Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree5Likes
Old 12-07-2011, 04:22 AM   #7186
Originally Posted by M7H View Post
I even believe what I have suggested is around the default setting.
Maybe even go to the slowest turbo slope setting of 1.5
Settings depend on how throttle heavy you are, and ofcourse your driving skills.
As punch I would start with 3 to 5.
Also start with a roll-out / FDR as suggested by LRP.
a lot of driver think the X12's need to scream, they are wrong, they have a lot of torque, and you need to gear them on the heavy side, when using 101224.
I think You will be surprised about the amount of punch you will have!
Because the amount of timing build in the motor itself, you also don't have to give to much timing with the ESC, also there people go wrong...
Only with 1S lipo 12th scale I give the full amount of 46 points of timing, devided in 34 Boost and 12 turbo, 450 acc, 1.5 slope, punch 9...
That should be oke I think.
I keep all FW release in seperate folders on my PC in the program files. I just made 1 folder called "Hobbywing" and extract the seperate software releases in there.
Yes!
Cheers,
Martin
Nick,
will be keen to see how it goes on Friday Night.
Martin,
did i read in earlier post that you use the "2 dot" insert with your X12 ?
mcdoogle is offline   Reply With Quote
Old 12-07-2011, 04:51 AM   #7187
M7H
M7H's Avatar
Originally Posted by mcdoogle View Post
Martin,
I hope not, because I run the 4 dot, but if you do, maybe I was drunk when writing it...
Serpent
M7H is offline   Reply With Quote
Old 12-07-2011, 06:57 AM   #7188
ok, good good. i have read somewhere here that someone is using x12 with 0' timing insert
Old 12-07-2011, 09:03 AM   #7189
Send a message via MSN to geubes
Im interested to know what the difference between 119 and 211 is?
I tried both and I stuck with 119 - seemed a little quicker.
Does anyone know the technical differences between the two? and why the later release seems a little "softer"?
geubes is offline   Reply With Quote
Old 12-07-2011, 12:35 PM   #7190
Yes me and all the lads in our club with X12 10.5t (and that is 90%)
Electriquement votre...
Drink EARTH water and save lives! in support of WFP
olly986 is offline   Reply With Quote
Old 12-07-2011, 03:44 PM   #7191
COBRARACING's Avatar
Its shows zero timing on the end bell but its actually about 25.5 degree of fixed timing
Email : teamcobraracing@gmail.com or ae@hobbywing.com
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Old 12-07-2011, 07:04 PM   #7192
Ok got it figured out.
Next question where do I set the brakes for 12th scale and timming adjustments. I'm running 17.5 revtech in open mode
Thanks,
Kenny
Fireball10 is offline   Reply With Quote
Old 12-07-2011, 10:46 PM   #7193
steliosh's Avatar
Angelo, if only I knew this X12 info two years ago...
www.steliosh.net/rcmoto/
www.steliosh.net/rc/
KP-Designs KP10e 1/5 rc bike, Kyosho Lazer ZX-5, HPI Baja SS, Xray T1 FK05, Venom GPV1 1/8 rc bike, Anderson M5 Cross 1/5 rc bike, TT SB-5 1/5 rc bike
steliosh is offline   Reply With Quote
Old 12-07-2011, 11:59 PM   #7194
Originally Posted by jdeadman View Post
COBRARACING,
I sent an e-mail back in Oct to hobbywing about my faulty speed Controller I talked about on here (1s booster not working) and Have not gotten a response.
What do I have to do to get someone to respond to me?
I sent it on Oct 18th from the account jdeadman@gmail.com
who did you send the email to ?
You say 1s booster not working is that a 1s 120 amp or is this an external booster ?
Old 12-08-2011, 12:04 AM   #7195
I should have gotten off my arse and studied the motor earlier .sorry Stelio anyway hows Greece going mate?
Old 12-08-2011, 01:23 AM   #7196
M7H
M7H's Avatar
Actually, it's:
4 dots / -10 degree end bell /27.5 degree in reality
3 dots / -5 degree end bell / 32.5 degree in reality
2 dots / 0 degree end bell / 37.5 degree in reality
1 dot / +5 degree end bell / 42.5 degree in reality
0 dots / +10 degree end bell / 47.5 degree in reality
Serpent
Old 12-08-2011, 05:26 AM   #7197
Fabricio's Avatar
Send a message via MSN to Fabricio Send a message via Skype™ to Fabricio
Default New to the HW stuff.
Hi guys, I am new to the Xtreme Stock esc.
Downloaded the HW software on a netbook so I can take it with me to the track.
Question is are the programs inside it or I have to download it somewhere? My idea is to run 4.5/10.5 and 17.5 motors. I know for the 4.5 on the website says I can just change the program.
Another question that came is if I get a Xerun 120 can I also use the stock program on it?
ARC R10 - ORCA - SANWA - EPIC
Fabricio is offline   Reply With Quote
Old 12-08-2011, 05:27 AM   #7198
Trader Rating: 40 (100%+)
The builtin booster of my 1s 120A Hobbywing V2
And I sent the email to cs@hobbywing.com as per their website's instructions.
I'm going to try by a different account as I'm wondering if my work account is not working.
______________________________________________
Jason Deadman
I race toy cars for fun. If I need to explain, you'll never understand.
jdeadman is offline   Reply With Quote
Old 12-08-2011, 09:34 AM   #7199
That's right as M7H mentionned, using 2 dots which in theory is the std insert but on 10.5t motor it is the 4 dots that comes on (-10)
We run these at our club with Tekin RS mainly, so when I run my second chassis with my HW 120A I run the same 2 dots insert and set the speedo's timing (with 224) good speed and low heat so far.
Next year we are moving to 0 timing in 10.5t, I have to set the speedo for this now.
Old 12-08-2011, 11:01 AM   #7200
sizheng's Avatar
The new v3 software is even more amazing than the hardware. Too many things need to test.
Angelo, thanks for your great support to hobbywing users.
TEAMHOBBYWING CHINA
sizheng is offline   Reply With Quote
