Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 08-06-2010, 08:39 PM   #946
AdminD's Avatar
hello guys is there any brushed firmware for hobbywing ?
Sliders
AdminD is offline   Reply With Quote
Old 08-07-2010, 01:10 AM   #947
The hobbywing esc does not support brushed mode sorry.
Simon
Team_Krusty is offline   Reply With Quote
Old 08-07-2010, 05:27 AM   #948
COBRARACING's Avatar
Hobbywing hasnt supported brushed systems for a long time .None of there esc's support brushed motors so no firmware for brushed motors.
Email : teamcobraracing@gmail.com or ae@hobbywing.com
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Old 08-07-2010, 11:00 AM   #949
Hi, I'm planning to run 8.5 on my SC. But will 10.5 with supercharge firmware go faster than 8.5? And what do you guys think of running 8.5 with supercharge firmware on low turbo setting? Or should I stick with the normal software and just use the normal timing adjustment?
Thanks.
Wilson Picaldy is offline   Reply With Quote
Old 08-08-2010, 12:30 AM   #950
This has surely been posted but I did not find it easily in the thread atleast.
I am new to hobbywing and I run TC rubber mod, 17.5t and 1s 1/12 and SC mod.
Could someone do a summary of what ESCs to run in which class and what software versions to use? Some starting setups and FDR:s would be nice also.
goos is offline   Reply With Quote
Old 08-08-2010, 12:38 AM   #951
TeamWTF's Avatar
8.5 with timing is no prob for the 120a xerun. 10.5 with timing will be much faster then 8.5 without.... i don't think you would need anything more then 10.5 with timing in a 2wd... but i race 2wd buggies! I had no trouble with low timing settings wheel standing down our main straight, but it was still good to drive in the tighter stuff. Loved it...
xerun 120a is the best all round speedy... The advantage of the stock speedy i size which is handy in TC... but leaves you limited in motor selection.
T.O.P. Racing Australia www.topracing.net.au
TeamWTF is offline   Reply With Quote
Old 08-08-2010, 12:41 AM   #952
Bishop's Avatar
I ran my 60a Xerun the other night for the first time, considering I don't have a programmer or turbo ware on it yet, was surprised by how quick it was in general, at least compared to others running non turbo style esc's.
Also I, and others noticed just how good the brakes are, in fact I don't think I have ever seen anything pull up as quick as something with a HW in it, great if your a late braker off a high speed straight.
QRCCRA
www.qrccra.org.au
www.facebook.com/englandparkraceway
www.myrcm.ch/main?pLa=en&hId[1]=org&dId[O]=4331
Bishop is offline   Reply With Quote
Old 08-08-2010, 12:45 AM   #953
TeamWTF's Avatar
FDR's - I used to run 7.0 - 7.5 in 10.5, and have only run 17.5 once on a large track.... ran 6.0 - 6.2 FDR
With timing that is.
17.5 - Start around 6000-7500rpm. Timing settings highish... so close to max with low motor timing. Play with punch and turbo delay to keep heat away and stop esc from spazzing out. But usualy punch run around 200rpm per degree
10.5 - Start around 9000rpm. Timing set about mid way.. low motor timing. Same as above for punch and turbo delay., probably a little less aggressive on the punch
Should be ably to play with that
Old 08-08-2010, 03:46 PM   #954
Thanks.
We have done the testing and yes the 10.5T will run faster than the 8.5T with the turbo function .The 8.5T with turbo function will not make a huge power difference and will probably cause more heat that is needed.
for the 8.5T just use the normal timing function it will be prefect for you as the turbo function was designed to function at its best with 10.5T and over .
Old 08-08-2010, 03:49 PM   #955
Hi Guys
Lets congratulate Kc shore who powered his hobbywing 80 amp powered 1/8th scale xray to hobbywings first ever national title .
He used the 80 amp esc with a 2250kv combination to win the Australian national title .
congratulations kc .
Old 08-08-2010, 04:54 PM   #956
ShadowAu's Avatar
Can't wait to try my 60A out...
Angelo I sent an email to the cobraracing email address... how long does it take you guys to reply?
Cheers
My car may look like it goes bad to you, but its actually far worse that you think it is...
I have only one more RC thing on my bucket list and I will keep racing (and probably coming last) till its done.
ShadowAu is offline   Reply With Quote
Old 08-08-2010, 09:07 PM   #957
So a 8.5 with normal timing still much faster than 10.5 with turbo timing right?
What turn will you recommend?
Old 08-08-2010, 11:29 PM   #958
whityboy's Avatar
I have bought a new hobbywing 120A for my T3 and put my 60A in my X6-2. After I got home I noticed I got a 2.1 version and also that the caps are not wrapped with shrink tubing and are just soldered on a small circuit board with no protection. After my first 5 min run I changed my battery and the caps where smelling badly. I touched one to check the temp and than there whas smoke and a lot more burn smell. The esc still works without issues but if I dare touche A caps It starts smelling and makes a sound like there is a short circuit. So I would recommend everybody to put some heat shrink over there caps. Still would be better if hobbywing would do that before selling them (don't know if every 120A version 2.1 is sold without heat shrink).to be on the safe side I will order some new caps and replace them
whityboy is offline   Reply With Quote
Old 08-09-2010, 02:49 AM   #959
Default 10.5 x12 setup help
Please help on this one,
Motor is LRP x12 10.5T with default mechanical timing(zero).
Air temp 84F/29C
Track temp 95-104F/35-40C
Motor temp after 5min of run 185F/85C with YR tornado 14000rpm fan
Track/tire grip medium - open medium large track
Current setup:
FDR=6.8
punch is level 7
drag brake 10%
#9 - 3
#12- 5
#13- 2 or 3
#14- 2
#15- 4
I didn't have any time to play with option #15 but this option kinda force u to change all other.
If i go with #9 and #12 up motor is to hot.
Can u sugest what to change on setup or maybe give whole setup to try.
I need increase my speed performance without loosing punch as i have LRP/NOSRAM guys that are damn fast with new speedos - same motor.
tomislav is offline   Reply With Quote
Old 08-09-2010, 10:24 AM   #960
GasserX's Avatar
Are you saying the 10.5 will run faster than the 8.5 with the mod or stock turbo program (please provide program number and vehicle type)?
LOSI 8E 4.0
LOSI 22-4 V1.5
LOSI 22 3.0 Dirt Laydown
GasserX is offline   Reply With Quote
