Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree5Likes
Old 03-11-2012, 07:15 PM   #8176
Originally Posted by UrabusDenis View Post
I am having big problems with my ESC at the moment and with the nationals coming in 2 weeks help would really be appeciated. I'm using a Hobbywing Xerun 60A with a Nosram 10,5T in Super Stock (boosted). Today at the track in one moment the car just lost power and then regained it after approx. 5 seconds. The power would last for a short while and it would be lost again. It isn't working after that moment. Sounds to me as if the sensor cable is bad but it is almost brand new. I inspected it for damage and I saw nothing. Hopefully the ESC isn't broken. Any ideas?
It can really only be one of two things:
Poor quality batteries that can't handle the current and therefore the receiver is not getting the power. This usually happens at a point in the race where there is serious current drawn. Don't get fooled into thinking LRP has better batteries than anyone else. If you are running your current limit at 9 you may have this problem.
The battery connectors cannot handle the current or are worn and give a bad connection. (very likely the problem)
Mike
ixlr8nz is offline   Reply With Quote
Old 03-11-2012, 07:43 PM   #8177
R3VoLuTiOn's Avatar
Trader Rating: 26 (100%+)
Had my first non club race with this speedo this weekend.
phenomenal performance, runs cool, quick, smooth and has a small case. Not as small as LRP, but for the money, I am super satisfied.
John Tsang 🏁 VBC Racing 🚗 ORCA RC 🚗 GripworksRC 🚗 MotivRC 🚗 GravityRC 🚗 RC America
http://www.facebook.com/VancouverRRR 🏁 http://www.facebook.com/OvergearedRacing
R3VoLuTiOn is offline   Reply With Quote
Old 03-12-2012, 04:55 AM   #8178
Born2Run's Avatar
Try turn off the voltage protection.
Whatever
Born2Run is offline   Reply With Quote
Old 03-12-2012, 04:58 AM   #8179
UrabusDenis's Avatar
Thanks for the suggestions, I'll try with a different sensor wire and also new connectors. Just to make sure if you understand the problem, by 'lost power' I mean that there is no boost&turbo (the car is going, the connection betweem the transmitter and receiver is not lost). Also is it normal for a spark to apper every time I connect the battery with the receiver (happens with the 5300 mAh LRP and not with the 5400 CS), is that a sign that connectors should be changed?
Alpha Plus - alpha-rc.com
JQRacing - eu.jqracing.com
Blue Bird - www.blue-bird-model.com
Boca Bearings - www.bocabearings.com
UrabusDenis is offline   Reply With Quote
Old 03-12-2012, 05:23 AM   #8180
COBRARACING's Avatar
The spark when connecting the pack is normal and different connectors will behave different some spark some dont .nothing to worry about
Email : teamcobraracing@gmail.com or ae@hobbywing.com
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Old 03-12-2012, 08:06 AM   #8181
outoforder's Avatar
Trader Rating: 34 (100%+)
I have a ? Is the boost and turbo effected by the esc you are running? I.e. will a 120amp be better over a 60amp esc?
I'm also considering buying my 5th hobbywing esc and don't know which one of these esc would be better for my onroad 1/10 tc , running asphalt , open esc anything goes only a 10.5 motor limit, and 2 cell lipo limit in the class.
http://www.hobbypartz.com/07e-xerun-...-1s-black.html
Or this one
http://www.hobbypartz.com/07e-c-xerun-120a-sd.html
What is the difference on these 2 escs? Any help would be appreciated.
Also does it matter if I use the led box or the advanced lcd box? Thanks again for any help.
...BASHERS INC.....
Team
Valadez
Hobbies
outoforder is offline   Reply With Quote
Old 03-12-2012, 08:27 AM   #8182
macdude's Avatar
I would check your sensor wire as I believe the ESC will switch to sensorless mode if the sensor signal is lost. If you have a bad sensor wire or board in your motor this could be the cause of the weird power/no power issue. Going from boosted sensored mode to sensorless during a run will seem like you have lost all your boost, because you have when the ESC is in sensorless mode. I have had this happen on another ESC during a race and that is what it turned out to be, a bad sensor board on the motor. What made it hard to track down was that about half the time it worked like normal.
