Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree5Likes
Old 07-09-2010, 12:51 AM   #706
COBRARACING's Avatar
Originally Posted by zleader_99 View Post
soft 512
1 1
2 3
3 4
4 7
5 4
6 4
7 1
8 1
9 7
10 1
12 7
13 1
14 2
15 4
and a 6.4 fdr. on my MI4 89 spur and 25 pinion 48pt
speed passion 13.5 v1 motor
156'x56 tracmac track apx sugar soloution sprayed
outside temp today about 40 with humdity.
feed back for fading supercharger soft.
Hardware SP LFP esc and HW soft supercharger
SP 13.5 v1 motor
Trakpower (gold Brick) 4900 and Akku lipos 5200
Sweep tires and Jack tire grip
and a one Okay club racer...
What are your temps ?As i see your FDR at 6.3 is way to low, temp is a very big factor in any type of electronic units as its performance will start to fade and all it takes is a drop of temp by 5 degrees and its back again .
Email : teamcobraracing@gmail.com or ae@hobbywing.com
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Old 07-09-2010, 12:55 AM   #707
cherry2blost's Avatar
soft 512
1 1
2 3
3 4
4 7
5 4
6 4
7 1
8 1
9 7
10 1
12 7
13 1
14 2
15 4
SP 13.5 v1 motor
Still sounds like an overheating problem to me, how are your drag brakes feeling when the 'fade' appears, are they 'hardening up' I personally would be running that motor at closer to 7.0 FDR and adjusting the Timings accordingly. Have you tried what we have been trialling and that is setting the Turbo to 1 (OFF) and then fiddling with the rest of the timings as we have noticed very little difference when using the 'Turbo' timings on lap times but with considerably LESS heat generated. If you are slightly heavy handed on the throttle then the speedo is often attempting to instigate turbo when the revs are too low, thus straining the motor. remember that 13.5's have a lot of low end grunt and wrong timings can negate this benefit massively as you end up adding timing when really the motor just needs to be 'left to be' in its' natural form to use the available 'power'. As an experiment try running our way a few times andd you may notice n improvement in lap times as well as a huge reduction in heat.
Hope it helps, these are our personal observations and may not be suitable for all but as they err on the conservative side then there will be little chance of causing damage by using them.
Cherry x
Tamiya TA05 Ver II, Hobbywing 13.5T, KO PROPO PDS-2501 ICS, Eagle Racing 6000 65C LiPo, Hobbywing XTREME STOCK 518/213) Sanwa/Airtronics MT4 2.4G Radio.
www.racersinexile.org.uk | 'Official Certified' UK/Euro Importer for the Hobbywing XERUN Series Equipment We ship the world !!!| Quote code 'cherry' for 10% discount on our Web Store.
cherry2blost is offline   Reply With Quote
Old 07-09-2010, 01:09 AM   #708
AGNO's Avatar
I have a SP esc with the lastest stock software supercharger running a V1 SP 13.5. While running the supercharger software seemed to fade away 2mins inleaving the car under powered and slower. I thought it was one of my older trakpower 4900 lipos starting to pack it up. So next heat I tried a new pack and it seemed to work to about the 4 min mark.. Then all power faded away. Prior to the fad away it was super fast. 6.3 was my fdr. I thought it might be a overheat problem but after running 3 heats the fade was all over the place.
My first thought is that the batteries are not very efficient, you may have a significant drop in voltage after a few minutes (I've also had the Trakpower), try lowering the cut-off.
The second thought is to check the cable sensors, often the problem is there and the ESC switches to sensorless with considerable loss of power (with cables Speedpassion LRP and I had problems ...)
One question: have you checked the temperature of the engine?
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Old 07-09-2010, 02:21 AM   #709
Born2Run's Avatar
As usual the ESC switches to sensorless .Check or better replace your sensor cable .If the problem persists try lowering the timing.
Whatever
Born2Run is offline   Reply With Quote
Old 07-09-2010, 04:38 AM   #710
Trader Rating: 20 (100%+)
Default thanks for all your help
Thats a lot of food for thought. I will have to test the adjustments over the next few days as the weather here is not looking well for the outdoor track.
