Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree2Likes
Old 02-17-2012, 12:23 PM   #7801
Hello,
I ve got a HW 2 in 1 box with SP gt 2.0 pro.
Actually i have the 323 SP soft, and i would like to switch for the 930 HW who improve the sensor signal.
When i load the HW soft i ve this error
"The current version ( v3.0_110323STOCK ) can not be updated to the version ( 3.0_110930 STOCK )!"
Manson is offline   Reply With Quote
Old 02-17-2012, 02:26 PM   #7802
Originally Posted by AGNO View Post
I use the Speed ​​Passion 13.5 V3 ETS, engine specs for our club racing, much like the MMM, use the following setup with good performance, it is not exaggerated and keeps the engine cool.
We also use tires Sorex 36
FW 930STOCK
FDR 5,5
Mechanical motor timing 10
DDRS 9
9 - 35
10 - 18
12 - 20
13 - 3000rpm
14 - 0,1s
15 - 300
Is a good starting point setup, not need a fan, but in Italy is a winter...
Thanks Agno, perfect!
Mild7 is offline   Reply With Quote
Old 02-17-2012, 03:20 PM   #7803
defcone's Avatar
Trader Rating: 15 (100%+)
Originally Posted by Manson View Post
Hello,
Open Sp Software upgrade to 205_MOD
Open HW software, upgrade to 930_Stock.
defcone is offline   Reply With Quote
Old 02-17-2012, 05:02 PM   #7804
COBRARACING's Avatar
Hello,
first make sure your in admin mode on your pc .
second update to a old hobbywing firmware once thats done upload 930 stock .if you dont have a old file i can email you the older file.
in the future because of mixing and matching software from hobbywing,sp etc the new hobbywing firmware for the future will not be able to be downloaded to any other brand than only hobbywing product that includes the 2.1 versions .
Email : teamcobraracing@gmail.com or ae@hobbywing.com
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Old 02-17-2012, 06:23 PM   #7805
FW 930STOCK
FDR 5,5
DDRS 9
9 - 35
10 - 18
12 - 20
13 - 3000rpm
14 - 0,1s
15 - 300
Agno,
I have this version installed, but cant get more than 16deg boost timing (you suggest 35deg):
https://picasaweb.google.com/lh/phot...eat=directlink
Nor can i adjust Boost Start RPM or Boost Timing ACC.. Am I doing something wrong?
Sorry if this is painful.. ive spent hours trawling this thread and cant sort it!
Cheers,
Mike.
Old 02-17-2012, 06:44 PM   #7806
Trader Rating: 36 (100%+)
Originally Posted by Mild7 View Post
Agno,
Cheers,
Mike.
I'm new to this ESC and software, but it looks like you're using the Mod instead of the Stock version of the software. With the current configuration if you press the Upgrade button at the top, it will load the Stock software, and you should have more options.
ufoDziner is offline   Reply With Quote
Old 02-17-2012, 06:50 PM   #7807
Yep, that'll do it!
Thanks mate.
Old 02-17-2012, 09:23 PM   #7808
NR
NR's Avatar
Trader Rating: 52 (100%+)
Anyone got any advice on using Duo / Ion 3s with this software?
Regards
Nathan
NR is offline   Reply With Quote
Old 02-17-2012, 09:53 PM   #7809
Trader Rating: 19 (100%+)
Regards
Nathan
i have tried d3's as well as the newer revtech motors with it in TC as well as pan car and it is an extremely smooth feeling setup, very efficient in the blinky class and super fast in the boosted class!
★Randy Banks★
COLD AS ICE is offline   Reply With Quote
Old 02-17-2012, 11:45 PM   #7810
Nice it s work well.
I was hopping that the 930 resolve my cogging problem with my ready sonic 5.0 but nothing...
In sensorless it s work perfect
Got anyone an idea ?
Old 02-18-2012, 12:00 AM   #7811
You have an issue with your sensor cable or your sensor board in the motor.
Old 02-18-2012, 12:18 AM   #7812
AGNO's Avatar
Agno,
Cheers,
Mike.
UfoDziner's answer is correct
select 930STOCK and to upload
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Old 02-18-2012, 01:26 AM   #7813
I trying 2 sensor cable but same result... so i thing it s the motor sensor, but my sonic is new
Old 02-18-2012, 01:25 PM   #7814
Im currently still running 211stock software in my esc and was wondering if there are any other benefits apart from the less sensetive sensor. I dont get problems with the esc going into sensorless and have the esc setup almost exactly how i like it now.
scytherat is offline   Reply With Quote
Old 02-18-2012, 07:48 PM   #7815
Trader Rating: 22 (100%+)
Is this just poorly worded or do you state that there will be no more updates for the 2.1 versions.
Previous posts you claim the 2.1s will have continuing support regarding software updates!
bjspinner is offline   Reply With Quote
