with the differences being in throttle curves and brake feel but from what I'm hearing the local racers are saying that they've tried HW's, Orion's, LRP's etc. and the tekin outperforms them all. Hence my question. I'd rather the smoother feel as I would think it would yield better laptimes than the on off switch feel of the Tekin.
Shane W.
Everything for Sale - out of hobby
tcdrvr2 is offline   Reply With Quote
Old 10-04-2012, 08:52 AM   #9978
Super Moderator
Marcos.J's Avatar
Trader Rating: 150 (100%+)
probably because the tekin has a little dynamic timing in the software , unless there is a way for each esc to be check we will never know if their software absolutely has no timing thats why for blinky class everyone should be with the same esc and motor
Old 10-04-2012, 09:04 AM   #9979
2wdrive's Avatar
At my club they tested the hobbywing justock with the SP cirtix and there was no difference except the Justock felt a lot smoother. I would highly doubt the tekin will be faster as there has been nothing about it being faster in straight line speed so far. They have a blinky profile and is in agreement with the "blinky"rule.
I call it bs.
www.rc-lemans.de
2wdrive is offline   Reply With Quote
Old 10-04-2012, 01:04 PM   #9980
Trader Rating: 58 (100%+)
BLANK>>> I figured out my problem. Shheesh
MC112b is offline   Reply With Quote
Old 10-04-2012, 09:28 PM   #9981
COBRARACING's Avatar
we are working on the brakes issue with the blinky software
should be available next week
regards Angelo
Email : teamcobraracing@gmail.com or ae@hobbywing.com
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Old 10-04-2012, 11:55 PM   #9982
Dan
Dan's Avatar
Trader Rating: 43 (100%+)
In the meantime, will upgrading to 508 firmware solve the sensor issues on my Justock? Just want to know since I don't have the programming box but I may give it a shot.
Dan is offline   Reply With Quote
Old 10-05-2012, 05:45 AM   #9983
We have done dyno testing on various esc's and our weapon of choice for 1s is the Hobbywing. Free reving (timing check) there is little difference. Load testing is where the differences show up. This can be tested using a TurboDyno and a standardized motor. Smoothness is a feel item and can only be done by the seat of the pants to the average individual.
www.norcarracing.com
NORCAR @ The Gate
old_dude is offline   Reply With Quote
Old 10-05-2012, 09:06 AM   #9984
Trader Rating: 45 (100%+)
Send a message via AIM to RicerX1
regards Angelo
Nice. Hopefully the update will my make justock and xtreme brake as hard as my v3
RicerX1 is offline   Reply With Quote
Old 10-05-2012, 03:53 PM   #9985
The sensor port had been fixed with the 508 zero timing v3 version a very long time ago which was to sensitive with some motors like the lrp etc .now you might want to have a look at your motor and the sensor board in that motor you might have some damaged hall sensors even one can cause an issue as it will send back a distorted signal back to the esc .
Old 10-05-2012, 05:58 PM   #9986
narcotiks's Avatar
anyone tried turbo start by full throttle and rpm on the V3?
i felt it was more responsive in the infield and had a better feel when kicking in on the straight
narcotiks is offline   Reply With Quote
Old 10-06-2012, 06:22 PM   #9987
Trader Rating: 82 (100%+)
I just picked up a Hobbywing SCT Pro to put in my SCTE and I can't seem to use the computer or programming card on it at all. I do own 2 other Xerun 120amps, an Orion R10 pro, and even a LT4.... they all work with the programming card + computer at least.
Here's what I've tried (all with a fully charged battery).
Programming Box, RX connector to programming card
Programming Box, RX connector to programming card + computer
Programming Box, sensor connector to programming card
Programming Box, sensor connector to programming card + computer
LT4 USB cable with both connections
Mainly, I really want to set my punch level to 1 for my Tekin 4600.
"Tinkering with Toy Cars that go around in circles"
OCRC | Club R/C | Mike's Gulf Coast | Kyosho RB6 ZX6 MP9E
Kuya_Kimo is offline   Reply With Quote
Old 10-06-2012, 07:05 PM   #9988
TCCustoms's Avatar
thats your problem....you need to unplug the fan and plug into the fan port for the programming card, NOT the RX connector OR sensor wiring(which wouldnt fit anyways)
1/10 Traxxas Summit Blue
Axial AX10 Scorpion * Viper VSC 240/55t combo * Hitec HS-7954SH
TCCustoms is offline   Reply With Quote
Old 10-06-2012, 08:28 PM   #9989
Dan
Dan's Avatar
Thanks Angelo. I upgraded to V3 508 firmware and it is still kicking it into sensorless mode. I did run my car today and I was very impressed with the ESC. Much improved over my Cirtix in terms of brake strength/response. Everywhere else, it is fine once the car is moving. But in the main and a standing start, this will be trouble. Plus I think the car is faster in sensorless mode than sensored?? Is this true or no?
I'm going to try a different brand motor and see if maybe it is just isolated to the Speed Passion V3 Ultra Sportsman motor. I have read of past issues that some people have had this problem, but some haven't. Urgh...
Old 10-06-2012, 10:28 PM   #9990
Thanks Travis! Who would think the instructions could tell you how to do it too?
"You must use the 3 pin port between the soldering terminal #A and #B. Normally, this 3 pin port is used to connect cooling fan, when programming the ESC, please unplug the cooling fan connector. Please also make sure that the 3 pin program port of the ESC must be connected with the Program Box through the port marked with “ ” in parallel, the cross connection is not correct"
