Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree5Likes
Old 06-21-2012, 06:42 PM   #9406
NR
NR's Avatar
Trader Rating: 52 (100%+)
Originally Posted by FFred View Post
Not exactly because if it's "full throttle" on the TX and not on the ESC, he could be "full throttle" before the Boost timing end, and even before that 9000RPM threshold.
The only thing about that "full throttle" is that as soon as 0.1s is passed after full throttle is press on the TX, then the Turbo is starting.
Now, it's almost set in a way that Turbo can't start before all the Boost timing is reached.
So his Turbo is not starting before Full Throttle + 0.1s, and only if Boost timing is already used.
Im quite new to all this myself, and have been helped out by a few guys at the track and couldn't be happier as the car is quick, "just not the guy holding the transmitter"
What would you advise I change Fred?
NR is offline   Reply With Quote
Old 06-21-2012, 09:07 PM   #9407
Trader Rating: 27 (100%+)
Update again. Did some testing tonight and there was no change. After about 3 mins, the problem would start and not stop. I tried disabling the voltage detection and over heat detection. Didn't do anything.
Cobra, is there anything else i can try? If not, I'm sending it in for an RMA and switching to tekin.
hyujmn is offline   Reply With Quote
Old 06-21-2012, 09:55 PM   #9408
COBRARACING's Avatar
If your battery or batterys have a massive voltage drop /dump doesnt matter the voltage cut off being off ill not help your issue.
what batterys are you running as it seems to me a energy issue especially after 3-4 minutes of run time the esc or the software is not going to cause the proble you are having .
regards ANgelo
Email : teamcobraracing@gmail.com or ae@hobbywing.com
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Old 06-21-2012, 10:36 PM   #9409
regards ANgelo
I dont think the battery is the issue. Remember that this problem was occuring in the same manner with some different parts. Battery played no part in it at that point.
Also, like I said, I've tested 3 different batteries. Gens Ace 5000mah 40c, Turnigy 6000mah 65c, and an Orion 50c battery. All the same problem.
There's one common factor here: the ESC. I'm already in the process of hooking up my Tekin. I'm sending that one in for repairs.
Old 06-22-2012, 12:07 AM   #9410
Barry_Hughes's Avatar
Does turbo only come in after the boost is used?
On the Extreme Stock dependent on the software version, turbo can come in before the boost is used.
Built it !
Raced it !
Wrecked it !
Barry_Hughes is offline   Reply With Quote
Old 06-22-2012, 09:37 AM   #9411
Suspended
Originally Posted by mulepic View Post
Here is the 120a w/ 13.5 hw sensored motor. When the motor is not connected to the tranny you can hear the delay
+ YouTube Video
And here is the 60a w/ a tekin 17.5 running unsensored. With more drag (i.e. connected to the tranny) it's more noticeable. Then when the car is on the track it's really noticeable.
+ YouTube Video
each video demonstrates starting the throttle just above zero and there is no delay to full throttle. they each demo going from zero throttle to full throttle where there is delay.
I hope someone has offered to help you with this problem it seems this may be fixed by adjusting the expo on your throttle ? have you ever tried that?
Dan
-Team SIC-
-Team WnB-
B4.1 worlds
*LRP* Rev-Tech* Reedy*
Warehouse 3 The Best indoor RC track in Phoenix! www.Whouse3.com
Dan1977 is offline   Reply With Quote
Old 06-22-2012, 12:43 PM   #9412
RC MARKET's Avatar
Where had old ver. Firmware download ?
RC MARKET is offline   Reply With Quote
Old 06-24-2012, 01:33 AM   #9413
CFR
CFR's Avatar
XERUN-120A V3
running one on 1s (using booster) with 10.5 using Thunder Power cells & motor
got the top end but struggling to get the bottom end to have some punch
suggest some settings for the bottom end please
CFR is offline   Reply With Quote
Old 06-24-2012, 04:09 AM   #9414
ScottyTC4NZ's Avatar
Send a message via MSN to ScottyTC4NZ
Default Setup with s/p 3.0 13.5t motor and a h/w v3 esc
Hey Guys,
Looking for a setup for V3 ESC with 13.5t SP V3.0 motor, open timing
Thans
Jamie Scott
Onroad Race Director
O.R.C.C.C
Titan ARC R10 2013 / Blitz / Sweep / Team Titan
Titan ARC R10 Upgrade / Blitz / Sweep / Team Titan
ScottyTC4NZ is offline   Reply With Quote
Old 06-24-2012, 12:02 PM   #9415
Hello! I have an Ez-Run 150a esc, and a Hobbywing 4074SL motor. Running on 4s, the motor gets *hot* after about 15 minutes flat out. I've measured 180 degrees, and I'm sure it's been even hotter than that.
