Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree2Likes
Old 09-23-2012, 09:03 PM   #9916
Wildcat1971's Avatar
Trader Rating: 79 (100%+)
you should feel honored that your line of esc's is the most duplicated on the market. No one duplicated the LRP or Tekins.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 09-24-2012, 04:12 AM   #9917
Send a message via ICQ to vitomon Send a message via Skype™ to vitomon
Default help wanted
i recently came accross a problem with the speedo. seems like it goes into sensorless mode right from the start. there is no boost and turbo applied even though i have it set to 15deg each. used to work like a charm. but since the last race it stutters when starting from standstill and there absolutely now power. the 4.5T thunderpower geared 8.0 feels like a 10.5T machine suddenly.
i changed motor (tp 4.5t new out of the box) and sensor cable twice. so i think there is something wrong with sensorports or the esc itself. checke both motors on motortester and sensors on motor are working.
has anybody had the same problem and maybe a solution? otherwise i have to send it in for repair which takes week i guess.
Yokomo BD7 -- Hobbywing v3 -- Sanwa M11x
May the grip be with you ... always!
vitomon is offline   Reply With Quote
Old 09-24-2012, 05:29 AM   #9918
CFR
CFR's Avatar
Originally Posted by chris_dono View Post
Connect the Speedo to a 2S Lipo and remove the low voltage cutoff, then you can bind to your transmitter using a 1S cell. The LVC stops you from binding as it's expecting 6v minimum as standard (auto, 2S Lipo)
Any issues, please let us know.
Tried that. The esc switch's on but the red LED won't flash to set to transmitter Am I missing something?
CFR is offline   Reply With Quote
Old 09-24-2012, 06:26 AM   #9919
bkspeedo's Avatar
For the Non-v3 ESC's there was a known problem with the firmware if you have not upgraded to the latest. The sensor signal range was to narrow and if the signal came back from the motor out of this range it would fall into sensor-less mode. So if you have not upgrade firmware since you bought the ESC try that. Otherwise your sensor board is probably bad.
Brent Klingforth
Sponsors: Awesomatix USA ~ Roche USA ~ ORCA ~ AVID Bearings ~ R1 Wurks
TQ Wire ~ ProtoForm ~ BSR Racing Tires ~ 2mm Design
5280raceway.com [Operated by - Colorado On-Road RC Club]
MILE HIGH INDOOR CHAMPS April 20-23rd 2017 @ www.milehighindoorchamps.com
bkspeedo is offline   Reply With Quote
Old 09-24-2012, 07:37 AM   #9920
Fjeld's Avatar
Originally Posted by COBRARACING View Post
Oskar
I do have a setup for a 4.5T and 5.5T for a 2.0 esc you just have to work from there .
send me an email at teamcobraracing@gmail.com and i will forward both setups to you .
Thank you Email sendt
|| Yokomo BD7 2015 || XRAY T4'15 ||
|| Muchmore Fleta POWER :D ||
Fjeld is offline   Reply With Quote
Old 09-24-2012, 07:43 AM   #9921
it is a v3. whats the latest software for the v3 anyhow?
Old 09-24-2012, 09:44 AM   #9922
Thanks TCCustoms for linking up Angelo with me. Angelo I sent you an email this morning and just need the details for Paypal to wrap this issue up. Thanks.
Vince
TeamC TC02
Retired: Tamiya M04M, F103, F103GT, F201, TA02SW
element6 is offline   Reply With Quote
Old 09-24-2012, 11:01 AM   #9923
Anyone using the xerun 2.1 60a or 120a with the Castle 1406 Series of motor? How bad does it cog? Also, looking at the
http://www.falconsekido.com/products...6-4p-sct-motor
Old 09-24-2012, 01:50 PM   #9924
Are you holding the setup button down when you switch it on ?
CPD Racing
chris_dono is offline   Reply With Quote
Old 09-24-2012, 06:08 PM   #9925
COBRARACING's Avatar
when you plug your esc into your pc can you upgrade or change software does the pc usb link coomunicate with your esc?
Email : teamcobraracing@gmail.com or ae@hobbywing.com
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Old 09-25-2012, 01:59 AM   #9926
FunkyDunky's Avatar
Hi All,
FunkyDunky is offline   Reply With Quote
Old 09-25-2012, 02:11 AM   #9927
FunkyDunky's Avatar
Hi All,
Just wanted to see if it is just me or whether others feel the same but I have been trying to get the V3 working on a 21.5 motor in TC and no matter what I try I cannot get it to go as fast as my 120amp 2.1? I know the V3 is mega smooth and I am wondering if the smoothness of the software is actually a hinderence in higher wind motors?
I love my V3 and was planning on running in the winter here in the UK but just can't get it aggressive enough without generating too much heat.
Cheers
Old 09-25-2012, 02:44 AM   #9928
Do you have any more info?
Can you tell us the size of the track? Which club you run at?
Also can you post a speedo setup sheet?
Personally I don't run 21.5, but I do have a rough idea where I'd start.
cyclonetog is offline   Reply With Quote
Old 09-25-2012, 02:45 AM   #9929
gastekk's Avatar
Hi all im having a problem with calibrating my gt3b after changing my filmware 930 ...when i do the prossesing nothing flash!i have v2.1 120a did i miss something?it working just fine with preview set up but i hear it must be recalibrated...please help...by the way i have it allmost a year and im very proud of it!
gastekk is offline   Reply With Quote
Old 09-25-2012, 02:49 AM   #9930
Originally Posted by FunkyDunky View Post
Hi All,
Cheers
Hey Duncan, send me an email admin@cpdracing.co.uk
Cheers
Chris
CPD Racing
