Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree5Likes
Old 12-04-2011, 10:31 AM   #7156
capellone24's Avatar
Yes olly....the motor temp Was ok (around 50celsius) .....i stopped the car all the time the esc went in sensorless m ode to prevent damage.....
Update:this morning i tried all your advices but still the esc went in sensorless mode......at the end i uploaded 508 no timing firmware and after four minutes the motor smoked up to 138 celsius.....
So swapped this pièce if sxxxt for a 40€ speed passion v2 13.5 sportsman motor and.....wow amazing performance ,great speed and very nice feeling ....after 8 min the motor was 40 celsius and the Esc 20 ........
Never buy x12 stock again!!!
Ciao!
visit my yokomo blog:
http://yokomo-fan.blogspot.com/
capellone24 is offline   Reply With Quote
Old 12-04-2011, 01:30 PM   #7157
X12's are one of the best motors available (don't give up on it yet), it sounds like your X12 has a faulty sensor board.
frozenpod is offline   Reply With Quote
Old 12-04-2011, 01:42 PM   #7158
TeamWTF's Avatar
When boosting the x12 you want to run the lowest timing insert.... 4 dot or -4dot I cant remember (Have not used one myself)
T.O.P. Racing Australia www.topracing.net.au
TeamWTF is offline   Reply With Quote
Old 12-04-2011, 02:12 PM   #7159
I'm only a bit frustrated today, i'm sure the x12 works well with lrp speedos.....
and anyway i agree,maybe my x12 had a damaged sensor unit , but i don't understand why it smoked in no timing mode.......
maybe when i was running with 508 no timing i'vent noticed a loss of permormance due the sensorless mode engaging and this mode was letal for my x12 motor.....who knows...
Thank you all....
Ciao
Old 12-04-2011, 03:30 PM   #7160
Thank you all....
Ciao
Well, when you moved to timing zero, you would have to change your fdr for sure. If you did not it could damage the moteur.
I run X12 in our two cars all season with only 1 bearing replacement
We actually run the straight insert 0 dot and do our setup via speedo, but 4 dot is the standart insert when you get the motor.
Plenty X12 here and no major problems, but they do need to run hot, 70/80 celsius is fine for these.
Electriquement votre...
Drink EARTH water and save lives! in support of WFP
olly986 is offline   Reply With Quote
Old 12-04-2011, 07:27 PM   #7161
Trader Rating: 22 (100%+)
Originally Posted by COBRARACING View Post
red to green flashing is that the esc doesnt recognise your sensored motor or a poor signal from the motor sensor board
Not related but Drop the punch level to 7-8 (9) is way to high .
Also check your sensor cable swap it with another and try .
The last thing is to re shim the motor to bring the rotor closer to the sensor board hall sensors .
one of the options above will fix it your problem
You cannot shim an X12 closer to the sensors as the sensor insert goes over the rotor end, there is no option as there are minimmal shims in the design as it is.
Try 1224 as some have suggested in earlier posts.
80 deg celsius is a good temp for an X12.
bjspinner is offline   Reply With Quote
Old 12-04-2011, 07:30 PM   #7162
Ciao!
There is a problem with this speedy motor combo, very fast when it works but unreliable to a frustrating level with the sensored dropout issue.
Old 12-05-2011, 06:50 AM   #7163
I decided to try my HW V2.1 120a esc with X12 with the new 930 software (usually use HW 13.5 motor) and instantly did a PB at my local track. My car is really quick now, it is a little lacking in brakes. i just used the settings that was posted here approx 10 pages back :.
mcdoogle is offline   Reply With Quote
Old 12-05-2011, 07:37 AM   #7164
CrazyRonny's Avatar
I put an Xtreme Stock in my HotBodiex TCX this weekend and I had some problem with it.
We need to run the "blinky" "no boost" mode in the 17.5T class, so I put the "508_NO timing" software in it.
The first thing I notice is that there is no blinking led to indicate to the tech people that I run a "no boost" mod.
Second thing is that I have a really bad delay when braking, I calibrate everything twice and try all kind of set up... but nothing change, the car will not brake when I ask it, it took like 4 to 8 feets befor it brake.
Not a good weekend...
Anyone with the same problem or a solution to this?
CrazyRonny
www.crazyrcshop.com
CrazyRonny is offline   Reply With Quote
Old 12-05-2011, 07:48 AM   #7165
lowroad's Avatar
Trader Rating: 79 (100%+)
You should be able to see a small blinking light, at least I do. It's a bit difficult to see. I missed it the first time too. It's actually under the solder tabs.
The bad news is, if you are running on 1S, you have to disable low voltage cut off for anything to work. There are rumors of a fix, but no update as to when.
lowroad is offline   Reply With Quote
Old 12-05-2011, 07:56 AM   #7166
AGNO's Avatar
No problem with Xtreme NO timing mode, use it for a year over with 10.5 engine, with V2 508, the flashing of led is a little weak, with the V3 508 flashing is very visible and brake power was increased
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Old 12-05-2011, 08:27 AM   #7167
When using the V3 508_no_timing software be sure to disable voltage protection and re-calibrate the speedo to the radio after updating. If you don't have a blinking red light (under the solder posts on a 1s) try throttle trim. For a solid red light trim to the forward, for no light at all trim towards the brake. When properly trimmed you will have a nicely visible blinking red led (about one blink a second). If it is blinking very fast try the trim to the forward direction one click and you will get the slower blink.
www.norcarracing.com
NORCAR @ The Gate
old_dude is offline   Reply With Quote
Old 12-05-2011, 09:15 AM   #7168
lowroad's Avatar
Ah, snap. I was referring to the 1s I have. Missed the whole xtreme stock thing. Reading is fundamental.
Old 12-05-2011, 01:05 PM   #7169
COBRARACING's Avatar
The 1s voltage cutoff will soon be available michael is working on it now .
Email : [email protected] or [email protected]
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Old 12-05-2011, 01:07 PM   #7170
Thank you all....
Ciao
The designer and engineer Reto from Lrp is a friend so i will talk to him later today and see what he has to say about the x12.
Thats the benefit of being friends with the competition you help eachother .
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
