Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree2Likes
Old 03-02-2012, 01:10 AM   #8071
R3VoLuTiOn's Avatar
Trader Rating: 26 (100%+)
interesting topic....
mine flashes green in 2 blips...
John Tsang 🏁 VBC Racing 🚗 ORCA RC 🚗 GripworksRC 🚗 MotivRC 🚗 GravityRC 🚗 RC America
http://www.facebook.com/VancouverRRR 🏁 http://www.facebook.com/OvergearedRacing
R3VoLuTiOn is offline   Reply With Quote
Old 03-02-2012, 02:21 AM   #8072
millbank's Avatar
Originally Posted by warrenwrench View Post
Hi, I recently purchased a XERUN-120A-1S-SD. I have the zero timing firmware installed and the red LED does not blink, therefore I'm not legal to race. It is advertised to have a legal blinky mode. It also will not work as advertised on 1S with lipo cut out enabled. Anyone have any ideas?
You may need to adjust your throttle trim as it needs to be in exactly neutral to blink. You will need ro re calibrate the speedo to your handset. Lipo cut off does not work at the moment on 1s, being rectified by hobbywing.
Xray T2009 / hobbywing v3 120amp /LRP x12 6.5 / wet car
Xray t4'14 / Hobbywing v3 120amp / 13.5/ boost car
Xray t4'15 / Orca Vxx / Orca Rx3 17.5 / blinky car
TEAM DRIVER FOR MMR FLUX
millbank is offline   Reply With Quote
Old 03-02-2012, 04:34 AM   #8073
Two correct answers. I have set up close to a dozen 1s units for "Blinky" racing and I advise each racer about the throttle trim and that voltage protection must be set to "off".
www.norcarracing.com
NORCAR @ The Gate
old_dude is offline   Reply With Quote
Old 03-02-2012, 04:36 AM   #8074
Default Programming and sensorless
I have a quick question. I will be running a 60a with a sensorless motor. Does ESC timing advance or turbo function work in this configuration?
NORCAR @ The Gate
Old 03-02-2012, 07:27 AM   #8075
defcone's Avatar
Trader Rating: 15 (100%+)
No.
defcone is offline   Reply With Quote
Old 03-02-2012, 07:47 AM   #8076
What is the future of the Extreme Stock and the 1s 120A speedos once the v3 comes out, will they still be produced and available.
The v3 seems to be a replacement for the 1s speedo, but there will probably be a significant difference in price to the Extreme Stock.
derekk is offline   Reply With Quote
Old 03-02-2012, 01:30 PM   #8077
Originally Posted by defcone View Post
No.
Thank you very much. I didn't think it could without feedback.
NORCAR @ The Gate
Old 03-02-2012, 07:49 PM   #8078
Hello guys, I just built a Xray T3 and installed a xerun v2.1 esc with a 8.5t motor, It came stock with V1.107_110119 installed but it seems to be lacking the goodies and I am looking to use turbo, timing, boost features on the esc. Could someone point be in the right direction towards what is the best firmware for modified class and if there is a guide for the upgrading process it would be very helpful as well.
Oscar.
arix is offline   Reply With Quote
Old 03-02-2012, 08:32 PM   #8079
lewis110's Avatar
I used the cd that came in the box and downloaded it to my computer.
lewis110 is offline   Reply With Quote
Old 03-02-2012, 08:38 PM   #8080
defcone's Avatar
Oscar.
119 should have boost/turbo.
Old 03-03-2012, 12:28 AM   #8081
Default hobbywing 1s esc with speed passion 17.5v3.0
Hi all, looking for some help with settings on my HW 1s esc using a speedpassion 17.5v3 motor.
I run in our onroad stock open boosted class here in Perth Australia and have currently just purchased the speedpassion motor.
below are the settings the current fast club members are using with their speedpassion escs and software and i was hoping someone could tell me how to replicate these with the hobbywing software and settings.
as you can see they have different settings like supercharger boost and supercharger punch.
I would really like to show them the Hobbywing is just as good as the speedpassion
Thanks in advance Dave
Speed Passion software 528
End bell - full retard , black (std timing board)
S411 (2.0 internal) FDR - 4.0
drag brake - 0
low voltage cut off- none
DRRS - 9
brake force - 75%
nuetral range - 6 (narrow)
AMTS timing- MAX
over heat - on
supercharger boost level - 7
RPM Delay - 5000
Full throttle delay - off
supercharger punch - -1
Toolmannz2 is offline   Reply With Quote
Old 03-03-2012, 04:07 AM   #8082
Help
got problems with my car
running a xtreme stock 17.5 combo in a front wheel drive T.O.P Sabre FD Mini
final gear ratio is 6.10. motor is running far to hot, what programme and settings do i need to install into the ESC.
problem I have is with a front wheel drive car I cant put down the power comimg out of a corner, I need to reduce wheel spin, but still have top speed
would be gratefull for any help
thanks for now
Tony
Tony G is offline   Reply With Quote
Old 03-03-2012, 04:14 AM   #8083
cannon's Avatar
Trader Rating: 35 (100%+)
Originally Posted by Tony G View Post
Help
thanks for now
Tony
You need to at least tell someone what settings you are currently using
www.feralbatteries.com ........... new website
cannon is offline   Reply With Quote
Old 03-03-2012, 07:33 AM   #8084
sorry about that
we started with default settings on the ESC, and the motor came off very hot after a 3 min run, we turned the boost down by 3, the turbo was turned down by 4 , and the timing down by 3, the punch was turned to 1, after the next run, the motor was far cooller, but the car had no speed at all, the ESC was running the default software
this is the first time we are useing brushless, and we are worried about damaging the motor/esc
Old 03-03-2012, 10:45 AM   #8085
outoforder's Avatar
Trader Rating: 34 (100%+)
Ok I have been getting a lot of help on here and I am very thankful for the help. My next ? Is what is the difference between boost and turbo? Also slope of turbo I don't understand what this is suppose to do? Thanks for any help.
...BASHERS INC.....
Team
Valadez
Hobbies
outoforder is offline   Reply With Quote
