Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree2Likes
Old 08-14-2012, 02:39 PM   #9691
Wildcat1971's Avatar
Trader Rating: 79 (100%+)
esc
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 08-14-2012, 06:55 PM   #9692
Originally Posted by COBRARACING View Post
Dear Milton
Yes i recieved the email and it was passed onto accounts and they should have sent you out an invoice for the repair .
I will chase it up now
regards Angelo
Good evening Angelo,
I just received the information from Ms. Bell. And I completed the transaction. I'd like to thank you very much for your assistance and excellent customer service. You now have one more Hobbywing user for life
Milton
oaktreevi is offline   Reply With Quote
Old 08-15-2012, 12:12 AM   #9693
hello
I gave a look to the software and I played around with the demo mode. It would be possible to have a firwmare for the xerun 150A similar to that proposed in Car_turbo_v3? I refer to the settings of the throttle control and brake control. That way we could have more control and more accurate on Throttle and brake
Thanks for the reply.
puma303 is offline   Reply With Quote
Old 08-15-2012, 12:27 AM   #9694
M7H
M7H's Avatar
Originally Posted by Kevin Marcy View Post
I do have one thing that's still not clear to me. The software has 3 different "profiles" that can have different settings in them. Are these profiles stored in the ESC or in the program box?
as mentioned by Wildcat1971, they are stored in the ESC.
Serpent
M7H is offline   Reply With Quote
Old 08-15-2012, 03:28 AM   #9695
peter.'s Avatar
hw v3 is the good in combination with a lrp x12 13.5
peter. is offline   Reply With Quote
Old 08-16-2012, 06:02 AM   #9696
Danielson2's Avatar
I am running a 13T Ezyrun sensorless motor with a Xerun 120 2.1 with the boosted software in it. Is this the best software to use or is there one that will give the motor some sort of advance. Also do many or any of the adjustments such as brake, punch, timing work with the Ezyrun motors using the Xerun ESC ?
In regards to my previous post as above, will an Ezrun ESC run a Ezrun motor better than the Xerun or will it be the same with either ESC ?
Xray XB4, Mugen MBX6 Eco.
Danielson2 is offline   Reply With Quote
Old 08-16-2012, 12:37 PM   #9697
ByteStream's Avatar
Angelo,
Can you explain the differences between v3_120612 and v3_120808 USB software?
What was changed/added/removed/fixed/etc?
RCAmerica | Xray | Hudy | KO Propo | Hobbywing HWNA | R1Wurks | BSR Tires
5280 Raceway - www.5280raceway.com
MILE HIGH INDOOR CHAMPS April 20-23rd 2017 @ www.milehighindoorchamps.com
ByteStream is offline   Reply With Quote
Old 08-16-2012, 04:21 PM   #9698
COBRARACING's Avatar
Originally Posted by puma303 View Post
hello
no they will not work with the v3 settings for the 150 amp
Email : teamcobraracing@gmail.com or ae@hobbywing.com
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Old 08-17-2012, 06:32 AM   #9699
Default V3 setup
Hello I'm Paulo from Madeira Portugal
I use to run a gm esc and i change to hobbywing V3. The fists run i was surprised with it, so fast and really amazing to drive,
with profile 6 / GM motor 13.5t i start 2 minutes run and watch temp, and 4 minutes watch temp but 5 minutes run just cut off motor temp
I read de manual and the FDR for TC 13.5 is between 4.00 to 5.00 so I used FDR 4.375
So I need same help for a good set-up please.
Our track is very big asphalt with a 90m straight
I will be grateful for any help
tanks
pauper is offline   Reply With Quote
Old 08-17-2012, 08:22 AM   #9700
FunkyDunky's Avatar
Hi All,
Been doing some testing with the V3 on 21.5 boosted but feel my motor temps are too high for my liking, has anyone got some base settings to work from and I can see if I am a long way off? Although a know it is track dependent an idea of FDR would be good!
Cheers
FunkyDunky is offline   Reply With Quote
Old 08-17-2012, 08:33 AM   #9701
Pro10noob's Avatar
It also depends on what motor you are running.
The Hobbywing motors run a lot cooler then for example the LRP X12.
regards Roy
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 08-17-2012, 08:35 AM   #9702
Pro10noob's Avatar
@Pauper.....Do you run boosted or blinky??
regards Roy
l===/o\===l
Old 08-17-2012, 09:50 AM   #9703
regards Roy[/QUOTE]
Running boost
Cheers
Old 08-17-2012, 10:31 AM   #9704
syndr0me's Avatar
Trader Rating: 32 (100%+)
If FalconSekido is "Hobbywing of North America" then what is CRC?
syndr0me is offline   Reply With Quote
Old 08-17-2012, 10:41 AM   #9705
Pro10noob's Avatar
With a FDR of 4.3??
No wonder the motor is running hot.
Go up to 5.5 and temp again.
I was running a FDR of 7.5 on a tech track with a straight of 50 meters.
Motor temp was 71 degrees celcius after 7 minutes.
regards Roy
Originally Posted by pauper View Post
Running boost
Cheers
l===/o\===l
