Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree5Likes
Old 07-13-2012, 05:35 AM   #9496
RasCalDK's Avatar
Originally Posted by jensen123 View Post
Dear Angelo,
I have been using your company product V2.1 for more than one year, so far so good and even both quality and after sales service. Now I'm using the new V3, It works good for me with my teampower 4.0T motor. But my team mate using the Lrp X20 4.5T is upset, he using FDR of 8.5 zero boost and 15 turbo only, but he can play for 2 to 3 mins only then overheat cut....... the temp. of esc was 132 or above.....
We had tried to change the gear ratio, larger capacitor (4 pcs of hobbywing), smaller turbo setting, also cannot fix that problem.
Would you please give me the setting for using with the Lrp x20 4.5T motor running with touring car.
Thanks a lot!
The temp also depends on how how hard he is on throttle. Have you tried his car? Is the temp the same.
Rasmus T. Callesen - Denmark
Serpent S411 - Serpent.com/2-speed.de
Hobbywing Xerun V3 and Thunder Power Z3R motors - ToniSport
RasCalDK is offline   Reply With Quote
Old 07-13-2012, 06:42 AM   #9497
Default Hobbywing v3 setup for a 13.5 LRP X12 motor
Hi Guys,
Does any one have a basic setup for a V3 with a 13.5 LRP X12 motor in a touring car. I will be using the car on a large outdoor asphalt track.
Many thanks
XRAY T4 Hobbywing V3 Sanwa
FLAT OUT is offline   Reply With Quote
Old 07-14-2012, 03:00 AM   #9498
Just wanted to take this occasion to publicly thank Cobraracing for his help in following up a customer related repair. His was able to track down my repair order and get back with me on the status in less that a day. I must admit that I was extremely impressed with the personal attention that he gave to my case. Great service Angelo.
calvin is offline   Reply With Quote
Old 07-14-2012, 03:38 AM   #9499
Default Hobbywing v3 fan
Hi Guys,
I assume the fan on the esc can be removed, Ive tried to pull the little plug out but its so tight Im afraid of damaging something.
Old 07-14-2012, 03:57 AM   #9500
TryHard's Avatar
Just use a small flat screw driver to prise the fan plug out.
HiH
Ed
Old 07-15-2012, 02:26 AM   #9501
chrislow's Avatar
Trader Rating: 17 (100%+)
Dear Angelo, I was wondering what is the best way to go about repair with an esc. I have a xerun 150 in my D8 and today while racing the post of one of the motor wires clean came out of the circuit board. Clearly stopped me dead and ended my race
Does hobbywing have a exchange program or repair, not sure if its still under warrenty less than 6 months old. I have tried to solder it back on, it wont be as strong as factory but it worked on the bench. I have been very happy with it so i hope i can get it fixed
chris
M03R mini cooper -- T2'008
XXX-CR -- D8 V4 conversion
chrislow is offline   Reply With Quote
Old 07-15-2012, 07:33 AM   #9502
CraigMBA's Avatar
Trader Rating: 22 (100%+)
chris
What's the difference between your soldering iron and theirs?
Sounds like you fixed it yourself.
* Cee Lo Dizzle, the Secizzle * Red Bull * Team Homies * Pintura de Negro Mate * USVTA #152
CraigMBA is offline   Reply With Quote
Old 07-15-2012, 01:35 PM   #9503
Stanfsu's Avatar
Trader Rating: 294 (100%+)
Send a message via Yahoo to Stanfsu
Looking for a reasonable priced ESC to run USGT (21.5T). Any suggestions?
It must be ROAR approved. I was thinking of the C-Xerun 60A that sells for about $60.
Losi | Futaba
Low Ballers will be ignored!
Stanfsu is offline   Reply With Quote
Old 07-15-2012, 02:12 PM   #9504
chrislow's Avatar
There is a little tab that goes through the circuit board which should be soldered right through. I could only solder to surface at the top because I couldn't get the tab through the hole and because there are two circuit boards sandwiched together I could only solder the top. Like I said, it works but Not as strong as it should be.
Chris
Old 07-15-2012, 03:22 PM   #9505
COBRARACING's Avatar
Chris
Dear Chris
please send me an email at [email protected] or [email protected] and we will work something out
regards Angelo
Email : [email protected] or [email protected]
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Old 07-15-2012, 03:24 PM   #9506
Depending if you want to run turbo software you buy the 60 amp xerun if not buy yourself a justock .
Old 07-15-2012, 05:53 PM   #9507
It's my job to help but thank you for your kind words
regards Angelo
Old 07-15-2012, 06:14 PM   #9508
Hi Guys i am going to do some setup sheets for the following v3 and 2.1v
Motors 4.5T 5.5T 8.5T 11.5T 13.5T 17.5T 21.5T
These will be basics sheets to get you started but will also perform as they should .
Old 07-16-2012, 12:16 AM   #9509
Good idea angelo. Post a link when there done
markrobinson is offline   Reply With Quote
Old 07-16-2012, 02:49 AM   #9510
tmomedrano's Avatar
not sure if this has been answered before:
which is cooler for the motor? more boost less turbo or less boost more turbo?
ex. boost timing is 50 and turbo is say 14 vs. boost timing is 40 turbo is 24 vs. no turbo just 64 of boost
assuming everything else is the same.
reason i asked is in our home track i find 40 boost and 24 turbo too much. i feel like im running out of straight even before the turbo sets in fully. thinking of pushing the boost more with less turbo timing and then maybe id also get more kick on the technical parts and short straights
other setup details: no turbo delay, 250 ACC, 3000 start RPM, 7.6 fdr, 13.5 vst pro motor (full mechanical timing), temp is at 172* my highest so far after 8 mins of running (IKR, i was having too much fun to even notice)
im using a V2.1 so theres no throttle trigger sensing factor purely revs.
[ Team Maxx Traxx ] http://iloveporrc.blogspot.com/ * http://timmedrano.com
tmomedrano is offline   Reply With Quote
