Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree2Likes
Old 05-17-2012, 05:00 AM   #8986
NR
NR's Avatar
Trader Rating: 52 (100%+)
Originally Posted by TryHard View Post
I was measuring the esc temp with a metallic cases temp gun... Touched the pins with the esc on, and also touched the case... There goes was a short. Woulda been fine if I hadn't left the esc on, or had a plug /cover on the pins. I believe all new v3's are coming with a cover.
HiH
Ed
Ouch
Thanks for the info, I will keep away any metallic cases or better still get something to cover the pins
NR is offline   Reply With Quote
Old 05-17-2012, 05:31 AM   #8987
cyanyde's Avatar
Originally Posted by Benzaah View Post
Posts like this give me the S$*#'S. Is it hobbywings fault that the Canadian government taxes you, its citizen the way it does? Get over it. Its a quality product that is worth the price you have to pay. Yes that is more than the average racer but thats not hobbywings fault.
Chill mate. His post didn't sound like he was blaming HW.
/Adrian.
RC FB Pages Subscribed:
facebook.com/EPBuggy
facebook.com/AllStarChampionship
cyanyde is offline   Reply With Quote
Old 05-17-2012, 06:54 AM   #8988
banquer's Avatar
On the switch thing, sounds like its shorted out on the case, and fried the switch... Thats what happened to me with mine, exact same symptoms. Unfortunately, will need to go back to HW to be fixed.
Hih
Ed
Hi Ed.
I think this isn't my problem because, the swith works ok normally. Only about this circustances (hot and after a 5 minutes of running), don't work.
After a few minutes more, the switch works ok.
Any ideas?
Cheers.
Tamiya 419
Tamiya TRF 101
MuchMore Fleta Pro - Euro - Fleta 10.5-21.5
Sanwa M12 - RX-471
http://www.agaerc.com/
banquer is offline   Reply With Quote
Old 05-17-2012, 08:30 AM   #8989
racer x 1's Avatar
Trader Rating: 27 (100%+)
Does anyone have pictures of the 1s hobbywing mounted in 1/12 pan car? Hopefully the r5???
Matt Bell
Mugen MRX5 Ae R5.2 X6^3 M11x All powered by Speedtech Rc
racer x 1 is offline   Reply With Quote
Old 05-17-2012, 08:31 AM   #8990
whityboy's Avatar
Today the first test with the v3 and I love it but I had several times that the power disappeared for a few seconds, as if the engine went to sensorless mode.
just seconds after the power was back there.
any idea how this could come.
Also if I temp the ESC th temp is 35 but on the data record reads a max temp of 120.
I drive a duo 3 boosted.
Also the programe 7 (17.5)does not work.
If I give a little gas, start the engine at full throttle.
anyone have any idea
VBC support team manager EU
whityboy is offline   Reply With Quote
Old 05-17-2012, 08:46 AM   #8991
lip
Chill man...
Just speaking about my experience in obtaining this since I'm in Canada and no one sells it locally in Canada.
lip is offline   Reply With Quote
Old 05-17-2012, 08:56 AM   #8992
syndr0me's Avatar
Trader Rating: 32 (100%+)
I must have missed it in the manual, but you can power the ESC off by holding the brake for 6 seconds? Is this the default?
syndr0me is offline   Reply With Quote
Old 05-17-2012, 09:29 AM   #8993
whityboy's Avatar
Yes if you hold full break for 6 sec the ESC shuts off. (If its no to hot )
Old 05-17-2012, 10:37 AM   #8994
lip
Guys, my hobbywing motor has the cool solder posts on the back...with the other motors I've had that have these I don't remember these posts being able to spin around....I can't see how they are connected as they are shrink wrapped....when you solder them I'm guessing it "locks" that portion in place and it only spins around for you to be able to centre the wire?
Thanks.
Old 05-17-2012, 10:53 AM   #8995
I've just downloaded the USB link software v3.1 but I can't extract the files. Winrar keeps saying the file is corrupt. Has anyone managed to load this yet?
Thanks Michael
Schumacher Mi5evo-HW V3.1 - HW V10 13.5 dry car
Schumacher Mi5evo-HW Extreme stock-HW 13.5 wet car
Schumacher SSGT - HW V3.1 stock spec - HW V10 13.5
Racing-cars.com
MWarren is offline   Reply With Quote
Old 05-17-2012, 10:56 AM   #8996
Thanks.
The shrink wrapped piece is a bullet connector which should pull off.
Racing-cars.com
Old 05-17-2012, 01:46 PM   #8997
Thanks Michael
+1
mcdoogle is offline   Reply With Quote
Old 05-17-2012, 02:05 PM   #8998
lip
duhhhhhh
What an idiot I am....I've had a motor with these before and never realized they were bullet connectors.....
Anyone have experience with the hobbywing motors...
Old 05-17-2012, 03:05 PM   #8999
Thanks Michael
+2
xraydad is offline   Reply With Quote
Old 05-17-2012, 03:15 PM   #9000
hanulec's Avatar
Trader Rating: 23 (100%+)
Can that be disabled?? Or is that a feature?
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