Cherry
I am pretty hard on the throttle. I should have temp guned the motor last night during practice, I totaly forgot I had a gun with me. You recommend a 7 fdr with that 13.5 motor. I have a SP v3 motor comming. Any ideas on a base setup?
By the way thanks for the Videos.
Besercoe
I will try setting the end points again at 90% then back to 100. Heat affects the end points? Would never have fiqured that. I read that trick back a few pages and have not yet tried it. I can tell you next time I set up my controler I will do this. I have a DX3R so I just reduce the end point adjustmen? Do I do this both for brake too?
Agno
With the sensor cable its there a way to check it with a multimeter? I guess I could check wire to wire for its resistance? Do you mean lowering the lipo cutoff value?
I see the general sesnus is I have deloped too much heat. I was running this set up two weeks ago with no issuses or changes. The only major difference was the outside temp. It felt like 42 degrees here in Toronto Canada. It must have reduced the ability to disapate the heat.
Its hard to keep up with guys, such a wealth of knowledge in the two HW and SP treads. Thanks to all of you beta testers I now own two HW esc and 2 SP lpf.
I am retirering my SP 13.5 V1 to put in my sons offroad car. This means I have a BOSS SP V3 13.5 comming. I would really appreicate a base setup and FDR
Thanks again for all the help.
TLR 22
Desc410r
zleader_99 is offline   Reply With Quote
Old 07-09-2010, 05:32 AM   #711
AGNO's Avatar
Agno
You can check the efficiency of the sensor cable from the LED status, if the ESC switches to sensorless mode problems for cable or sensor LED blinks green.
The lipo cut-off is parameter 4# - low voltage cut-off threshold, with a low value of ESC is less sensible the lowering of battery voltage
Old 07-09-2010, 04:27 PM   #712
Default Update to my issue fadding
Did a strip down of the chassis today. I did find one thinn which may have led to my fadding problem. During my racing I look a pretty hard hit on the left side near my speedo. My speedo case was partialy apart and the sensor lead may not have been in 100%. I snaped the case back together and secured the cable. Thinking back i did notice a blinking green light. As Agno suggested a possible problem with the sensor cable.
I will continue to check the and test with the software.
TLR 22
Desc410r
Old 07-10-2010, 01:29 AM   #713
Benzaah's Avatar
Trader Rating: 21 (96%+)
I had a very productive day of testing today. Track was windy but still got 10 runs down. Dropped my FDR down and upped the start rpm and the car is very nice now. Ive dropped the DRRS right down too and find the car a lot more drivable. No lap timing was running so I have to wait till next meet for the true test but very happy. Still want to try higher start rpms as i did try 7500 today but im curious about a 9000 start and puch at 4 so it winds out a little slower as im still coming on a bit too strong around the sweeper. I ended up with the following settings.
t3 duo 1 17.5 middle hole timing FDR 5.5
DRRS level 2
boost timing 21*
turbo 4*
Start Rpm 6000
Delay 0.6
Punch -3 400*
End Rpm 16000
Temps 45c. after average 8 minute test runs with no fade or drop in brakes or acceleration
AERCCC - ARCR - RRCSA
Adelaide RC
Walter Rc Hobby
Benzaah is offline   Reply With Quote
Old 07-10-2010, 04:18 AM   #714
Send a message via MSN to geubes
soft 512
1 1
2 3
3 4
4 7
5 4
6 4
7 1
8 1
9 7
10 1
12 7
13 1
14 2
15 4
SP 13.5 v1 motor
Interestingly those are the Exact settings I have ended up with my 13.5 except setting 13 is set to 3. on a large track (about 60m straight) I was also geared at 6.4, however at my local my FDR is 7.2 - which has a 25m straight. I do not notice any fading when setting 13 to 3 rather than 1. this is using a duo 13.5 with no timing on the endbell
geubes is offline   Reply With Quote
Old 07-10-2010, 04:55 AM   #715
LOSI123's Avatar
Trader Rating: 63 (100%+)
Can anyone point me in the right direction for a guide to updating a hobbywing Xerun 120amp ver 2 with the latest software for stock racing, im a newb to hobbywing, also do i have to first put the software on it back to old version or something? , I dont even know for sure what ver is on it atm. cheers
LOSI123 is offline   Reply With Quote
Old 07-10-2010, 06:27 AM   #716
r0adrunn3r's Avatar
Send a message via MSN to r0adrunn3r
Do you have the USB 2in1 program box? Get one of those. Plenty on ebay at the moment from HK.
