Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree5Likes
Old 04-26-2012, 07:43 PM   #8806
YR4Dude's Avatar
Trader Rating: 44 (100%+)
Originally Posted by brettweir78 View Post
With a booster it should. Like you said just turn off the voltage protection
Originally Posted by COBRARACING View Post
yes run a booster
Thanks.
One more thing, since I'm just running 1s (3.7V) is it okay to run the speedo without the fan?
YR4Dude is offline   Reply With Quote
Old 04-26-2012, 07:55 PM   #8807
sbrewer's Avatar
Trader Rating: 20 (100%+)
Anyone running a TenShock Sc401 with an 80amp? Im going to be running this combo im my Sc10 4x4 Was just looking for thoughts and feed back
- AKA - Team Associated - Dark Side RC Racing - Os Speed - Jc Designs - Futaba - Boca Bearings-
sbrewer is offline   Reply With Quote
Old 04-26-2012, 09:40 PM   #8808
sbrewer's Avatar
Question I just installed a Tenshock sc401 4600 kv in my Sc104x4 took It out for a test run and I have gogging/ shuddering taking of or ar slow speed. I'm running a 80 amp . Any suggestions y or how to fix it?
Old 04-27-2012, 12:26 AM   #8809
COBRARACING's Avatar
does it work without the sensor cable ? if it does then you have issue with the sensor cable or the sensor in the motor itself .Also turn down your punch level and even you might have an issue with a low discharge battery .Many things can be the cause of cogging
Email : [email protected] or [email protected]
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Old 04-27-2012, 01:53 AM   #8810
Darrin70's Avatar
its the serial number on the esc
Just so everyone knows the anti counterfeit number is the actual label on the box.. You just simply scratch the box to have the 20 digit number appear.. When entering the number on the website do not leave any spaces..
HYPERHOBBIES
YOKOMO
SKYRC
SWEEP RACING
SMC
Darrin70 is offline   Reply With Quote
Old 04-27-2012, 08:11 AM   #8811
sbrewer's Avatar
It's a non sensored 4pole 4600 kv motor. I will try updating the Esc software , was running a sensord Novak 5.5 Hv with no problems.
Old 04-27-2012, 08:34 AM   #8812
JRXS_chris's Avatar
I've noticed an increase in the number of people racing in the UK that are whacking the advance timing on the motor right up in 10.5 then adjusting the esc settings to suit. Any one any ideas why racers are going down this route?
JRXS_chris is offline   Reply With Quote
Old 04-27-2012, 09:52 AM   #8813
sbrewer's Avatar
Whats the lates version of usb link software you can use? I was trying to use the usb link v3 bata software is that my problem? lol
Old 04-27-2012, 01:19 PM   #8814
lewis110's Avatar
I believe v1.64
lewis110 is offline   Reply With Quote
Old 04-27-2012, 04:02 PM   #8815
sbrewer's Avatar
Originally Posted by lewis110 View Post
I believe v1.64
Ok thank you.
Old 04-27-2012, 04:14 PM   #8816
Trader Rating: 19 (100%+)
It gives it more initial punch if you run high mechanical timing, with slightly lower gear, say 2 teeth less on pinion, and it allows the motor to spin at a higher top rpm, which means you can add more timing boost and then stretch your boost ramp out really long therefore making the car smoother, I myself prefer to run slightly advanced above neutral, but alot of that depends on the track you run at.
★Randy Banks★
COLD AS ICE is offline   Reply With Quote
Old 04-27-2012, 09:22 PM   #8817
TryHard's Avatar
And to further add to that... Adding motor timing is the only option left when the settings are maxed (boost+turbo), which gains RPM, and hence top speed.. Buts more heat.
HiH
Ed
| THard.co.uk | Xray | MuchMore |
Old 04-27-2012, 10:10 PM   #8818
LOSI123's Avatar
Trader Rating: 63 (100%+)
Is there a online guide available for 930 stock to explain all the settings, mainly about timing "acc" and boost and turbo etc?
also anyone know the true mechanical timing of the xerun stock 540 sensored motors, they dont have adjustable endbell
LOSI123 is offline   Reply With Quote
Old 04-27-2012, 10:44 PM   #8819
HiH
Ed
Thanks Ed! forgot to add that in there
★Randy Banks★
Old 04-27-2012, 10:45 PM   #8820
HiH
Ed
For most people who are starting to tune with dynamic timing however end up with a too small FDR and too much boost too early. The motor spins at insane RPM:s but the car does not really go anywhere.
The most important setting for dynamic timing is your FDR, make sure it is as big as possible, its ok to sacrifice some timing for this. It will also improve your throttle response and make the car easier to drive. Of course the car should be responsive and not sluggish.
Fast drivers can always get away with more timing and bigger FDR. They simply drive the corners better which keeps the RPM higher and when they accelerate out they generate less heat. Its easy to do the last fine tuning for the track and person by increasing the FDR untill the lap times do not improve anymore.
the 3 parameters of adjusting your dynamic timing are:
FDR
total timing per RPM
angular acceleration of the motor (weight of car, drive train, grip levels etc anything that affects how freely the motor can accelerate, avg speed)
angular acceleration is quite static but changes slighty because of track condition, driver, track layout etc.
For the timing you want to adjust it so that you always have the max timing the motor can cope with (but not a single degree too much). This will always give you the best efficiency (less heat). If you have too much it will cook your motor, if you have too little your car will just not go anywhere but always keep it on the lower side. Othervise you might end up cooking your motor later in the day when the traction builds up.
When testing your setups and learning how to play with the settings always take your temps with 1 or 2 minute intervalls. This way your gear will be quite safe and the risk breaking something is quite minimal.
www.EuroRC.com your European webshop for Hobbywing, Xray, Yokomo, Highest, TeamC, Gens Ace, Vampire, Team Associated, TLR and many more.
goos is offline   Reply With Quote
