Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree5Likes
Old 05-03-2012, 06:29 AM   #8851
XSLR8's Avatar
Originally Posted by COBRARACING View Post
Are all the Motors you have used thunder power motors even the new ones ?
Yes they are,both brand new 21.5 Thunder Powers.
Thank you for replying.
VBC Racing Australia.....FUTABA AUSTRALIA.....Volante tires.....WTF Fans.....R.A.B Hobbies....President www.serccc.com.au
XSLR8 is offline   Reply With Quote
Old 05-03-2012, 06:34 AM   #8852
COBRARACING's Avatar
Originally Posted by Pattojnr View Post
any news for 150 amp Turbo ? much longer and ill off load my gear and go to more cells.
We have tested turbo functions on the 150 amp and the amount of frequency noise from the motor causes the esc to go from sensored to sensorless .
Motor noise is a major issue at the moment and to be honest i can't see michael releasing any software that will not work and cause major reliability issues.
To produce turbo even with small settings we feel that the software at the moment has more than enough power .many do tell me we need to tone it down not tone it up .
Email : [email protected] or [email protected]
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Old 05-03-2012, 06:37 AM   #8853
Pattojnr's Avatar
Trader Rating: 19 (100%+)
again this is for onroad 1/8th ! we need more speed. thats fine, ill off load my HW stuff.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 05-03-2012, 06:41 AM   #8854
XSLR8's Avatar
Both motors cogg even with the sensor lead unplugged !
The only way to stop it is to retard the timing on the motor to less than zero.
Old 05-03-2012, 06:46 AM   #8855
Craig W's Avatar
Send a message via MSN to Craig W Send a message via Skype™ to Craig W
Are all the Motors you have used thunder power motors even the new ones ?The thunder power motors have end bell adjustment from 0 degree to 50 degree .We need your settings before we can help you esc and motor.
thunder power need run 25 on motor
Orca www.ChubbiesCarShack.co.uk TDX SMC RC Airbrush Fundecal
Craig W is offline   Reply With Quote
Old 05-03-2012, 06:51 AM   #8856
XSLR8's Avatar
Anything over 0 and they cogg badly,settings I have used as a start is the pre-set 17.5 v3 settings with FDR of 6.1
Old 05-03-2012, 08:22 AM   #8857
macdude's Avatar
Add a bigger gear or more cells. I don't know your situation, but there has never been a time when the larger motors could be boosted. In most cases the loss in efficiency is much greater than the gain in speed. I have been running a T8 motor in electric offroad with a MMP for a couple of seasons, and it has never been wanting for power. I can understand wanting more top end, but boosting does not work well with large sensored motors. Even the tekin guys don't run in sensored only mode for their large scale stuff. Try a higher KV motor to get more RPM. Or adjust your gearing, and add another cell. Another thing to consider is the physical limitation of RPM on the rotor. Most 4 pole motors are not rated over 80K RPM, so if you are running 6S and a 2600KV motor then you are approaching the physical limit of the motor. If you can't get the gearing to give you enough top speed then add a 2 speed transmission, just like you have to do in nitro. Or 3 speed if the track is really big. Electric is cool because for the most part you don't need to do this, but the RPM range is not unlimited. Adding timing on the smaller motors is possible because it actually adds efficiency and can create more power with only a small amount of loss due to heat. The larger the motor, the more efficient it is and the less power you can get our of it by boosting or adding physical timing to the can. In another thread a couple of engineers where explaining why they don't boost larger motors. But the bottom line is that you don't get anything out of it, just heat, and significantly less run time.
KO Eurus / Orca / MMP / XB2 / 22-4 /
macdude is offline   Reply With Quote
Old 05-03-2012, 09:47 AM   #8858
cyanyde's Avatar
Originally Posted by mcdoogle View Post
Hi, what ttpe of track was it on and what settings did you use ?
Track: Asphalt, med speed, 50ft straight
Motor: LRP X12 13.5 0000 timing insert (27.5 deg)
Fdr: 6.44
Boost: 27deg, 8k-15k, linear.
Turbo: 5deg, 20k rpm, Acc 15/0.1, Dec 18/0.1
Temp: 95deg C (Air temp 36 deg C)
More aggressive settings are possible with more power but I'm not too comfy with the temps.
/Adrian.
RC FB Pages Subscribed:
facebook.com/EPBuggy
facebook.com/AllStarChampionship
cyanyde is offline   Reply With Quote
Old 05-03-2012, 12:14 PM   #8859
whityboy's Avatar
If I update my program box to use whit the V3 can I still use it with my xtreme stock
whityboy is offline   Reply With Quote
Old 05-03-2012, 01:06 PM   #8860
macdude's Avatar
You will only be able to use it as a link with the HW software. It will not work without the computer. The boxes are cheap enough I am just picking up an extra one.
Old 05-03-2012, 01:27 PM   #8861
JRXS_chris's Avatar
Originally Posted by M7H View Post
and is your X12 still alive?
Not tried. Don't get much track time due to there being no tracks near me.
It's survived 120c temps before and consistant 100c temps after 5 min runs. It's a tough old blighter!
JRXS_chris is offline   Reply With Quote
Old 05-03-2012, 04:46 PM   #8862
there is no esc combo on the planet with turbo functions.whatever you buy you will need more speed.run a 6 cell pack.
Old 05-03-2012, 04:49 PM   #8863
have you tried a different motor? meaning brand not wind
Old 05-03-2012, 04:51 PM   #8864
LOW ET's Avatar
Trader Rating: 97 (100%+)
did you try different batteries?
LOW ET is offline   Reply With Quote
Old 05-03-2012, 06:25 PM   #8865
XSLR8's Avatar
Batteries I use are Fantom 6500 which are new and work fine in my 13.5 car with the old speedie.
Have not tried other motor yet,but will so I can work out whether it is esc/motor combo or speed control problems.
Cheers.
