Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree5Likes
Old 02-15-2012, 11:38 PM   #7786
TeamWTF's Avatar
Originally Posted by defcone View Post
SW 930STOCK
FDR 5
4 - DDRS 9
9 - 40
10 - Fastest/0,1s
12 - 24
13 - 2000rpm
14 - off
15 - 150rpm/deg
This is a good start setup for Speedpassion 17.5
This is what I've been using with great results.
How you do not melt motors I will never know
T.O.P. Racing Australia www.topracing.net.au
TeamWTF is offline   Reply With Quote
Old 02-15-2012, 11:55 PM   #7787
defcone's Avatar
Trader Rating: 15 (100%+)
Le efficient drivetrain XD
defcone is offline   Reply With Quote
Old 02-16-2012, 12:36 AM   #7788
AGNO's Avatar
SW 930STOCK
FDR 5
4 - DDRS 9
9 - 40
10 - Fastest/0,1s
12 - 24
13 - 2000rpm
14 - off
15 - 150rpm/deg
+1 for best punch
My setup is a standard for SP 17.5
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Old 02-16-2012, 12:46 AM   #7789
AGNO's Avatar
Originally Posted by TryHard View Post
Tom, just load up up 930stock or 119stock.. And then tweak the settings down. That way no need to use a seperate program when switching between stock/mod.
Btw, with a 4.5t I have run this successfully before;
Fdr: 7.8
DDRS: 1
Drag brake: 10%
Initial brake: drag
Boost: 20
Turbo slope: 12
Turbo timing: 10
Boost start: 15k
Turbo delay: 0.1
Boost ACC: 200
For lower rev punch, shorter boost ACC, lower boost start, and more boost in general... The above was for medium traction, high traction I was on boost 28, start 10k, and accl at 100! Super punch!
HiH
Ed
It's nice to know that the GM Delta can operate with the Xerun I was informed to the contrary
Old 02-16-2012, 01:24 AM   #7790
millbank's Avatar
I have found that the xerun will work with any motor. You just need to adjust the set up accordingly. Not found any motor that is slow when combined with the xerun. Its all about motor timing. Too much timing and you will generate heat. Simples
Xray T2009 / hobbywing v3 120amp /LRP x12 6.5 / wet car
Xray t4'14 / Hobbywing v3 120amp / 13.5/ boost car
Xray t4'15 / Orca Vxx / Orca Rx3 17.5 / blinky car
TEAM DRIVER FOR MMR FLUX
millbank is offline   Reply With Quote
Old 02-16-2012, 01:55 AM   #7791
AGNO's Avatar
Yes sure, I use too many brands of motor, between here mainly GM Star, but not the version of the Delta, had been erroneously informed that the sensors were not compatible
Old 02-16-2012, 01:59 AM   #7792
Andy63's Avatar
SW 930STOCK
FDR 5
4 - DDRS 9
9 - 40
10 - Fastest/0,1s
12 - 24
13 - 2000rpm
14 - off
15 - 150rpm/deg
I will try this one. But with higher fdr. I have rum the same with fdr: 5.3 and it didnt have good enough punch.
But i will try it! Thanks!
www.andrefossto.wordpress.com|HOBBYWING |YOKOMO |HBracing |MIBOSPORT.COM |Reservdelsrc.com |Jockeli-Painting |
Andy63 is offline   Reply With Quote
Old 02-16-2012, 02:12 AM   #7793
defcone's Avatar
What temps are you coming off at?
Old 02-16-2012, 02:30 AM   #7794
Andy63's Avatar
My temp was about 90 celsius. I had 42 in turbo also.
What temp can the sp motor handle? 17.5T
Old 02-16-2012, 02:40 AM   #7795
TeamWTF's Avatar
I'm curious... What timing do other people run on the V3 motor? I've always cranked it to 10deg and liked that.
Iron Chef Yokomo?
Old 02-16-2012, 04:17 AM   #7796
defcone's Avatar
Max I ever got mine was mid 70's haha. How long is your straight?
Iron Chef Yokomo?
It's either max or off. Feels like a different motor when u max it.
Old 02-16-2012, 06:20 AM   #7797
Andy63's Avatar
The straight is quite short. But is the lipo capacity have anything to do with speed and temp?
When the motor was that hot i was driving pretty hard. But i will try higher gearing so i get the acc i want. Hopefully...........
Old 02-17-2012, 02:00 AM   #7798
Hi all,
I have 120A V2.1 with Speed Passion MMM 13.5, Xray T3, Sorex 36, not a particularly technical track, medium grip, 30m straight.
Looking for a decent if somewhat conservative ESC setup as im returning after a 5 year absence and dont need max speed.
Can anyone make a suggestion? Dont want to cook motors etc.. Running yeah racing twin fans if that helps?
Thanks guys.
Mild7 is offline   Reply With Quote
Old 02-17-2012, 05:10 AM   #7799
AGNO's Avatar
Originally Posted by Mild7 View Post
Hi all,
Thanks guys.
I use the Speed ​​Passion 13.5 V3 ETS, engine specs for our club racing, much like the MMM, use the following setup with good performance, it is not exaggerated and keeps the engine cool.
We also use tires Sorex 36
FW 930STOCK
FDR 5,5
Mechanical motor timing 10
DDRS 9
9 - 35
10 - 18
12 - 20
13 - 3000rpm
14 - 0,1s
15 - 300
Is a good starting point setup, not need a fan, but in Italy is a winter...
Old 02-17-2012, 08:16 AM   #7800
TryHard's Avatar
Ok... it's coming, trust me!
