Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 09-25-2012, 09:36 PM   #9946
COBRARACING's Avatar
Originally Posted by syndr0me View Post
Hacker? Is that a clone?
looks like an oem of a orion speed controller .I cant see it being a clone no maybe orion has ordered the esc for hacker .
Email : teamcobraracing@gmail.com or ae@hobbywing.com
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Old 09-25-2012, 09:42 PM   #9947
Trader Rating: 39 (100%+)
Send a message via AIM to Prostreet314
Yeah that is a rebadged r10pro...
"We race toy cars, act accordingly..."
ORIGINAL MEMBER OF TEAM TUCK NASTY RACING
We are proudly Sponsored by:
COW RC, TEKNO RC, DE RACING, PHATDAD RC, T-BONE RACING, TEAM RADIOPOST, MONSTER ENERGY DRINKS
Prostreet314 is offline   Reply With Quote
Old 09-26-2012, 04:22 AM   #9948
Originally Posted by M.Abramowicz View Post
Hi!
I have 2.1 speedo, latest stock software.
How to set it like 'modified' soft for 5.5T?
I do not need turbo on my car now but also do not want each race flashing ...
ping ?
or it is not possible and better is put modified?
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 09-27-2012, 10:40 AM   #9949
Moderator
Clegg's Avatar
Hey guys,
I have a hobbywing Justock I picked up to replace a Tekin I had go out for my 17.5 blinky 1/12th I am running at IIC. I figured the Justock was small and light and since I am running Blinky why not.
I am potentially having some issues with the ESC in the car though. As in its way off pace. I also noticed that the booster gets quite hot in the car with the Justock. What is the proper way to setup the ESC/Booster in the car for 1S running?
The booster is essentially a TQ booster, using the one wire connection to the Pos terminal on the ESC with a switch to turn the booster on and off. I have been running with the ESC powered on and the booster powered on. No LiPo cutoff set on the ESC.
Do I need to pull the red wire from the ESC to the RX like some require?
Any help here would be great.
Joe Kelly - JK720.net
5280 Raceway |5280raceway.com | 5280 Raceway Facebook
Clegg is offline   Reply With Quote
Old 09-27-2012, 11:10 AM   #9950
jeff jenkins's Avatar
Trader Rating: 74 (100%+)
Need a setup for my 1s with a lrp x12 4.5 t on a large carpet track that is tight and technical. Where do I go to find a setup sheet ???? I'm running 1/12.
Serpent project 4x
jeff jenkins is offline   Reply With Quote
Old 09-27-2012, 03:29 PM   #9951
hi was wanding what setup ppl are using in 13.5t boosted
if you could let me know
settings
motor
fdr
thanks
tcboy1983 is offline   Reply With Quote
Old 09-27-2012, 05:01 PM   #9952
narcotiks's Avatar
What voltage does the program card port on the V3 put out?
narcotiks is offline   Reply With Quote
Old 09-27-2012, 07:21 PM   #9953
Originally Posted by Clegg View Post
Hey guys,
yes you need to remove the red wire for it to fucntion properly
Old 09-27-2012, 07:28 PM   #9954
Hi Jeff, can you share with me if you found some setup sheet ?
I am using Duo3.5 4.5T, timing set to 0. roll out is 41~44, no turbo, boost set to 5, drag brake to 15. I am using 930_mod firmware.
ongbenghui is offline   Reply With Quote
Old 09-27-2012, 07:36 PM   #9955
i have not found any setups yet they are nowhere to be found on the net
Serpent project 4x
Old 09-29-2012, 01:51 AM   #9956
I have:
Xerun 2.1
LRP X12 Vector brushless modified 6.5
Pan car 1:10
1.- I use this firmware:
V3.0_110930_MOD (don't have boost options!?)
Or better new one or older?
2.- I read: adjustable timing (LRP X12) is to set-up the motor to different speed controllers. Recommended for Xerun? (Default Timming -10)
3.- Recommended setup? (straight 60m)
THANKS and regards
TyoBBS is offline   Reply With Quote
Old 09-29-2012, 01:51 AM   #9957
EDIT:Sorry, delete
Old 09-29-2012, 06:25 AM   #9958
TryHard's Avatar
ping ?
I would put the 930 stock on, and just be careful about what settings you run. That way, when you go to a boosted stock class, just need to alter the settings.
On the 2.1, you will need to change the software if you have to run in blinky mode though.
HiH
Ed
Old 10-01-2012, 01:17 PM   #9959
hi, there is the possibility to have a new firmware for xerun 2.1 similar v3 firmware?
puma303 is offline   Reply With Quote
Old 10-01-2012, 01:27 PM   #9960
Barry_Hughes's Avatar
how do you mean similar?
the circuitry in each is totally different - The 2.1 does not have the capabilty of running a larger program like the V3.
Built it !
Raced it !
Wrecked it !
Barry_Hughes is offline   Reply With Quote
