Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree5Likes
Old 07-06-2012, 10:11 AM   #9466
artwork's Avatar
Trader Rating: 59 (100%+)
I am selling a used v3...works perfectly Check it out here FS: Hobbywing V3 Black
Sanwa | R1 Wurks | Avid | 2mm Designs
artwork is offline   Reply With Quote
Old 07-06-2012, 04:39 PM   #9467
hanulec's Avatar
Trader Rating: 27 (100%+)
What are you going to now??
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 07-06-2012, 04:41 PM   #9468
artwork's Avatar
Duh...Novak of course
Old 07-06-2012, 05:20 PM   #9469
LOSI123's Avatar
Trader Rating: 63 (100%+)
Can anyone tell me if Tekin, Novak & LRP motors all work without issue with the hobbywing Xtreme stock esc? and also with the new V3 ESC's?
LOSI123 is offline   Reply With Quote
Old 07-07-2012, 11:28 PM   #9470
COBRARACING's Avatar
No issue they all work with thehobbywing esc's
Email : teamcobraracing@gmail.com or ae@hobbywing.com
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Old 07-08-2012, 12:11 AM   #9471
CraigM's Avatar
Trader Rating: 34 (100%+)
Yannick and Andy are both going strong at ETS for Hobbywing, will we be able to get some setups soon? I'd like to see what they are running on a tight track like that.
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 07-08-2012, 06:27 PM   #9472
russp's Avatar
Hello, what's up with the v3
"Never argue with an idiot. They'll just drag you down to their level, and beat you with experience!"
***radiopost.com***Gens ace/hobbypartz.com***Evosports.net
+++Losi xxx-sct 17.5+++Losi 22. 17.5+++losi xxx-sct mod+++
russp is offline   Reply With Quote
Old 07-09-2012, 01:06 AM   #9473
AGNO's Avatar
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Old 07-09-2012, 08:00 AM   #9474
RasCalDK's Avatar
It's very good.....
A specific question would give a specific answer
Rasmus T. Callesen - Denmark
Serpent S411 - Serpent.com/2-speed.de
Hobbywing Xerun V3 and Thunder Power Z3R motors - ToniSport
RasCalDK is offline   Reply With Quote
Old 07-10-2012, 04:20 AM   #9475
daleburr's Avatar
Heatsink side up, flat side down. Otherwise the wires will drag on the track.
Team Xray
RC-Timing Software - http://www.rc-timing.com
Mercedes AMG F1 - http://www.mercedes-amg-f1.com/
daleburr is online now   Reply With Quote
Old 07-10-2012, 04:47 AM   #9476
M7H
M7H's Avatar
Serpent
M7H is offline   Reply With Quote
Old 07-10-2012, 05:18 AM   #9477
ScottyTC4NZ's Avatar
Send a message via MSN to ScottyTC4NZ
Hi Guys, looking for a boost only setup for v3 to run with a sp 3.0 13.5t motor.
Any help would be great
Jamie Scott
Onroad Race Director
O.R.C.C.C
Titan ARC R10 2013 / Blitz / Sweep / Team Titan
Titan ARC R10 Upgrade / Blitz / Sweep / Team Titan
ScottyTC4NZ is offline   Reply With Quote
Old 07-10-2012, 05:35 AM   #9478
SlideMasteR's Avatar
Will hobbywing be at the worlds in 2 weeks time ? my spare esc has not arrived and hoping i can get one there
Xray T4 15' - Hobbywing V3.1 ESC - Reedy Modified Motors - Thunder Power Batteries - Protoform - Much More
SlideMasteR is offline   Reply With Quote
Old 07-10-2012, 12:10 PM   #9479
Default Xerun 1S --- temperature issue --- 95C
Hi all,
hoping that someone can help with the following (which seems pretty much of an issue to me - unless one can confirm this is normal):
I'm using a Xerun Hobbywing 1S in an 12th scale car, running IP 6400 lipos (1s).
After the run the motor tends to stay rather cool but the ESC goes through the roof (depending on the motor: 70 to 95C).
How can I reduce this temperature to 'normal/reasonable' levels without jeopardizing my speed & power this ESC is offering me ??
My settings:
- Hobbywing 1S
(16Awg wires to the motor, 14Awg wires to the battery)
(no cooling no fan installed)
- Battery: new IP 6400 lipos 1S (charged normally: 1S = 6AMP)
- Radio: futaba 3PM 2,4gHz with original receiver R603FF
- track: small & tight track with a lot of 180 turns
- motor: LRP X20 4,5BL
no timing on motor - roll out 32,0 > 86C
(with a roll out of 30,5 >>> temperature = 95C)
- motor: NOVAK ballistic 4,5BL
no timing on motor - roll out 30,5 >>> temperature = 70C
settings on hobbywing:
- STOCK software installed (110211)
(with latest MOD software: temperatures are still over 60C but less power)
- drag brake force: 0%
- DDRS: level 4
- max brake force: 75%
- max reverse force: 25%
- initial brake force: 0%
- neutral range: normal (9)
- boost timing: 15
- turbo open time: 18deg / 0,1 sec
- over heat: disabled
- turbo timing: 15 deg
- boost start rpm: 7000 RPM
- turbo open delay: off
- boost timing: 250 rpm/deg
After running the temperature drops within 3-5 minutes back to normal temperatures (25-30C), but directly after running - even the carbon chassis is 'too' hot to hold.
Can anyone help me with reducing the temperature without compromising on speed&power? Or are these temperature levels acceptable and within Hobbywing limits?
Thanks a lot for your help & input
Benedict
Benedict is offline   Reply With Quote
Old 07-10-2012, 12:28 PM   #9480
Shop Owner
nnick's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to nnick Send a message via MSN to nnick Send a message via Yahoo to nnick Send a message via Skype™ to nnick
I think you are using rather aggressive settings. Maybe you should because its 1/12..
Anyway I would try to do the following changes having i mind that you are running a 4.5!
- boost start rpm: higher than 1000 RPM
- turbo open delay: 0.1 or higher
- boost timing: higher than 600 rpm/deg
Nikolakopoulos Nick
RC RING
The #1 source for all your electric needs www.rcring.eu
Enjoy RCing....
R/C Tech #82
IRT #123
Don't practice until you get it right. Practice until you can't get it wrong
nnick is offline   Reply With Quote
