Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree5Likes
Old 09-06-2012, 02:25 AM   #9811
COBRARACING's Avatar
Hi Guys
Just some info as you guys are aware that we at Hobbywing produce nearly 60% of the worlds racing brands as in orion,Hpi,yokomo,Sp Gt series etc etc .
I will help you guys with the tech support on all the brands that are oems but i cannot do anything for you when it comes to warranty that must be handled by the brand and company example hpi or orion etc .
thanks for your time
Angelo
Email : teamcobraracing@gmail.com or ae@hobbywing.com
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Old 09-06-2012, 02:26 AM   #9812
Originally Posted by Aoh View Post
has a fix been released for the tekin pro4 motors dropping out of sensor mode?
talking about the sct pro esc etc ?
Old 09-06-2012, 03:45 AM   #9813
Originally Posted by puma303 View Post
Hello to all
boys finally today I bought my first 1/10 (HB TCX) and the XERUN 120a 2.1, I wanted to ask for help: what firmware you advise me to install and which setup how can I start?
thanks to those who will answer.
any help?
puma303 is offline   Reply With Quote
Old 09-06-2012, 04:48 AM   #9814
Shop Owner
nnick's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to nnick Send a message via MSN to nnick Send a message via Yahoo to nnick Send a message via Skype™ to nnick
Angelo,
I remember you wrote once that will give us a guide for the settings of v3. Have you publish it as I can't find it
Thank you
Nikolakopoulos Nick
RC RING
The #1 source for all your electric needs www.rcring.eu
Enjoy RCing....
R/C Tech #82
IRT #123
Don't practice until you get it right. Practice until you can't get it wrong
nnick is offline   Reply With Quote
Old 09-06-2012, 01:27 PM   #9815
does anyone have a good startingpoint for 17.5 boosted
Motor: trinity revtech, esc: xtremestock
small/med size carpet
Team Associated TC7.1 - Hobbywing - Highest - Sanwa - Gens Ace
Team Associated B5R - Hobbywing - Highest - Sanwa - Gens Ace
Bappe is offline   Reply With Quote
Old 09-06-2012, 10:29 PM   #9816
Wink
how is the brake setting rules? I can not turn while braking. It must be brake and then turning. Please help
b.wihardja is offline   Reply With Quote
Old 09-09-2012, 06:38 AM   #9817
CFR
CFR's Avatar
Hobbywing XERUN Black 120A 1S esc
Can this run v3 508 No Timing sofware? It has it loaded but won't program to the transmitter.
Can it be undone if it has to be?
CFR is offline   Reply With Quote
Old 09-09-2012, 08:09 AM   #9818
If your brakes are working then the ESC has done its job, and you have a chassis handling, or driving issue. Your tires only have a limited amount of grip, if they are using all of the grip to slow/stop your car then there wont be enough grip to also change the direction of the car. Thats why it wont turn, and pushes to the outside of the corner.
If you drive a full size car the same thing happens, and you should NEVER be using your brakes IN the Corner. You should either be letting the chasiss ROLL, or slight acceleration to pull the car around, and out of the corner.
Hope this helps you,
Shawn.
Shawn68z is offline   Reply With Quote
Old 09-09-2012, 08:15 AM   #9819
What do you exactly mean?
You can't steer the wheel while braking?
Your wheels steer but your car keeps on going straigth?
If your car can't steer (but wheels do) while braking, that's exactly what Shawn68z said.
Otherwise, it's a battery problem, not enough current available.
Durango DEX 210 MM / Reedy Sonic 6.5 / HW V2.1 120A 1S
Durango DEX 210 RM / Savox 6.5 / HW V2.1 120A 1S
Durango DESC 210R / Reedy Sonic 10.5 / SpeedPassion Cirtix Stock Club Race
Tamiya F103GT / Reedy Sonic 10.5 / HW V2.1 120A 1S
FG Sportline 2008 (Formule France package) / Zenoah G230RC
DaTaz is offline   Reply With Quote
Old 09-09-2012, 08:20 AM   #9820
Just got back to racing after 1 year break..
Please help me with Best set up for ESC HW Xerun 120A V2.1 w/930STOCK 10.5T motor with 2cell lipo battery (1/10 Touring Car Racing)
note: will use for small technical track
Appreciated your help.. Thanks
nietzbatik is offline   Reply With Quote
Old 09-09-2012, 12:35 PM   #9821
Aoh
Trader Rating: 16 (94%+)
all of the speedos that can run that motor. i have that issue with my sct pro, v2.1 and v3
Aoh is offline   Reply With Quote
Old 09-09-2012, 02:04 PM   #9822
TCCustoms's Avatar
what do you mean "out of sensor mode"?? IS that both red/green lights blinking even tho everything is still plugged in and untouched as mine does that quite a bit and dont notice until im pretty much done running a pack or testing w/o the body
1/10 Traxxas Summit Blue
Axial AX10 Scorpion * Viper VSC 240/55t combo * Hitec HS-7954SH
TCCustoms is offline   Reply With Quote
Old 09-09-2012, 02:34 PM   #9823
Connect the Speedo to a 2S Lipo and remove the low voltage cutoff, then you can bind to your transmitter using a 1S cell. The LVC stops you from binding as it's expecting 6v minimum as standard (auto, 2S Lipo)
Any issues, please let us know.
CPD Racing
chris_dono is offline   Reply With Quote
Old 09-09-2012, 02:34 PM   #9824
any help?
Hi Puma, which motor and class are you running in ?
CPD Racing
Old 09-09-2012, 10:34 PM   #9825
it is a Lipotech XR 10.5T SPECIAL KIT, I do not know the class. It 'a few days ago that I use the electric.
