Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree5Likes
Old 07-31-2010, 10:50 PM   #916
TeamWTF's Avatar
Well today Rod M and myself both ran the hobbywing speedies and neither of us had issues. Both very quick, he was using a Keyance and i ran a novak (Both 17.5) so i guess since changing motor its has been ok.
I dont know what the duo's timing is set at internally. I know you can adjust it to 'zero' but you never really know what the manufacturer is doing.
I had this problem with a duo2 10.5... so i took the timing off the endbell and went up 2 teeth on my pinion. I was running just as fast but had no issues with cutting out. As said before, HW dont seem to like a lot of OVERALL TIMING, not just software driven, but physical motor timing also.
My 2c
T.O.P. Racing Australia www.topracing.net.au
TeamWTF is offline   Reply With Quote
Old 08-01-2010, 04:59 AM   #917
Benzaah's Avatar
Trader Rating: 21 (96%+)
I played with my V2.1 a lot again today trying to find a nice balance between speed and drive ability.I was fighting car set up all day as it was damp and windy early but still came away with the win after some good fights in the finals. I ended up at the following.
Duo1 17.5 middle hole timing
drrs 2
boost timing 15*
turbo timing 3*
start 6000
ramp -3
delay 0.3
FDR 5.1
temps 40c ish
In testing afterwards i went even quicker with the following.
drrs 2
boost timing 12*
turbo timing 4*
start 6000
ramp -2
delay 0.1
FDR 4.6
Could probably add more turbo or more pinion as only temped at 55c after 6 minutes
AERCCC - ARCR - RRCSA
Adelaide RC
Walter Rc Hobby
Benzaah is offline   Reply With Quote
Old 08-01-2010, 05:13 AM   #918
Rod M's Avatar
My 2c
yes I used the Keyence 17.5 all day with out issue (3 practice runs and 4 heats)
I am still curious as to what is wrong with those motors then?
TOPRACING.NET.AU Australian Importer of:
T.O.P. Tokyo Hobbies Optional Parts,
Team Trinity , BL Motors and Tyre compound
Team Tekin , ESC's, motors,
Elangears, Chargers,
Rod M is offline   Reply With Quote
Old 08-01-2010, 05:41 PM   #919
COBRARACING's Avatar
From what i know hobbywing has walked away from faigo who make the duo and now make the motors through leopard without any issues .
I also know MMH from shanghai china make some really top quality all handmade motors .
From what i have heard there are some issues with some of the those duo's and who knows whats really internally in those motors on a mass production line .
Ive seen many motors state very high kv ratings with more turns but doing the math just doesnt work out so i find it hard to believe and very strange at the same time .
Email : teamcobraracing@gmail.com or ae@hobbywing.com
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Old 08-01-2010, 05:42 PM   #920
2 weeks time we will have some more little patch files for some more updates .
Old 08-01-2010, 08:20 PM   #921
Darrin70's Avatar
What are the benefits in running the 120amp over the 60 amp?.... Will you have less temps with the 60amp and the same performance? I run the 120a and get abit high of temps.. My 17.5 class you have to be on the edge or your losing...
HYPERHOBBIES
YOKOMO
SKYRC
SWEEP RACING
SMC
Darrin70 is offline   Reply With Quote
Old 08-01-2010, 09:02 PM   #922
TeamWTF's Avatar
i would expect the 120a to run cooler then the 60a for a given motor
Old 08-01-2010, 11:53 PM   #923
Why ??
I wouldnt expect there to be much difference, we are talking heat caused by fet resistance only. (??)
1101 is offline   Reply With Quote
Old 08-02-2010, 02:45 AM   #924
I have 120a and 60a and i don't see temp diference used with 10.5T motor.
But as wires are 14awg on 60a esc, and diferent capacitator board, can i see some improvement if i instal 12awg wire and capacitor from 120a version or super capacitors like TOP or speed passion?
tomislav is offline   Reply With Quote
Old 08-02-2010, 02:47 PM   #925
vazzo's Avatar
Trader Rating: 100 (100%+)
Is anyone here who runs 10.5 starting their RPM around 9000??
Cheers
Adrian
Gone riding, cya.........
vazzo is offline   Reply With Quote
Old 08-03-2010, 01:41 AM   #926
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
Cheers
Adrian
9000rpm? i dnt think so
Give the best while u can !
kschu is offline   Reply With Quote
Old 08-03-2010, 02:04 AM   #927
3500 rpm to 4500 rpm
Old 08-03-2010, 03:08 AM   #928
Cheers
Adrian
It seems to labour if you go a too high start RPM. And it generates too much heat if you put it too low. 6000 seemsriht for most scenarios
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 08-03-2010, 03:52 AM   #929
ali_g's Avatar
what about for 4.5 / 5.5 motor?
can we set it at 9000? coz currently im on 15000
☆ JU.C RACING ☆
https://www.facebook.com/Ju.Cracing
ali_g is offline   Reply With Quote
Old 08-03-2010, 04:18 AM   #930
TRF4evr's Avatar
what FDR should start with?
TRF - HUDY - Much more - Ride
Proamp Lipo - Speedpassion
www.feralbatteries.com
TRF4evr is offline   Reply With Quote
