Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree5Likes
Old 06-05-2012, 05:32 PM   #9196
Fabricio's Avatar
Send a message via MSN to Fabricio Send a message via Skype™ to Fabricio
Originally Posted by SlideMasteR View Post
agreed enough now, do as you were told to and stop spammimg this site
+1
ARC R10 - ORCA - SANWA - EPIC
Fabricio is offline   Reply With Quote
Old 06-05-2012, 08:24 PM   #9197
Fast410's Avatar
Trader Rating: 40 (100%+)
than leave me alone so i will stop,i sent angelo what he wanted we will see if he is going to do what he says this time, if he does i will leave your thread...
you girls must be some racers like to see you on the tracks i run on with your set ups,somebody would be getting a spanking for sure!!!!!!!!!!
GRUDGE RACING $$ PROMOD KUSTOMZ real race car fabrication and custom painting -airbrushing CHICAGO WISEGUYS RACE CIRCUT-1/4 mile Door Slammers @ 200mph plus
Fast410 is offline   Reply With Quote
Old 06-05-2012, 11:01 PM   #9198
COBRARACING's Avatar
I have given you the information for crc now send it back to frank and he will sort it i have notified what he needs to do .
Now enough enjoy the thread and post useful info or give it a rest and please leave as there are people on here who need info .
Email : teamcobraracing@gmail.com or ae@hobbywing.com
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Old 06-06-2012, 01:29 AM   #9199
Originally Posted by matiworld View Post
Ejector Blades Manufacturers
"MATI is truly a one-stop shopping source for the molding and mold making industries, offering sleeves, ejector sleeves, Ejector blade, Ejector pin & Punches in India."
Please stop spamming our thread .
Old 06-06-2012, 01:36 AM   #9200
Send a message via ICQ to vitomon Send a message via Skype™ to vitomon
Default gearing
hi guys, just bought a new v3. any tips on gearing a 4.5T thunderpower with 2s lipo?
also any changes need to be made to the pre programmed modified settings?
thx for help
Infinity -- Orion ESC -- Sanwa M11x
May the grip be with you ... always!
vitomon is offline   Reply With Quote
Old 06-06-2012, 02:52 AM   #9201
CraigM's Avatar
Trader Rating: 34 (100%+)
thx for help
Depends on the track but 8.0 FDR should put you in the ballpark. Mod settings should be a good start, learn what the settings do and tune from there
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 06-06-2012, 04:53 AM   #9202
Vitomon - as CraigM stated, gearing 8,0 is correct as start, but as always it depends on the track, you race on. We also now use the V3 with 4,5 T Thunderpower motor. On a big outdoor tarmac track we started with 8,3 but ended up with 7,71 - and using timing and boost. We read out the rpm to be about 67000 rpms = about 105 km/h.
Next practice we will try out the Thundepower 4,0 T. We will then start gearing about 8,3 and lowering the timing and boost.
Sponsor: Team Serpent, 2-Speed RC, ToniSport, Allans Koereskole
Modified: Serpent S411 Eryx 4.0, LRP Flow, LRP X20 4,5 T, Sanwa M11X
Superstock: Serpent S411 Eryx 4.0. LRP Flow, LRP X20 13,5 T, Hitec Lynx 4S
BCDK is offline   Reply With Quote
Old 06-06-2012, 06:07 AM   #9203
SlideMasteR's Avatar
what sort of numbers are you putting into the 4.5 ? boost and turbo ?
Xray T4 15' - Hobbywing V3.1 ESC - Reedy Modified Motors - Thunder Power Batteries - Protoform - Much More
SlideMasteR is offline   Reply With Quote
Old 06-06-2012, 06:59 AM   #9204
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
I run 10 boost, 18 turbo. 15 and 15 is also a very common combo
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 06-06-2012, 03:45 PM   #9205
what end bell timing are you running on your thunder power motors
t3 racer is offline   Reply With Quote
Old 06-06-2012, 06:51 PM   #9206
20d. You dont need any more, my car is already too fast. You can use 15 on some tracks
Antoni Caretti
Old 06-06-2012, 09:26 PM   #9207
thx for help
I have attached Justins setup for 4.5T
Old 06-07-2012, 12:03 AM   #9208
Thank you Cobra for posting the above info,
what suggestions or tweaks would you make to this setup for running a 7.5 Reedy ?
Our track is 40m x 25m quite flowing
Old 06-07-2012, 06:22 AM   #9209
Trader Rating: 30 (97%+)
In the market for a new esc, just came from a lrp sxx tc v2, and tekin rs pro, is the new v3 esc a better esc then the other two, also considering the orca vx any info would be apperciated thanks
zaraz is offline   Reply With Quote
Old 06-07-2012, 07:48 AM   #9210
macdude's Avatar
I have not run the newer v3 esc so I can not comment on the smoothness. It does however seem like it has way more programable features than any other ESC right now. This can be good and bad as it raises the level of complexity to set it up. I have also run the older Orca MKII ESC and it is the smoothest ESC that I have ever run. Better than the LRP, and way way better than Tekin. The new VX is almost identical in set up to the older MKII so it is really easy to set up. It is not as complex as the V3 HW so that makes it a little better choice in my opinion. Both offer track side adjustment with a program box.
I would ask around your local track and actually drive one to make the choice. The only limit for me at the moment is there is not a good importer in the US for ORCA, where as HW has CRC and they are all about helping you out in the US.
KO Eurus / Orca / MMP / XB2 / 22-4 /
macdude is offline   Reply With Quote
