Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree5Likes
Old 02-15-2012, 11:56 AM   #7771
Andy63's Avatar
Anyone know what software works best with 17,5 T Speedpassion and HW extreme stock esc? Also anyone know good setup??
Thanks!
www.andrefossto.wordpress.com|HOBBYWING |YOKOMO |HBracing |MIBOSPORT.COM |Reservdelsrc.com |Jockeli-Painting |
Andy63 is offline   Reply With Quote
Old 02-15-2012, 12:45 PM   #7772
AGNO's Avatar
Thanks!
SW 930STOCK
FDR 5,5
4 - DDRS 9
9 - 44
10 - 18/0,1s
12 - 20
13 - 3000rpm
14 - 0,1s
15 - 250rpm/deg
This is a good start setup for Speedpassion 17.5
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Old 02-15-2012, 12:51 PM   #7773
banquer's Avatar
And for modified races?
GM Delta 7.0T, final ratio 8.00.
I'll receive my Xerun 2.1 120A tomorrow and I don't know which software version to install and setups for it.
Cheers!
Tamiya 419
Tamiya TRF 101
MuchMore Fleta Pro - Euro - Fleta 10.5-21.5
Sanwa M12 - RX-471
http://www.agaerc.com/
banquer is offline   Reply With Quote
Old 02-15-2012, 01:04 PM   #7774
AGNO's Avatar
Cheers!
I'm not sure that the Xerun 2.1 support the motor GM Delta, but I could be wrong ...
Old 02-15-2012, 02:45 PM   #7775
Andy63's Avatar
Originally Posted by AGNO View Post
SW 930STOCK
FDR 5,5
4 - DDRS 9
9 - 44
10 - 18/0,1s
12 - 20
13 - 3000rpm
14 - 0,1s
15 - 250rpm/deg
I have ran the same setup and didnt feel good punch. Suggestions what to change? Thanks alot for helping!!
Old 02-15-2012, 02:54 PM   #7776
Trader Rating: 36 (100%+)
Would it be better to run the stock or mod version if I'm running a 17.5 on 3s? Thanks.
ufoDziner is offline   Reply With Quote
Old 02-15-2012, 03:11 PM   #7777
Monkeys punk's Avatar
Running a x12. 17.5 so was going to run the v1.63 software but when I try to install it it just tries to update everytime and won't install unless I do the update. Any sugestions guys ?
Top Racing Sabre mini
Tamiya m05
Sakura zero
Monkeys punk is offline   Reply With Quote
Old 02-15-2012, 03:14 PM   #7778
Hi Andy63,
I dont know much about the Speedpassion motor but maybe the FDR is a bit low for that motor. Maybe try a FDR around 5.8 - 5.9
Simon
Team_Krusty is offline   Reply With Quote
Old 02-15-2012, 04:15 PM   #7779
defcone's Avatar
Trader Rating: 15 (100%+)
SW 930STOCK
FDR 5
4 - DDRS 9
9 - 40
10 - Fastest/0,1s
12 - 24
13 - 2000rpm
14 - off
15 - 150rpm/deg
This is what I've been using with great results.
defcone is offline   Reply With Quote
Old 02-15-2012, 04:43 PM   #7780
TryHard's Avatar
Cheers!
Tom, just load up up 930stock or 119stock.. And then tweak the settings down. That way no need to use a seperate program when switching between stock/mod.
Btw, with a 4.5t I have run this successfully before;
Fdr: 7.8
DDRS: 1
Drag brake: 10%
Initial brake: drag
Boost: 20
Turbo slope: 12
Turbo timing: 10
Boost start: 15k
Turbo delay: 0.1
Boost ACC: 200
For lower rev punch, shorter boost ACC, lower boost start, and more boost in general... The above was for medium traction, high traction I was on boost 28, start 10k, and accl at 100! Super punch!
HiH
Ed
| THard.co.uk | Xray | MuchMore |
Old 02-15-2012, 04:52 PM   #7781
Trader Rating: 67 (100%+)
First weekend of running my ofna 1/8 dirt late model with the Xerun 80 AMP ESC and 2250 motor combo. I have the ESC attached to the mounting plate and it is attached to the flat plate that extends behind the batt mount. Should I do anything to prevent the ESC case from splitting due to the hard knocks it gets in 1/8 racing? I don't know that it will but just wanted to see if anyone had a solution or this issue. Thanks.
nutz4rcyktw is offline   Reply With Quote
Old 02-15-2012, 05:16 PM   #7782
smilekt's Avatar
Originally Posted by COBRARACING View Post
Hi Guys
I will be in Thailand next week at the Thailand international touring car championships otherwise known as TITC .
I will be there for support but most important i will be there to look for talented drivers from around the world to join Team Hobbywing as a product supported drivers .
So if you see me around rc addict please come and say hello .
o.k no problemm .... see you there ..
Kuala Terengganu Rc Club Facebook
http://www.facebook.com/group.php?v=wall&gid=357083332025
smilekt is offline   Reply With Quote
Old 02-15-2012, 07:01 PM   #7783
TryHard's Avatar
Same for me, I'll be coming to say hello regardless to Michael, Salton and the gang
Old 02-15-2012, 09:08 PM   #7784
COBRARACING's Avatar
Come and hang out with me ED ok salton and michael will be to stressed to hang out with lol.
Email : [email protected] or [email protected]
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Old 02-15-2012, 10:43 PM   #7785
banquer's Avatar
Fdr: 7.8
DDRS: 1
Drag brake: 10%
Initial brake: drag
Boost: 20
Turbo slope: 12
Turbo timing: 10
Boost start: 15k
Turbo delay: 0.1
Boost ACC: 200
HiH
Ed
Thanks Ed, i'll try it.
Regards.
Tamiya 419
Tamiya TRF 101
Sanwa M12 - RX-471