KO Eurus / Orca / MMP / XB2 / 22-4 /
macdude is offline   Reply With Quote
Old 03-12-2012, 08:57 AM   #8183
Slapmaster6000's Avatar
Trader Rating: 16 (100%+)
After a rough boot camp at Dumper's Speed Shop, I entered the racing arena with a basic understanding of this speed control. I soldered up 3 x HW 1S #7002 in my CRC rides for the Emerald City Classic in Seattle this past weekend. 2 in my 13.5 spec 12th scale and 1 in the WGT 10.5 boost. Result: 2 poles, 2 wins. In my roughly 28 years of driving, I have NEVER felt a speed control with this kind of brakes! For the first time I could use proportional brake, applying just what I need the mind racing speed to accurately pin every corner of the speed of boosted 10.5. And the punch!!! Are you kidding me? It was like a soccer ball getting blasted out of the park. This speed control has re-energized my racing enthusiasm. It's a little funky to get used to at the programing side, but anything new has a learning curve. I am simply amazed. Thank you Hobby Wing!
Stay dialed my friends!
www.slapmastertools.com
Team Roche USA
Team Orca orcharc.com
Slapmaster6000 is offline   Reply With Quote
Old 03-12-2012, 09:18 AM   #8184
Originally Posted by Still Bill View Post
Just getting used to the HW120 1S in my WGT and its programming.
Is there a simple sequence of events to follow for plugging it into the 2-in-1 and my laptop. Seems like I am missing something...LOL
Bill
Hey Bill, welcome to the HW!
Make sure your 2in1 is updated. You have to make sure the proper device is selected in the laptop software. Once that is done, do the software upload form the laptop to the 2in1 TWICE. Trust me on this one.
Then you can change the device, hook up the ESC to the 2in1, and then turn on the ESC. I always use a 2S lipo for programming the ESC. It should find the ESC, then do a software upgrade to the ESC. Twice.
If you goto the HW Set up forum, then first post has a link to Cherry2Blost's youtube video.
Remember if running 508 (No Boost) turn off the LVC or it will not work with 1S.
Cheers,
Shawn
Shawn68z is offline   Reply With Quote
Old 03-12-2012, 09:19 AM   #8185
I told you this stuff was top fuel.
3 weeks ago in North Dakota, TQ and win in WGT. TQ and second in 1/12th 13.5 boosted, TQ and third in 17.5 blinky TC, Qual 2nd and finish second in 17.5 blinky 12th scale.
2 weeks ago in Colorado, 4 TQ, 4 wins in WGT, 13.5 and 17.5 12th scale, and 17.5 TC.
This past weekend at the Canadian On Road Nationals, I won WGT, 2nd in boosted 17.5 12th scale and 4th in TC.
Alot of people are taking notice.
www.teamcrc.com, www.teamscreamracing.com, Outlaw RC Motorsports, KO Propo USA, www.crcraceway.com, Dumper's Speedshop, FB/FX Paint. 38.4mm>38mm, 9 degrees does not = Zero end of story. Vice-President of the F1 Pink Flame Posse
dumper is offline   Reply With Quote
Old 03-12-2012, 12:00 PM   #8186
M7H
M7H's Avatar
As Nosram is LRP, which motor are you talking about?
The X12? (Nosram pure?)
If X12, then try the 101224_STOCK firmware for that particular motor.
If X11 then go for the latest firmware.
Also check axial play on rotor, and minimise as much as possible.....
Serpent
M7H is offline   Reply With Quote
Old 03-12-2012, 01:43 PM   #8187
Desperatly need some help. I was an idiot yesterday and connected my esc up wrong way. ESC is ok but teh capacitor pack is dead, Problem i have is no one in the uk has any stock so can i use this
http://demonpowerproducts.co.uk/prod...pacitor-p-5242
Its a speedpassion 4 capacitor bank, looks just like the hobbywing one
scytherat is offline   Reply With Quote
Old 03-12-2012, 01:55 PM   #8188
any news on the v3 esc?
Xray T4`16 - Hobbywing - Highest - Sanwa - Gens Ace
Xray XB2 - Hobbywing - Highest - Sanwa - Gens Ace
Bappe is offline   Reply With Quote
Old 03-12-2012, 01:57 PM   #8189
banquer's Avatar
Go to a Electronic comerce and buy 2200uf 16V capacitor.
Is cheaper.
I'd running my Xerun 120 with it, last two races!
Cheers!
Tamiya 419
Tamiya TRF 101
MuchMore Fleta Pro - Euro - Fleta 10.5-21.5
Sanwa M12 - RX-471
http://www.agaerc.com/
banquer is offline   Reply With Quote
Old 03-12-2012, 02:01 PM   #8190
Trader Rating: 19 (100%+)
Hey Brian, who do i contact about getting one of those super nice HobbyWing t-shirts Nice runs lately!
★Randy Banks★
COLD AS ICE is offline   Reply With Quote
