Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree5Likes
Old 06-13-2012, 12:35 PM   #9256
Shop Owner
nnick's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to nnick Send a message via MSN to nnick Send a message via Yahoo to nnick Send a message via Skype™ to nnick
Where can I find an empty modifiable setup sheet?
Nikolakopoulos Nick
RC RING
The #1 source for all your electric needs www.rcring.eu
Enjoy RCing....
R/C Tech #82
IRT #123
Don't practice until you get it right. Practice until you can't get it wrong
nnick is offline   Reply With Quote
Old 06-13-2012, 11:32 PM   #9257
Originally Posted by syndr0me View Post
Bump.
Any comment on the drag brake issue before I sell the V3 and start telling everybody it sucks?
Syndrome I am no pro but what I have tried is to set Turbo de acc to instant de acceleration and also set my TH trim like 2 clicks forward this seems to help. Done this many times when I have to much drag when I'm on driver stand and to lazy to stop and set it. Lol
This is with a 13.5t 3racing motor with loads of boost, I need to play around abit more could get it even better and I'm sure if its a problem HW will address it but so far I am loving this speedo.
Hope this helps.
charl mac is offline   Reply With Quote
Old 06-14-2012, 12:01 AM   #9258
RasCalDK's Avatar
It's build into the HobbyWing USB link software.
Press "file" and then "print settings", then it will geneater a PDF with the current settings in the USB link software.
Rasmus T. Callesen - Denmark
Serpent S411 - Serpent.com/2-speed.de
Hobbywing Xerun V3 and Thunder Power Z3R motors - ToniSport
RasCalDK is offline   Reply With Quote
Old 06-14-2012, 01:22 AM   #9259
TryHard's Avatar
Bump.
Syn, where is it happening mainly? Coming off the throttle off the main straight, or everywhere? Boost or blinky (i'm being too lazy to read back through, long day )
Reason I ask is you can play with the turbo DEng setting to make it smoother, too quick can make it fell like it drops an anchor (IMO). Also, and I haven't had a chance to check this more recently, but on my early unit (pre-prod) there was an occasional issue that the volta protect was cutting in sometimes when I came off full throttle, dropped outta turbo, then punched it back... would stutter a bit on re-applying when the pack got later into a run.. since then, I never bother with the low volt cut-off, might be worth backing that setting down (or setting it to a manual value rather than auto).
One other thing... what size rotor are you running in the motor? that'll have a big effect on drag brake...
Could even be a transmitter setting issue (dodgy pot on the throttle... not impossible, as I had my Sanwa Super Exes have this issue once that played havoc with the throttle until I twigged what was happening).
Don't give up on it yet, sure we can sort you out...
Ed
| THard.co.uk | Xray | MuchMore |
Old 06-14-2012, 01:54 AM   #9260
Shop Owner
nnick's Avatar
Oh nice! Thank you
Nikolakopoulos Nick
RC RING
Enjoy RCing....
R/C Tech #82
IRT #123
Old 06-14-2012, 02:38 AM   #9261
defcone's Avatar
Trader Rating: 15 (100%+)
Ed
Running a 17.5t with 6diseng, it feels to have like 20% drag brake when I have 0, lipo cut is off, esc on 125 deg, motor cut off.
defcone is offline   Reply With Quote
Old 06-14-2012, 02:41 AM   #9262
After using the latest usb link software on my extreme stock esc, the for/brk/rev no longer has reverse using any fw, fwd/rev works, fwd/brk works, fwd/brk/rev works but only fwd/brk.
Any helpful ideas please?
Kev
ManxPlumber is offline   Reply With Quote
Old 06-14-2012, 03:53 AM   #9263
SlideMasteR's Avatar
As far as i know you should be using 1.64 for the extreme stock
I see 612 has been released , btw it would be nice if they included the database release date in the 'help/about' tab of the software,
can anyone comment on the fixes and or changes in 612 ?
Xray T4 15' - Hobbywing V3.1 ESC - Reedy Modified Motors - Thunder Power Batteries - Protoform - Much More
SlideMasteR is offline   Reply With Quote
Old 06-14-2012, 04:53 AM   #9264
pchroma24's Avatar
Trader Rating: 79 (100%+)
Apologies if this was asked prior... It seems the software download links on the Hobbywing site are inoperable... any info on this or a different link maybe?
Thanks in advance ...
If you can't explain it simply, you don't understand it well enough... Einstein
pchroma24 is offline   Reply With Quote
Old 06-14-2012, 06:09 AM   #9265
Check post 9246 on page 617 for links
Tony G is offline   Reply With Quote
Old 06-14-2012, 06:17 AM   #9266
artwork's Avatar
Trader Rating: 62 (100%+)
Ed
Ed
I won't speak for syn, but I notice it every where are we are both running the esc in blinky. It applies load in a very weird way and slows the car down but it does not feel very linear. Even with very little drag brake the car seems to slow down too much. It is not a setting or compnent outside the V3. It is some setting or design within the V3 itself. The V3 is a very nice speed control, but if it feels like this by design I will get rid of it. I have hit more stuff since I have had the V3 in my car then I have in the last few years and that seriously concerns me.
Sanwa | R1 Wurks | Avid | 2mm Designs
artwork is offline   Reply With Quote
Old 06-14-2012, 07:37 AM   #9267
AGNO's Avatar
I am using the V3 blinky mode touring class 13.5, but I have not noticed any problem with drag brake, the drag brake control is much better and more accurate than the Xtreme and V2, also the power of brake of V3 is great also on blinky mode.
Using Speedpassion, Hobbywing e GM motors, with this motors any problem of drag brake.
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Old 06-14-2012, 07:59 AM   #9268
artwork's Avatar
What version of the software are you running on the speedo?
Old 06-14-2012, 08:05 AM   #9269
syndr0me's Avatar
Trader Rating: 32 (100%+)
Yeah, "blinky" mode in sedan. With a Hacker and Thunder Power 13.5, both slow down too much everywhere even with zero drag brake and make the car get on the nose. It's a very unnatural feel.
syndr0me is offline   Reply With Quote
Old 06-14-2012, 08:16 AM   #9270
Trader Rating: 27 (100%+)
Kev
Possibly recalibrate the fwd/rev/brake settings on the esc? That happened to me when I didn't have it programmed correctly.
hyujmn is offline   Reply With Quote
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
