Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree5Likes
Old 08-05-2012, 02:29 AM   #9616
TryHard's Avatar
Originally Posted by SeanV View Post
This might seem like a stupid question but my understanding is...
When you load the no timing software onto an XeRun, shouldn't there be a blinking light (hence blinky mode) to indicate to scrutineers that the ESC is running no timing and is in blinky mode?
I have loaded the no timing software (V3_508_NO timing)onto my Xerun 60A and there is no blinky light - what gives?
(It definitely has the no timing software loaded, in Advanced settings of the USB link, all the timing settings are grayed out which is what I would expect.)
AS Cobra said, it can be very faint, and if you have it in a difficult to view place, can be a real issue to see.
HiH
Ed
Old 08-05-2012, 10:36 PM   #9617
a little question :
there is a way to know if it's released a new firmware version of my esc without having to connect it to my PC ( i've got the XERUN-150A-SD ) ?
i see that the downloaded version for usb link software is from 12/06/12, is right? i use already this version...or there is a new version?
puma303 is offline   Reply With Quote
Old 08-06-2012, 02:31 AM   #9618
COBRARACING's Avatar
Originally Posted by puma303 View Post
a little question :
There is no new software for the 150amp esc .Yes you need to use your pc and liad the usb to see it there are any updates.
Email : teamcobraracing@gmail.com or ae@hobbywing.com
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Old 08-06-2012, 02:33 AM   #9619
Brushless Hobbies and Bullistorm products are not Hobbywing oems we have no association never had never will.
thanks for your time.
Old 08-06-2012, 02:47 AM   #9620
thanks for answer. Do you know if will came someone?
Old 08-06-2012, 10:47 AM   #9621
bkspeedo's Avatar
Has anyone tried increasing the cap size on a HW ESC to increase brakes?
I'm using a Justock with V3_508_NO_timing FW in a 17.5 and 13.5 TC and the brakes are horrible. 2 different motor's; 17.5 Thunder Power and the 13.5 Revtech.
I did not have this issue with a Tekin w/223 fw.
I love this ESC but it needs better braking. Any help would be appreciated.
Brent Klingforth
Sponsors: Awesomatix USA ~ Roche USA ~ ORCA ~ AVID Bearings ~ R1 Wurks
TQ Wire ~ Montech ~ WTF ~ BSR Racing Tires ~ 2mm Design
5280raceway.com [Operated by - Colorado On-Road RC Club]
MILE HIGH INDOOR CHAMPS April 20-23rd 2017 @ www.milehighindoorchamps.com
bkspeedo is offline   Reply With Quote
Old 08-06-2012, 10:48 AM   #9622
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
did you recalibrate the esc after you made the changes?
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 08-06-2012, 10:55 AM   #9623
bkspeedo's Avatar
Yes I've done it all. Tried numerous changes in drag brake and brake settings nothing has changed the feel.
Brent Klingforth
Old 08-06-2012, 02:27 PM   #9624
If it's a V2.1 then try the following:
set your end point for throttle/brake to 95%
calibrate your speedo
set your end point back to 100%
set brakes to 100%
This should be enough hopefully, if not, please get in touch !
CPD Racing
chris_dono is offline   Reply With Quote
Old 08-06-2012, 03:17 PM   #9625
bkspeedo's Avatar
set brakes to 100%
I believe i tried this technique but I'll try it again this wed when i race again.
Brent Klingforth
Old 08-06-2012, 07:54 PM   #9626
NolanP's Avatar
Can someone tell me how 2A directly effects my speed control?
Followed by setting punch 1 and punch 2 together?
Ie if I'm at 99, 30, 30 does that mean I will get full power to my motor?
Sorry for dumb questions used to a Tekin.
Mod Touring Car
Mod 12th
Nitro TC
Nitro GT
Wheeler and Mod Buggy
NolanP is offline   Reply With Quote
Old 08-06-2012, 08:47 PM   #9627
Trader Rating: 19 (100%+)
Hey Brent, have you tried setting the reverse force to 100% as well as the brake force. Make sure it's in FWD only mode and this should help make the brakes a little stronger.
★Randy Banks★
COLD AS ICE is offline   Reply With Quote
Old 08-06-2012, 10:13 PM   #9628
bkspeedo's Avatar
I have not tried that, will give it a try this week.
How's that VBC car working for you?
Brent Klingforth
Old 08-07-2012, 02:08 AM   #9629
ta04evah's Avatar
I done this with my hobbywing xtreme stock and it gave me more braking force.
Also I can't exactly recall where it was said but someone suggested using 4 capacitors like this http://www.ebay.com.au/itm/Hobbywing...item2c657041fd rather than the 2 capacitors that come with it.
Cheers
Rob.
Castle Hill RC On Road Facebook https://www.facebook.com/groups/121817254587521/
FatBear RC Videos https://www.youtube.com/channel/UCjiAhwa-rk5Vas2rv5IBD4A
ta04evah is offline   Reply With Quote
Old 08-08-2012, 04:18 AM   #9630
Is there any way to install supercharge software into my xerun 150 esc?
Overunitygreg is offline   Reply With Quote