If I lower the timing (default is 15 I think), will that reduce the heat? I'd try it myself to see, but it's raining, lol. Thanks for any help!
DudeInMyrtleBch is offline   Reply With Quote
Old 06-24-2012, 02:55 PM   #9416
Hi, has anyone had their v2.1 120a esc repaired before? I suspect that I,ve blown a output transistor. The bec still works & I can still change settings & change firmware. It just wont drive the motor any more. This happened after a crash, in which one of the motor leads came off & an Alloy wheel got wedged on top of the motor connections! I'm hoping it can be repaired at a reasonable cost??? Or is it scrap???
whizbang is offline   Reply With Quote
Old 06-25-2012, 12:25 AM   #9417
Hey Guys,
Looking for a setup for V3 ESC with 13.5t SP V3.0 motor, open timing.
Long flowing track with 65metres (214ft) straight.
Jamie Scott
O.R.C.C.C
Old 06-25-2012, 01:19 AM   #9418
sizheng's Avatar
Originally Posted by ScottyTC4NZ View Post
Hey Guys,
FDR 5.5 , MOTOR FAN IS A MUST.
MOTOR : SP MMM 13.5T ENDBELL TIMING:10 DEGREE
Item Programmable Items SP MMM 13.5T
1A Running Mode Running Mode For/Brake
1B Reverse Speed Reverse Speed 25%
1C Voltage Cutoff Voltage Cutoff 6.0
1D ESC Overheat Protection ESC Overheat 125 ℃
1E Motor Overheat Protection Motor Overheat 125 ℃
2A Punch Rate Control Punch Rate Switch Point PR SW Point 50%
2B 1st Stage Punch Rate 1st Punch Rate 30
2C 2nd Stage Punch Rate 2nd Punch Rate 30
2D Throttle Input Curve TH Curve linear
3A Drag Brake Drag Brake 0%
3B Brake Strength Brake Strength 50%
3C Initial Brake Initial Brake =drag brake
3D Brake Rate Control Brake Rate Switch Point BR SW Point 50%
3E 1st Stage Brake Rate 1st Brake Rate 20
3F 2nd Stage Brake Rate 2nd Brake Rate 20
3G Brake Input Curve Brake Curve linear
4A Boost Boost Timing Boost Timing 42Deg
4B Boost Start RPM
BT Start RPM 1500
4C Boost End RPM BT End RPM 17500
4D Boost Slope BT Slope Linear
4E Boost Controlled by Throttle BT By TH Yes
5A Turbo Turbo Timing Turbo Timing 22 Deg
5B Turbo Activation Method TT Activation Full TH
5C Full Throttle Delay (sec.) Full TH Delay 0.15
5D Turbo Start RPM TT Start RPM 19000
5E Turbo Engage slope (deg/0.1sec)
TT Eng Slope 24
5F Turbo Disengage slope (deg/0.1sec)
TT DEng Slope 18
TEAMHOBBYWING CHINA
sizheng is offline   Reply With Quote
Old 06-25-2012, 01:32 AM   #9419
malcnz's Avatar
4B Boost Start RPM
BT Start RPM 1500
TT Eng Slope 24
TT DEng Slope 18
Cheers...would you run full(20) degrees timing on motor?
SCHUMACHER MI5 EVO/TEAM POWERS/SANWA/DX4R PRO.
SERPENT F110/TEAMPOWERS 21.5.
LOSI 22 2.0/TEAM POWERS 8.5
malcnz is offline   Reply With Quote
Old 06-25-2012, 01:54 AM   #9420
Hi Guys
I have received a fair few emails about the v3 not connecting with the pc and the programming lcd box and found that all were connecting through the rx port and not the programming port which is also a spare motor fan output.
The programming port for the v3 is differen to the rx port we no longer program the new products like the sct pro and he v3 via the rx port but its own programming port labelled PRG/FAN
please read the manual guys that's What i'ts there for .
thank you for your time
