NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE
#7726
is there a issue with xtreme stock ESC lipo voltage cut off being lower than it set to?
i set mine to 3.0v, and lipo went down to 2,8v per cell...
#7727
First chance today to run my Xerun 80 Amp ESC and 2250 KV motor in 1/8th dirt oval late model. FAst and no issues with electronics at all. I really like this system.
A friend who races with me bought the same system and also ran it today in same class. His performed very well.
#7728
We are getting the same problem using the team powers 17.5t motor, as soon as you go full throttle the car stutters, speed controller green light flashing and it seems to go sensorless, we have tryed 2 new sensor boards now, tryed numerous things last night, turned off the low voltage cut off, no timing on the motor, very little boost on esc and still does it every time.
Batterys are 6500 60c so should be ok.
Has anyone got any other ideas ?
#7729
No issue as some chargers will show it at 3.0v some are 2.8v some batteries dump faster than ithers on the linear voltage drop and some better than ithers.
#7730
lrp x12 21.5t settings
Im looking for some setting for an lrp x12 21.5t
for a medium size asphalt track
in an xrary t3 11 1.9
not sure what to run with atm its fdr is 5.496
boost timing 50
turbo slope 24
turbo timing 14
start rpm 300
turbo delay 0.2
timing acc 350
timing insert 4 dot
with temps in 90's, degree
any help would be great
boost timing 50
turbo slope 24
turbo timing 14
start rpm 300
turbo delay 0.2
timing acc 350
timing insert 4 dot
#7731
boost timing 50
turbo slope 24
turbo timing 14
start rpm 300
turbo delay 0.2
timing acc 350
timing insert 4 dot that equals to 32.5 degree of mechanical timing as the x12 is 27.5 degree as at is suppose zero ponint and each insert will add 5 degree. with temps in 90's, degree
boost timing 50
turbo slope 24
turbo timing 14
start rpm 300
turbo delay 0.2
timing acc 350
#7732
Hi Guys
Just to make you aware of some changes at hobbywing when it comes to software upgrades as for the hobbywing product and its oems.
Hobbywings unique software which will have more advanced unique settings will not be available to download for any other brands than we oem as some of the settings of the software will have patents and licenses attached .
Basically you will not be able to load hobbywing software to any other brand which is an oem product that will include v3 and the 2.1,2.0 xtreme and justock .That will be usb link software and esc software
In saying all this i will always support you no matter what oem brand you use that is made by us no matter software or hardware that i assure you of .
For your oem brand in the futre you must contact your brands website to download the specified software for the specific product .
thank you guys and happy racing .
#7740
he has more speed down the straight hey I would say a little every where whats settings do you run? im sure its the tc version 2 I brought an xxx tc version one second hand that i have noT used yet and was told it would not work,it would make it run to hot is that right?
