Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree5Likes
Old 06-25-2012, 03:42 AM   #9421
RasCalDK's Avatar
Default 17.5 boosted on V3
Originally Posted by NR View Post
Reverse speed 100%
Voltage cutoff auto
Esc overheat 105
Motor overheat 105
Pr sw point 50%
1st punch rate 30%
2nd Punch Rate 30%
TH Curve Linear
Drag 0%
Brake strength 100%
Br sw point 50%
1st brake rate 20%
2nd brake rate 20%
Brake curve linear
Boost timing 42 deg
BT Start Rpm 1000 rpm
BT end rpm 12000
BT slope linear
BT by Th yes
Turbo timing 22 Deg
TT Activation - full throttle
Full throttle delay 0.1s
TT start rpm 9000 rpm
Yesterday i got to testing this setup with my 17.5 GM, haven't my ThunderPower jet.
As the weather in Denmark is kinda rainy, i had to test on my local indoor track. Which is very tight an has a 24 m straight.
I started with a gearratio of 6.17 and a fan to cool the motor. I started by checking the temps often, but barely got 50 deg C, even though it was very fast. I didn't like the way the turbo kicks in, as you really felt the delay. To get rid of it I felt I had to punch the throttle out of the corners.
I changed the Turbo is activated to:
TT Activation - full throttle and RPM
Full throttle delay instant
TT start rpm 12000 rpm
This made the throttle much more linear and a dream to drive, without higher temps. Then i added more boost and turbo until i got some heat on the motor.
Now I'm just waiting for my ThunderPower motor!
Very happy with the V3!
Rasmus T. Callesen - Denmark
Serpent S411 - Serpent.com/2-speed.de
Hobbywing Xerun V3 and Thunder Power Z3R motors - ToniSport
RasCalDK is offline   Reply With Quote
Old 06-25-2012, 11:39 AM   #9422
Barry_Hughes's Avatar
Is there an easy way of converting V2.1 settings to V3?
I have an extremely good setting on my extreme stock, but i am struggling to try and get the same punch & top end speed when I use the V3 with the same car/motor/ratio
Built it !
Raced it !
Wrecked it !
Barry_Hughes is offline   Reply With Quote
Old 06-25-2012, 11:49 AM   #9423
Trader Rating: 27 (100%+)
Just wanted to report in about the throttle issue. Turns out that one motor had a bad sensor board, which is what thought too. However, it didn't explain how the good motor still had the throttle problem.
I switched the Hobbywing esc to the tekin and everything went away. Throttle is excellent. Radio and receiver are just fine.
hyujmn is offline   Reply With Quote
Old 06-26-2012, 04:53 AM   #9424
JonboyGB's Avatar
Hi all,
I'm patiently waiting for my new v3 to arrive
While I wait, I thought I'd do a bit of research. I recently overheard a conversation at track about an 'app' that can be downloaded for the iPhone/ipad which can be used to control the v3 via Bluetooth? At the time of hearing this I wasn't thinking about getting a Hobbywing so ignored it. But now I've got one coming – is this true or just a load of nonsense?
JonboyGB is offline   Reply With Quote
Old 06-26-2012, 04:53 AM   #9425
JonboyGB's Avatar
While I'm here Does anyone have a good setting for the v3 for a fast but twisty indoor track on carpet. Using a GM2012 13.5.
Old 06-26-2012, 04:57 AM   #9426
defcone's Avatar
Trader Rating: 15 (100%+)
Originally Posted by JonboyGB View Post
Hi all,
While I wait, I thought I'd do a bit of research. I recently overheard a conversation at track about an 'app' that can be downloaded for the iPhone/ipad which can be used to control the v3 via Bluetooth? At the time of hearing this I wasn't thinking about getting a Hobbywing so ignored it. But now I've got one coming is this true or just a load of nonsense?
That's for speed passion.
defcone is offline   Reply With Quote
Old 06-26-2012, 05:06 AM   #9427
COBRARACING's Avatar
Maybe the Tekin has less sensitivity at the sensor port who knows .
Email : teamcobraracing@gmail.com or ae@hobbywing.com
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Old 06-26-2012, 06:47 AM   #9428
NR
NR's Avatar
Trader Rating: 52 (100%+)
Glad you liked it I will have a fiddle with the things you mentioned and let you know my thoughts
Nathan
NR is offline   Reply With Quote
Old 06-26-2012, 11:09 AM   #9429
RasCalDK's Avatar
Nathan
I liked your original setup, but because of the turbo delay, you had to punch the throttle to get the turbo to kick in when you want it to.
When I changed the turbo activation, it was possible to drive much smother, as the turbo would kick in after the boost, if you use full throttle.
But thank you for the setup, really help me, as i had absolutely no starting point
Old 06-27-2012, 11:28 PM   #9430
Create and Save your own setups easily !
http://cpdracing.co.uk/index.php?opt...info&Itemid=60
CPD Racing
chris_dono is offline   Reply With Quote
Old 06-28-2012, 03:07 AM   #9431
CraigM's Avatar
Trader Rating: 34 (100%+)
Do people realise the v3 box comes loaded with profiles for most of the common winds? Mod, 13.5, 17.5, etc. They are conservative but are good starting points for most tracks and motors, and it's pretty easy to tune once you run them and get a feel for gearing, temp, and what you need more of
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 06-28-2012, 04:35 PM   #9432
Trader Rating: 24 (100%+)
Default help!
Has some one had this problem before with the lcd.Thanks
Ivan
Team Associated TC7.1/HW XR10 Stock Spec/HW Bandit 10.5T/Arrowmax LP 52000 7.6v
IVAN RM is offline   Reply With Quote
Old 06-28-2012, 04:42 PM   #9433
Ivan
Yes i have had this problem once or twice just reload the software from the usb link data base and it will go back to normal.
Old 06-28-2012, 05:00 PM   #9434
Thanks I will reload the software again.Another question right now the lcd have the V1.08_120504 and I want install the V1.07_101224.When I try some window appear and tell me I cant change the version.
What I need too do for make this change on lcd.
Thanks, Ivan
Old 06-28-2012, 07:19 PM   #9435
NR
NR's Avatar
The stock profile is way to slow for a starting point.