Drop me a PM if you need further details.
Cheers,
Tony
Xray
Losi
www.hillsoffroadrc.com
r0adrunn3r is offline   Reply With Quote
Old 07-10-2010, 08:53 AM   #717
I have a tutorial if anyone is interested, excuse the quality as it's my first attempt at a video. It is in two parts 1/2 and 2/2 and can be found at:
http://www.youtube.com/watch?v=bUKMoGvRJZY Part 1 and
http://www.youtube.com/watch?v=iOCFkCwBlrQ
Part 2.
Before any moans occur I am NOT showing this to be clever it is just that having had over 500 messages asking for assistance with setting up etc I have decided to lower my work load with this video. Watch it don't watch it, it's up to you it is what it is and is purely based on my time spent with these speedo's.
While watching the videos it would be helpful to have a printed copy of the XERUN 'Additional Instructions of Stock Firmware' with you so as to understand the settings being spoken about. There are several mistakes as far as actual setting figures that's why it is advised to have the sheet to hand.
http://www.hobbywing.com/upload/manu...-Hobbywing.pdf
Instruction sheet.^^^
Hope it helps.
Cherry
Old 07-11-2010, 01:03 AM   #718
Mitch-e4fs's Avatar
Hi im new to brushless, can any one explain the differences between the stock and mod software?
Im running stock currently but i havent tried mod tho.
Im using a hw 60a with a Sp V3 21.5 motor
Any setup advice will be very much appreciated
Mitch-e4fs is offline   Reply With Quote
Old 07-11-2010, 06:17 AM   #719
Benzaah's Avatar
Another windy days testing and getting my head around this speedy more and more. Some ramblings from my notes.
Higher start Rpm's just didn't work and i kept going back to 6000. I tried 4500 again and found it came in too early unsettling the car coming through the sweepers and 7500 a touch too late so would love too see a future update with a custom start rpm in say 250 increments as 6500 or 6750 start would be perfect i think.
I guess start rpm is very FDR dependent setting but i dont want to go back to the absurdly high Tekin Fdr's and the weird off power feeling that generates.
With the gearing i was running I found that 21* boost works well with 1 or 2 turbo no higher. 18 boost worked well with 3 or 4 turbo but I ran out of time to test this theory more with lower boost settings as I think im onto something there.
Still cant find the right turbo delay so i will be playing with this some more next time but feel higher is better so that the boost can fully wind out before turbo kicks in and over time the motor and flattens the power.
I ended up with the following settings although one of the local fast guys still thinks its slow compared to his Tekin.
t3 duo 1 17.5 10 degrees motor timing
FDR 5.1
DRRS level 2
boost timing 18*
turbo 4*
Start Rpm 6000
Delay 0.3
Punch -3 400*
End Rpm 14800
Temps 55c.
Still not 100% on the FDR and wouldn't mind dropping it down into the 4's to see how the rip holds up and how much extra top end it has. Either that or Im thinking of dropping the punch to 2 and see how much quicker it spools up. Also want to try 12 degrees boost and max turbo.
Now all i need is for Sunday to roll around again, some new tyres and a decent coat of sugar on the track and this is going to be dangerous.
Any thoughts on the above are appreciated. Regards Benzaah
Adelaide RC
Walter Rc Hobby
Old 07-11-2010, 01:15 PM   #720
AGNO's Avatar
Default Setup for very small track
Hi guys, if you're interested I tried this setup for 17.5 track very small and medium grip with excellent results (1 th place).
This is the track
