Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 04-09-2012, 03:38 AM   #8596
JAM Racing's Avatar
Originally Posted by HenryC View Post
The local track runs World GT with 13.5 motors, 1S LiPo and ESC blinky mode. I smoked my Tekin last night so I thought I would try a Hobbywing 1S mainly because it has a built in DC/DC booster and some of the other local drivers seem to love it. I installed it today and it works just fine when loaded with either the STOCK or MOD software version. When I loaded the "V3_508_NO timing" sofware (blinky mode), when the ESC is turned on it gives me the 2 beep input voltage warning and the motor will not run. This is with a freshly charged 1S LiPo (double checked and it is at 4.2V). The ESC will not even talk to the program box in order to revert to another software load. I had to hook up a 2S LiPo in order to make any changes. Switch back to the STOCK or MOD software version and everything is OK. Switch back to blinky and same problem. I tried dropping the low voltage cut-off down to 2.6V, same problem. The only way it will work is if I set the low voltage cut-off to Non_protected, which the Hobbywing site recommends not doing with lithium batteries.
Anybody had this same experience? If so, got a solution?
Thanks,
Henry
i dont think hobbywing relised the number of cars that would use blinky and this oversight is supposed to have a fix this week if you read back this is on the forum.
time my friend ..weve been using a stop watch for over 2 months now so it is managable.
run 3 minutes practise and asses the charge required to get back to fully charged not a good fix but its all ive got except a noisy battery alert( aerploane style) hope that help but im sure Cobra will ensure that we get the product support we need
Walters Hobbies for all your racing needs
Serpent 411/ERYX
ORCA BATTERIES
Castle Hill Raceway
The Best in the West
JAM Racing is offline   Reply With Quote
Old 04-09-2012, 03:50 AM   #8597
JAM Racing's Avatar
Default like i said the fix is due soon
Originally Posted by COBRARACING View Post
ill try and get the cut off fixed for the zero timing software blinky as you guys call it this week coming.
due this week
Serpent 411/ERYX
ORCA BATTERIES
Castle Hill Raceway
Old 04-09-2012, 05:19 AM   #8598
COBRARACING's Avatar
Hi Guys
The 508 zero timing for the 1s lipo cut off has been fixed
Please email me at teamcobraracing@gmail.com or ae@hobbywing.com
so i can send you guys the files and give you and how to load the files to your pc .
You must have usb version 1.64 for it to work, this is the new v1.65 usb but the name for now wont change it will still stay as V1.64 its just a fix for the zero timing 1s lipo cut off .we will upgrade the version number soon .
regards Angelo
Email : teamcobraracing@gmail.com or ae@hobbywing.com
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Old 04-09-2012, 06:33 AM   #8599
To fix this you will have to hook the esc up to a 2 cell (7.4v), the programmer box and the pc. Set the voltage cutoff to no protection. Then the esc will work. You will not be able to install software until you do this. After that it will work on a 1 cell without a problem. Even when you get the new software I think this will be necessary the first time.
www.norcarracing.com
NORCAR @ The Gate
old_dude is offline   Reply With Quote
Old 04-09-2012, 07:19 AM   #8600
Warren Weaver's Avatar
Trader Rating: 46 (100%+)
will the new speed control be on the roar list soon?
R1 WURKS-AWESOMATIX USA-LRP-TQ WIRE-PROTOTYPE RACING-MCFACTORY MOTORSPORTS-SWEEP RACING-TXDSKINGRAPHIX-HOBMAX-THE RUG-TEAM EZDUZIT
R.I.P. MY FRIEND JDUB MISSED BUT NEVER FORGOTTEN
Warren Weaver is offline   Reply With Quote
Old 04-09-2012, 08:28 AM   #8601
defcone's Avatar
Trader Rating: 15 (100%+)
With the new firmware, will/are there going to be protection functions in relation to the motor temps that it can log?
defcone is offline   Reply With Quote
Old 04-09-2012, 04:52 PM   #8602
RL.2002's Avatar
Cobra, where i can buy the v3 esc? Was there any distributor for asian country??
the passion of the slide when taking the corner....
http://www.penabai-rcdrifter.blogspot.com/
Kyosho TF-5 drift spec powered by Ezrun 35A + 9t
Tamiya TRF-416X, Tamiya TRF-417
Hobbywing Xerun 120A, Xerun 3.5t, Team Orion 11.5t, Xerun 5.5t
RL.2002 is offline   Reply With Quote
Old 04-09-2012, 07:15 PM   #8603
Default ESC Fan not working
Hi,
i need some help here. I have a XeRun 120A but the fan was sort of melted in the base and popped off. I know the temp was as high as 80C but i had the over-heat protection on, anyways, the fan wasn't working anymore so i put in another identical fan from my other XeRun 120A, now it doesn't spin anymore.
Other than the fan, everything works fine, so is my ESC smoked? any idea how to make the fan spinning again?
thanks!
hugobox2003 is offline   Reply With Quote
Old 04-10-2012, 12:36 AM   #8604
check to see if there is any voltage coming from the fan plug on the esc if there isnt you hav broken something internally. if there is its a broken fan. if its tye esc just wire the fan up to the pos and neg wires to the battery then it will come on when you plug the battery in. hope that makes sense
scytherat is offline   Reply With Quote
Old 04-10-2012, 01:28 AM   #8605
thanks for the reply.
just one more thing, the fan is rated as 5V but the lipo is 7.4v, would there be any damage to the fan?
Old 04-10-2012, 02:09 AM   #8606
The fan rated at 5V can accept more, but the power on the ESC fan port comes from the BEC so between 5V and 6V.
If there isn't power coming from this port now, you should buy a 8.4V fan (wired on the Batt ports on the ESC).
FFred is offline   Reply With Quote
Old 04-10-2012, 09:23 AM   #8607
I am pretty sure the HW ESC fan connector is direct to the battery, and does not go through the BEC.
Shawn68z is offline   Reply With Quote
Old 04-10-2012, 03:21 PM   #8608
lip
CRC: any idea when you will have a bit better of a selection of motors from hobbywing?
Also, will you be offering a discount if you buy a programmer with a motor and a V3?
Cobra: any other places to buy V3 and motor/programmer in North America if CRC doesn't plan on carrying motors soon?
Thanks.
lip is offline   Reply With Quote
Old 04-10-2012, 07:59 PM   #8609
Trader Rating: 35 (100%+)
Default lip
lip, falconsekido.com is the only u.s distributer listed on hw website, there prices are good , and ship fast....
nazman01 is offline   Reply With Quote
Old 04-10-2012, 08:12 PM   #8610
lip
V3 price was high but now they looked like they lowered it....
