Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 04-13-2012, 07:19 AM   #8641
Also make sure that you reset your throttle end points (set full throttle, and brake)
www.teamcrc.com, www.teamscreamracing.com, Outlaw RC Motorsports, KO Propo USA, www.crcraceway.com, Dumper's Speedshop, FB/FX Paint. 38.4mm>38mm, 9 degrees does not = Zero end of story. Vice-President of the F1 Pink Flame Posse
dumper is offline   Reply With Quote
Old 04-13-2012, 07:21 AM   #8642
outoforder's Avatar
Trader Rating: 34 (100%+)
On one car I'm using a tacon for now till I can order a xerun motor, and another car exact same settings I'm using the xerun hobbywing 10.5. Thanks for the help guys also where can I download the 3.0 stock
...BASHERS INC.....
Team
Valadez
Hobbies
outoforder is offline   Reply With Quote
Old 04-13-2012, 12:55 PM   #8643
IS falconsekido a good site to buy from? Theres not much on the internet about people buying from them. I contacted them 2x now with no response. Looking for HW SCT Pro in the states.
TamiyaChris is offline   Reply With Quote
Old 04-13-2012, 04:36 PM   #8644
Warren Weaver's Avatar
Trader Rating: 46 (100%+)
yes i received in 3 days my v3 speedcontrol they dont seem to answer emails but the order was fast.
R1 WURKS-AWESOMATIX USA-LRP-TQ WIRE-PROTOTYPE RACING-MCFACTORY MOTORSPORTS-SWEEP RACING-TXDSKINGRAPHIX-HOBMAX-THE RUG-TEAM EZDUZIT
R.I.P. MY FRIEND JDUB MISSED BUT NEVER FORGOTTEN
Warren Weaver is offline   Reply With Quote
Old 04-13-2012, 06:06 PM   #8645
outoforder's Avatar
Originally Posted by TryHard View Post
Ok, first as mentioned, switch to the 930STOCK software, that will give you all the tuning options. What motor are you running?
Next up, try out the following;
FDR; 7.1
DDRS; 9
Initial brake; Drag
Neutral range; 6%
Boost; 40
Turbo open time; 24
Turbo; 24
Turbo delay; 0.2s
Boost Start; 6,000 rpm
Boost ACC; 400 rpm/deg
Try that out, and I guarantee you'll have top end back. Make sure to temp your motor after the first few minutes though, to make sure you don't run into problems.
HiH
Ed
thank you so much, tested this out and man this car is so fast. now i gotta learn to control the speed through the turns, its freaken awesome. what is a good temp for the esc and motor? i was getting 125 with a fan on after 10 min and the motor was running 165-175 after 10 min. using a 7.25 fdr do i go up or down on the fdr?
again thanks so much.
...BASHERS INC.....
Team
Valadez
Hobbies
Old 04-13-2012, 06:23 PM   #8646
lip
they responded once to me but told me since I'm in Canada they would have to email me shipping costs....4 days and 2 emails from me and still no response.
cobra: you need to fix this as crc has hardly any motors and not the one I want and your main rep doesn't respond to emails....i just want to buy your product...it should not be this difficult...im worried now if i di finally get your product but have a problem..
.why not sell through a more reputable place like amain?
lip is offline   Reply With Quote
Old 04-13-2012, 07:09 PM   #8647
lewis110's Avatar
Hobbypartz has just about every combination that you may want.
To the guy looking for a SCT pro esc CRC has them in stock ready to ship. WWW.teamcrc.com
lewis110 is offline   Reply With Quote
Old 04-13-2012, 09:53 PM   #8648
lip
Hobbypartz doesn't have the V3....and cobra basically is relegating them to 3rd class type distribution with little support and only a 90 day warranty....for $220 just for the esc I expect top level support and also top level warranty (not sure I will get top level warranty from hobbywing from the way it sounds but I know hobbypartz sucks on support already....).
Would like to think I could expect Tekin or Castle type support and warranty help if I need it with the V3 but I don't expect it...I'm going into it with low expectations from service support and high expectations from functionality
Old 04-13-2012, 10:07 PM   #8649
Trader Rating: 22 (100%+)
Quite simple don't buy one.
Not everything is given on a silver tray.
bjspinner is offline   Reply With Quote
Old 04-13-2012, 10:28 PM   #8650
When will start the global sales of V3?
Tamyia TRF 417
Team Associated RC8Be
Team Durango DEX410 2010spec
ezh_m5 is offline   Reply With Quote
Old 04-14-2012, 12:22 AM   #8651
TryHard's Avatar
I'm assuming that means F, right? If so, that sounds fine for 10minutes run time. If you are struggling a little, try going to one smaller pinion, that will help to drop temps.
Also, to smooth it out a little, try using the boost start rpm high (maybe 8000), and/or try a longer Boost ACC value (say 500 rpm/).
HiH
Ed
Old 04-14-2012, 07:12 AM   #8652
Seems that the ver3 you can only change the pre set profiles from the lcd box the instruction manual says nothing about setting them from the button
Old 04-14-2012, 07:27 AM   #8653
In Europe they are already available in shops.
Fastfreddy74 is offline   Reply With Quote
Old 04-14-2012, 08:59 AM   #8654
can u run a Hobbywing 6.5 with mod firmware in a Hobbywing Extremestock without frying it!!! Thinking of doing so until my 120a gets here. As the HW Extremestock is rated similar to a 60a Xerun.
Maybe turn down the boost to a minimum?
<Awesomatix A700 EvoII><Highest><Sanwa><Muchmore><Fantom>
<Awesomatix A800a><Hitec><Sanwa><Muchmore><Fantom>
<VBC LightningF><Hitec><Sanwa><Muchmore><Skyrc>
<=Team Autopartner=>
Gillblade is offline   Reply With Quote
Old 04-14-2012, 02:39 PM   #8655
or change to a older non boosted software
Xray T4`16 - Hobbywing - Highest - Sanwa - Gens Ace
Xray XB2 - Hobbywing - Highest - Sanwa - Gens Ace
Bappe is offline   Reply With Quote
