Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree5Likes
Old 08-31-2012, 02:28 AM   #9766
COBRARACING's Avatar
Originally Posted by puma303 View Post
hello guys
I have a very important question for me:
the function of the EPA on gas radio, must be 100% or can I decrease? Change will cause problems to the ESC?
Epa on the radio for the esc will not affect anything as it is used for a servo not for the esc if you used it on the steering yes it will affect as it will set the end point of the servo so you dont burn the servo .
20% or 50% the esc will still see the input as 100% throttle exactly what m7 has said in the previous post
Email : [email protected] or [email protected]
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Old 08-31-2012, 09:52 AM   #9767
Any updates on when to expect a V3 1S?
Steve S is offline   Reply With Quote
Old 08-31-2012, 03:25 PM   #9768
ByteStream's Avatar
+1
RCAmerica | Xray | Hudy | KO Propo | Hobbywing HWNA | R1Wurks | BSR Tires
5280 Raceway - www.5280raceway.com
MILE HIGH INDOOR CHAMPS April 20-23rd 2017 @ www.milehighindoorchamps.com
ByteStream is offline   Reply With Quote
Old 09-01-2012, 06:28 AM   #9769
Sir Tamiyalot's Avatar
The other HW thread looked dead so I will try here.
Hi, looking for help.
Will be running a mbx6 1/8 buggy and want to get a good budget friendly esc. I will be racing it on 4s lipo but would like to bash with 2s lipo. I would get the HW 150a esc but heard it has problems with 2s lipo, so I have been considering the xerun sc pro esc which can handle 4s lipo and works good with 2s.
Any problems racing with the sc esc on 4s compared to the 150a esc?
Thanks.
OFNA NEXX10, Schumacher CAT SX3, Mugen MBX6 Eco.
GOODWOOD OFF ROAD MODEL CAR CLUB
Sir Tamiyalot is offline   Reply With Quote
Old 09-02-2012, 03:14 AM   #9770
2 months away
Old 09-02-2012, 03:17 AM   #9771
Thanks.
no issue running the sct pro on 4 s lipo .it also works well with 2 s lipo.
I dont recommend the 150 amp esc on a 2s lipo it is a big speed controller and most run 4 s lipos in their 1/8th buggies
Old 09-02-2012, 03:21 AM   #9772
narcotiks's Avatar
cobraracing YGPM
narcotiks is offline   Reply With Quote
Old 09-02-2012, 03:56 AM   #9773
Is their an advantage racing the 150a esc on 4s over the sc pro esc on 4s?
Old 09-02-2012, 04:56 AM   #9774
the 150 amp can be run inn1/5th scale cars can handle a larher can and turn motor sonething i really dont think.you will need.
Old 09-02-2012, 05:31 AM   #9775
ByteStream's Avatar
2 months away
That is good news .. Is it still the case, that the 1s will not need an external capacitor?
Old 09-02-2012, 05:46 AM   #9776
Thanks alot for your help, much appreciated.
Old 09-03-2012, 09:39 AM   #9777
Default Set esc 10,5t
Guys, what an initial configuration to a 10.5t boosted:
Esc V2-60A, motors option: Xerun blue Baslistik or SpeedPassion V3, which better?
Results of my radio telemetry tests:
FDR 8.5 - 61251 rpm / speed 84,3 km/h / motor temp 95C (with cooler)
FDR 8.90 - 63190 rpm / speed 82,93 km/h / motor temp 100C (with cooler)
Set Esc:
Boost 36
Start RPM 2000
Turbo open: 18 / 01sec.
Turbo timming 28
Turbo open delay 0,3
Boost timming ACC 300
My main opponents have top speed the 94km/h.
Races have 8 minuts, environment temperature is +/- 28C and track +/- 45C
Tks for your help.
314ck5h33p is offline   Reply With Quote
Old 09-03-2012, 12:44 PM   #9778
PutAwayWet's Avatar
So, I have my new HW Xerun 120A 1s installed in my 1/12th. I've got 508 non-timing software onboard, and everything seems to work just fine. But, the "blinky" LED seems to be on the bottom of the ESC and is all but impossible to see. I took it into a dark closet to see if it was actually there. It is, but there's no way to see it in normal light, it's that faint.
Has anyone had trouble teching the Hobbywing in where a visual confirmation of the blinking light is required? Is this the normal thing?
Todd Mason
Seattle RC Racers
The world ends when you're dead. Until then, you got more punishment in store.
Stand it like a man, and give some back. --Al Swearengen
PutAwayWet is offline   Reply With Quote
Old 09-03-2012, 12:51 PM   #9779
OVA
OVA's Avatar
Trader Rating: 77 (100%+)
[QUOTE=PutAwayWet;11168145]So, I have my new HW Xerun 120A 1s installed in my 1/12th. I've got 508 non-timing software onboard, and everything seems to work just fine. But, the "blinky" LED seems to be on the bottom of the ESC and is all but impossible to see. I took it into a dark closet to see if it was actually there. It is, but there's no way to see it in normal light, it's that faint.
I thought for sure I can see mine in day light...need to double check gain..
OVA is offline   Reply With Quote
Old 09-03-2012, 02:25 PM   #9780
S.Stew's Avatar
Hey Todd!
Mine is miss kinda hard to see too. With my layout the blinky light faces the battery and is in a tight spot to see....especially with the body on. If anyone gives you trouble with tech you can always plug in the programmer and show them the software level.
I've also noticed with the Hw stuff that if the radio neutral point isn't exactly at neutral it won't blink. I've had to set the throttle trim so that its exactly at neutral....or reset the esc end points.
S.Stew is offline   Reply With Quote
