NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE
#9511
It would also be fantastic if rollouts were on there too, it takes hours to trawl through this thread to find where different classes should start
Kev
#9512
So Angelo http://rcmarket.com.hk/product_info....ducts_id=13471 this is fake ?
Funny because V3 should not available on the HK market
#9513
Fake also? http://www.rc-mushroom.com/product_i...sc-red-p-25187
#9514
I don't know.Ask cobra
#9515
Cobra, I need your help:
In the class motor 10.5t (I have Ballistic and SP V3), which the maximum possible degree of advancement in the motor? Whereas Ballistic ranges from 15º/45º and SP 0 ° to 10 °.
I need to know the maximum degree, motor + esc timming, for the maximum RPM and the FDR more short.
For use on road, turing Cars, and V2 Xtreme Stock.
Tks.
Tks.
#9517
but you're not considering the timming motor (physical timming) ...
#9518
my question is a limit, 64º + 45º motor timming = 109º, understain? how far can I go?
#9519
Fail!
Hobbywing firmware will add 64 steps of timing. How many actual degrees these are, I don't know.
Until it starts smoking.....
#9520
its ok!!
in my tests were 64 ° in ESC (50 + 14 turbo) and 20 in the physical motor = 84 in total timming. I believe the limit is 90, most likely to reach full RPM, Is it?
#9521
As for your other question, the limit is certainly not 90°, more like 60°-64°. At 90° the motor won't turn, as it won't know which way to spin (been there, done that with an old brushed motor!). Anymore than 65°, you'll be adding heat for no real increase in power, and thats motors with high in-built timing levels combined with high levels of ESC timing tend to struggle (X12 anyone? )
Part of the idea of the dynamic ESC's is that as you increase the rev's, the motor naturally retards the timing (think about cyclinders firing in an engine). To keep the same timing level, you need to be 'firing' the coil earlier with each increase in rpm. And this is where the dynamic ESC's come in... as they add timing to compensate for when it's needed (i.e. up the rev range).. hence lots of power through the rev range
Bear in mind as well, adding motor timing add's time through out the whole rev range, not just the specific part of the band that's wanted... which is why you can't also really compare adding motor timing to adding ESC timing in terms of heat.
Anyway, sounds like your pretty close with your current settings... best way to test this all out is on the track.. make a change (add motor timing) and see what happens
HiH
Ed
#9522
anything you need please let us know .
#9523
deleted
#9524
The point is there are a lot of contradictions here.First, that the V3 will be released as the hobbywing brand not any oem brand for atleast the first 6 months of the release and maybe longer (#5706) .This is not true as Hw has already released the V3 as an OEM for HPI and Yokomo(good for us).Second,It has been decided by the team of 4 Angelo,michael,Pan and Jack that the v3 will not be available from Hong kong especially for the 1st year of sales (#6429). RcMushroom & rcmarket already selling them (good for us too ) and the only thing you have to say is "good luck" if we buy from them.Thats my point.
However I did find a blatant knock off called "Hobbypower V3"
http://www.ebay.com.au/itm/Hobbypowe...item3a774533f8
Funny thing is that at the bottom of the page they admit it is a copy with this little gem of a description.
"Attention: this product is not Hobbywing product,but as good as hobbywing, compatible all hobbywing program and software."
As good as Hobbywing?
Cheers
Rob.
Last edited by ta04evah; 07-18-2012 at 02:10 AM. Reason: Posted the correct link this time lol
