NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE
#7756
#7757
Speedo going sensorless
After testing this weekend I can confirm that by turning the voltage cut off 'off' the car never went sensorless once. I even passed on this info to someone else who was having the same problem and it worked for him too.
Thanks - now that I can be confident it won't go sensorless randomnly I will start playing with the settings to get the best out of it.
#7758
#7760
I just stop when it feels a little weak. any more and the voltage drops too fast.
But that's after 10 min
10.5T Fully Boosted SP v2 on a small and technical track
#7762
I gave it a quick test last night seems to be quick but wont no till I get it on the track on the weekend.Temp where in the low 50's played with different settings but first seem to be better.I was told to put start rpm to 5000 and drop timing acc to 300 would this make much difference what do you thinks
#7763
As true as that is with my 1s 1/12 pan car I can feel the car's power level drop and when I'm practicing I never get below 3.4V.
#7764
Just dug out my old xerun 60a SD and I presume all the new software editions will be able to be loaded onto it still ?
#7765
#7766
Hi Guys
I will be in Thailand next week at the Thailand international touring car championships otherwise known as TITC .
I will be there for support but most important i will be there to look for talented drivers from around the world to join Team Hobbywing as a product supported drivers .
So if you see me around rc addict please come and say hello .
#7767
Where can i get the 224 software as i have the 930 loaded at the moment but i am going to run an lrp x12. I used to have it but when i upgraded to 1.64 i no longer have it installed for some reason. Is there a programme that has both 930 and 224 on it?
#7768
try this thread
has links to all the old firmware's etc
http://www.rctech.net/forum/electric...ings-only.html
#7769
I think it's on 1.63 as frank was after it at the last Cwic and the Jennings had it. Hope that helps
#7770
