Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree5Likes
Old 10-24-2011, 04:47 PM   #6796
Superkarter's Avatar
Hey Aneglo
I've got a problem with the No Timing software, it's just slow compared to other non timing speedie's. I've used this speedie in mod with boost and it's a rocket but i can't get any speed out of it for when racing the spec classes?
Any idea's?
Cheers
Tim
Superkarter is offline   Reply With Quote
Old 10-24-2011, 05:08 PM   #6797
Darrin70's Avatar
Originally Posted by Superkarter View Post
Hey Aneglo
Any idea's?
Cheers
Tim
Tim Install the software twice.... I ran it in no timing 21.5 with full timing on the motor and it was just as good or better... You are using motor timing aren't you?
HYPERHOBBIES
YOKOMO
SKYRC
SWEEP RACING
SMC
Darrin70 is offline   Reply With Quote
Old 10-24-2011, 07:18 PM   #6798
bukil's Avatar
Trader Rating: 39 (100%+)
Originally Posted by YZFAndy View Post
Assuming all the basics are set up right like transmitter end points, expo ect, I would say either your rotor is very weak or the speedo isn't getting enough support from the capacitors. Either they are on the way out or standard wires too skinny or bad soldering. I'm running 87% on the speedo and i've got that backed down another 5 on the transmitter for high grip carpet and that's still making the tyre sequel.
I have the Hobbywing 4-capacitor installed on the speedo. Wires and soldering are good. It could be my motor. However, I have my two other teammates having the exact same issue using a different motor.
Originally Posted by daleburr View Post
Make sure you set reverse to 100%
Hmmm. How will this work if I have the speedo set to For/Brake only? I will give it a try though. Thanks - will report back.
☆ ActivRC ☆
bukil is offline   Reply With Quote
Old 10-25-2011, 12:13 AM   #6799
JAM Racing's Avatar
Default version 3
any update about when we can by the version3
Walters Hobbies for all your racing needs
Serpent 411/ERYX
ORCA BATTERIES
Castle Hill Raceway
The Best in the West
JAM Racing is offline   Reply With Quote
Old 10-25-2011, 01:52 AM   #6800
M7H
M7H's Avatar
When it's ready....
If you've followed this thread, you could read that there has been some dealer comments about the rumor of the new ESC, customers are waiting now, not a good thing...
It will come this year, maybe next year...
Serpent
M7H is offline   Reply With Quote
Old 10-25-2011, 03:12 AM   #6801
blade072's Avatar
Trader Rating: 98 (100%+)
heard around the end of this month.....so probably within the next 2 weeks hopefully!!!
David Randall
AWESOMATIX A800X ★ MUCHMORE ★ R1 WURKS ★
ROCHE RAPIDE F1-16 ★ SANWA M12 ★ SILVERBACK ★
HOBBYWING ★ RCMAKER ★ VOLANTE RC ★
blade072 is offline   Reply With Quote
Old 10-25-2011, 03:24 AM   #6802
kedal's Avatar
Hi all, dont know if its the right place for that, but... I have a little problem with my Xerun 120A.
The on/off switch was dead, so I shut the + and - together, and leave the tird wire alone.
But now, I need to reboot my ESC and I need to use the "not here" button...
How can I do ?
TRF201 - Tekin RS Pro - PRT HS 10.5T
F103 - Hobbywing 1S - Hobbywing 13.5T
rctouch.over-blog.com
kedal is offline   Reply With Quote
Old 10-25-2011, 03:48 AM   #6803
defcone's Avatar
Trader Rating: 15 (100%+)
How can I do ?
Buy a new switch and replace it.
defcone is offline   Reply With Quote
Old 10-25-2011, 06:12 AM   #6804
millbank's Avatar
Set the brakes to 87.5 :-)
Seems daft but it really works
Xray T2009 / hobbywing v3 120amp /LRP x12 6.5 / wet car
Xray t4'14 / Hobbywing v3 120amp / 13.5/ boost car
Xray t4'15 / Orca Vxx / Orca Rx3 17.5 / blinky car
TEAM DRIVER FOR MMR FLUX
millbank is offline   Reply With Quote
Old 10-25-2011, 06:23 AM   #6805
Yep full timing on the motor in 17.5. I'll try that
Cheers
Tim
Old 10-25-2011, 04:19 PM   #6806
kinga's Avatar
Is that for all Hobbywing speedys? Will that help the brakes on the Justock? Looking at the capacitor on my justock it is a very small cap compared to other higher amp speedys, will a larger capacitor help the brakes?
What is the theory behind setting the brakes to 87.5 instead of 100?
kinga is offline   Reply With Quote
Old 10-25-2011, 05:42 PM   #6807
COBRARACING's Avatar
How can I do ?
you need a new switch with the button .
Email : teamcobraracing@gmail.com or ae@hobbywing.com
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Old 10-26-2011, 03:00 AM   #6808
cherry2blost's Avatar
How can I do ?
Hi have them here
http://www.racersinexile.org.uk/XERU...0_2750537.aspx
Hope it helps
Cherry
BTW codes are available
Tamiya TA05 Ver II, Hobbywing 13.5T, KO PROPO PDS-2501 ICS, Eagle Racing 6000 65C LiPo, Hobbywing XTREME STOCK 518/213) Sanwa/Airtronics MT4 2.4G Radio.
www.racersinexile.org.uk | 'Official Certified' UK/Euro Importer for the Hobbywing XERUN Series Equipment We ship the world !!!| Quote code 'cherry' for 10% discount on our Web Store.
cherry2blost is offline   Reply With Quote
Old 10-26-2011, 03:08 AM   #6809
kedal's Avatar
Thanks guys, I will buy a new switch.
Cherry2blost : I will buy it in France, but thanks for the link
Old 10-26-2011, 09:32 AM   #6810
syndr0me's Avatar
Trader Rating: 32 (100%+)
How long until I can hand someone a fist full of money for a v3? I don't care about stupid politics, I want a new ESC.
syndr0me is offline   Reply With Quote
