Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree5Likes
Old 06-17-2012, 03:43 AM   #9316
Barry_Hughes's Avatar
Originally Posted by jford View Post
My program box is showing all sqaures across screen and the program i downloaded is very slow and I dont think its working properly
Have you downloaded the correct program?
As has been said many times V3 software does not work on the V2 ESC's, perhaps this is what is happening.
Built it !
Raced it !
Wrecked it !
Barry_Hughes is offline   Reply With Quote
Old 06-17-2012, 03:50 AM   #9317
MrRolla's Avatar
Trader Rating: 29 (100%+)
the new 612 software that was mentioned a few pages back is this for the V3's or V2's?
cheers
MrRolla is offline   Reply With Quote
Old 06-17-2012, 10:47 AM   #9318
SlideMasteR's Avatar
612 is the USb Link version for the v3's
Xray T4 15' - Hobbywing V3.1 ESC - Reedy Modified Motors - Thunder Power Batteries - Protoform - Much More
SlideMasteR is offline   Reply With Quote
Old 06-17-2012, 02:19 PM   #9319
Default trouble V3
hi i have a v3 for 2 month now
today i had trouble with it
i started having trouble turning the car off
then it shut down while racing
now it's not starting anymore
the built in micro switch gives the pulse (power the servo and the fan)
but it's not holding
wonder if it's sofware related as the switch gives the pulse
hope somebody can help me
regards
closs is offline   Reply With Quote
Old 06-17-2012, 08:42 PM   #9320
murfy's Avatar
Trader Rating: 9 (92%+)
Angelo,
Do you have or anyone at HW have a blank downloadable setup sheet for the v3?
Justin Murphy
Team Xray | Hudy | Hobbywing | Sanwa
murfy is offline   Reply With Quote
Old 06-17-2012, 10:52 PM   #9321
Hi, I currently have a 120a 1s in my 12th and the LCD programmer and will pick up a V3 in a few weeks time for my TC. Just wondering if the same programming box could be used or should I pick up another. What I want to know is if it's possible to use one programmer for both to update and change setting or it's easier to have one for each version of the esc?
amuse is offline   Reply With Quote
Old 06-17-2012, 11:55 PM   #9322
RasCalDK's Avatar
Originally Posted by murfy View Post
Angelo,
It's build into the USB link software, I actually mentioned it some pages ago.
Under "file" then "print settings", this will generate a pdf with the current settings you have in the USB link software, you can also add notes.
Rasmus T. Callesen - Denmark
Serpent S411 - Serpent.com/2-speed.de
Hobbywing Xerun V3 and Thunder Power Z3R motors - ToniSport
RasCalDK is offline   Reply With Quote
Old 06-18-2012, 12:26 AM   #9323
Send a message via ICQ to vitomon Send a message via Skype™ to vitomon
Default first roll out v3
hi guys, had the first roll out yesterday with the v3 and a 4.5t thunderpower motor.
i used the setup which was posted a few pages back from the titc. i turned down the turbo from 30 to 20 deg just to be on the safe side, and had 10deg timing on the motor itself. fdr 8.0. i also disabled the "boost controlled by throttle"-function.
speedo worked super smooth, no glitches no nothing. it was a very hot day with temperatures reaching 34deg (air) and 60deg track. after a 5 min run the motor had roughly 85deg. which is ok i guess.
just one question: how do i get a more softer feel in the lower rpm band (kinda like expo i guess but on the speedo).
good speedo. worked flawlessly even in high temperatures. as soon as you have the settings sorted you are good to go. thx angelo for the help with settings which are posted a few pages back.
Yokomo BD7 -- Hobbywing v3 -- Sanwa M11x
May the grip be with you ... always!
vitomon is offline   Reply With Quote
Old 06-18-2012, 12:38 AM   #9324
murfy's Avatar
Thanks mate.
Also where can I find what this v3.1 update include....what's different.
Justin Murphy
Old 06-18-2012, 01:59 AM   #9325
Born2Run's Avatar
Originally Posted by Born2Run View Post
http://shopping.rcmodel.hk/product_i...ducts_id=19502
I thought V3 would not available on HK market at least for 2012.
http://rcmarket.com.hk/product_info....ducts_id=13471
Good for us.
Whatever
Born2Run is offline   Reply With Quote
Old 06-18-2012, 04:43 AM   #9326
COBRARACING's Avatar
good luck buying one from there.
Email : teamcobraracing@gmail.com or ae@hobbywing.com
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Old 06-18-2012, 04:46 AM   #9327
For the 150amp and the 80 amp 1/8th scale escs i recomnend you guys when running a 2 s lipo you also run a battery for the bec as the bec with a 2 cell the voltsge drop is to large causing problems with the radio .or jyst run a 3s and above.
Old 06-18-2012, 07:19 AM   #9328
sizheng's Avatar
For the case "strange drag brake feel", please tell me what transmitter you are using?
We find similar issue when using the new KO EX-1, the neutral range is a little differnt. causing this problem.
Will research the others.
TEAMHOBBYWING CHINA
sizheng is offline   Reply With Quote
Old 06-18-2012, 07:22 AM   #9329
defcone's Avatar
Trader Rating: 15 (100%+)
MT4
defcone is offline   Reply With Quote
Old 06-18-2012, 07:23 AM   #9330
sizheng's Avatar
For STOCK racing with BOOST and TURBO, suggest setting for ITEM 5F (turbo DEng) is 18 or 24. (18 for staright +sweeper, 24 for straight + u turn)
TEAMHOBBYWING CHINA
