Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 07-05-2010, 06:59 PM   #661
COBRARACING's Avatar
coming soon
new 120 amp 1S esc can also run 2s but perfect the 1/12 scale (in testing)
Short course truck combo esc
and many more to be annouced later this week .
Email : teamcobraracing@gmail.com or ae@hobbywing.com
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Old 07-05-2010, 07:25 PM   #662
warnos's Avatar
Default 17.5
I am a bit confused with the settings that people use in 17.5 on here and the SP thread. When ever I use a FDR in the 6's or 7's the car seems slower then when I use a FDR at 5.. I feel the car has more punch at 5 when using the same settings and more top end.. is it just me or have other people found this.
This has been at multiple tracks.. extremily long nitro tracks and small technical tracks.
Settings are :
12 -8
13 - 1 or 2 depends on the length of the straight for me
14 - 4
15 -2 have tried 1 at all fdr's and 2 seems better
I have tried these settings with 5 - 5.5 - 6.5- 7.8 and in between.. I just don't find the car faster when I go above 5.. anyone else found this?
Cheers
TCX Smokem / F104 wgp
Major Sponsor : Visa Card
TEAM SMA - www.smaracing.org
warnos is offline   Reply With Quote
Old 07-05-2010, 08:27 PM   #663
defcone's Avatar
Trader Rating: 15 (100%+)
Settings are :
12 -8
14 - 4
Cheers
What motor? I found this was true with Speed Passion motor, but was fast with a 6+ fdr with the duo1.
defcone is offline   Reply With Quote
Old 07-05-2010, 08:48 PM   #664
warnos's Avatar
Tried it with SP motor and Tekin.. both seemed to be like this.. but the SP liked it even lower then 5 the tekin which I have found faster I use at about 5.
Old 07-06-2010, 12:44 AM   #665
spoket's Avatar
Originally Posted by smilekt View Post
oitt ... can beat 5.5T with 11.5t ?
5.5T HW with EZrun .. drafting only
Speed Sideway Crewz
ENTC3/MRX4E
Powered by Brushless & Lipo Tech
spoket is offline   Reply With Quote
Old 07-06-2010, 01:08 AM   #666
Suspended
5.5T HW with EZrun ????
begintravel55 is offline   Reply With Quote
Old 07-06-2010, 01:48 AM   #667
cherry2blost's Avatar
Default XERUN Tutorial video
I have a tutorial if anyone is interested, excuse the quality as it's my first attempt at a video. It is in two parts 1/2 and 2/2 and can be found at:
http://www.youtube.com/watch?v=bUKMoGvRJZY Part 1 and
http://www.youtube.com/watch?v=iOCFkCwBlrQ
Part 2.
Before any moans occur I am NOT showing this to be clever it is just that having had over 500 messages asking for assistance with setting up etc I have decided to lower my work load with this video. Watch it don't watch it, it's up to you it is what it is and is purely based on my time spent with these speedo's.
While watching the videos it would be helpful to have a printed copy of the XERUN 'Additional Instructions of Stock Firmware' with you so as to understand the settings being spoken about. There are several mistakes as far as actual setting figures that's why it is advised to have the sheet to hand.
http://www.hobbywing.com/upload/manu...-Hobbywing.pdf
Instruction sheet.^^^
Hope it helps.
Cherry
Tamiya TA05 Ver II, Hobbywing 13.5T, KO PROPO PDS-2501 ICS, Eagle Racing 6000 65C LiPo, Hobbywing XTREME STOCK 518/213) Sanwa/Airtronics MT4 2.4G Radio.
www.racersinexile.org.uk | 'Official Certified' UK/Euro Importer for the Hobbywing XERUN Series Equipment We ship the world !!!| Quote code 'cherry' for 10% discount on our Web Store.
cherry2blost is offline   Reply With Quote
Old 07-06-2010, 02:52 AM   #668
mr.preay's Avatar
Default Change the Profile/Mode No. by USB Box.
Hi guys, this is how to change the Profile/Mode No. by USB Box.
You can have 3 Profiles setting on your speedo, so you can change
it when you want eg. change track, different motors.....
You can name the Profile and done all settings by use the computer
You can see how to do it in Video Clip(Part 2) from of Cherry2blost,
Thanks Cherry2blost.
If you've done all 3 Profiles/Mode No. setting then let start
Plug in the USB to the Speedo and turn on.
hold R/P button until the ESC firmware appear then let go the button.
Now you will see the Profiles/Mode No. or name that was saved
push VALUE button to select Profile/Mode you want
then push ITEM, and you're done changingn the profile
you can also check or change value in this profile as normal use
after you push ITEM button.
Preay.
mr.preay is offline   Reply With Quote
Old 07-06-2010, 02:57 AM   #669
AGNO's Avatar
If interested I can use for 17.5 this set-up with good results
This set-up works well with different brands of engines: Novak Ballistic and SS Pro, Feigao and GM Pro Stock are achieved excellent performance (like the Tekin ...) and low temperatures in the engine,max 65 C with 30 / 35 C ambient temperature
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Old 07-06-2010, 06:23 AM   #670
Benzaah's Avatar
Trader Rating: 21 (96%+)
Good healthy discussion here guys. I run a 17.5 duo 1 on middle hole timing. I have not tested FDR enough. The HW documents talk about the right gearing and rpm range giving less temps and more performance. It also talks of when using a higher number on setting 4, you end up sacrificing top end performance. My current curiosity is how much setting 4 has over the whole picture. Waiting for Cobras response to my earlier query.
Loving this speedy so far. Cant wait to get more time under the belt practicing and racing.
AERCCC - ARCR - RRCSA
Adelaide RC
Walter Rc Hobby
Benzaah is offline   Reply With Quote
Old 07-06-2010, 06:30 AM   #671
blade072's Avatar
Trader Rating: 98 (100%+)
hello quick question...maybe angelo or anyone could answer
i run 10.5...should i just get a v2.1 60amp or wait for the new xtreme stock??? is getting the v2.1 120amp worth the extra $$$
thanks...
David
David Randall
AWESOMATIX A800 ★ MUCHMORE ★ R1 WURKS ★
TEAM XRAY X116 ★ SANWA M12 ★ SILVERBACK ★
HOBBYWING ★ RCMAKER ★ VOLANTE RC ★
blade072 is offline   Reply With Quote
Old 07-06-2010, 06:43 AM   #672
Talking
Hi matey, as far as we can see having used these speedo's for two years the DDRS (Setting4) is a little like the old 'punch profiles on Brushed ESC's. Treat it as a 'smoothing' out of your trigger finger higher values just affect the actual power delivery which is mainly noticable on start up and on exit from slow corners, if you find your rear end is breaking out due to too much power too soon then lower this figure, but do try to run it as high as is comfortable. As far as we can tell it has no input to the overall delivery through the timing range and is really just as it says in the manual "Start Mode (Punch)". The time you will notice this the most is when starting on a grid final, higher DDRS will get you moving quicker off the line, but beware of the previously stated low end 'rip' which occurs with higher settings. Best suggestion to an explanation is that it has an effect UNTIL the timing ramp begins, so if you are running low Boost Start (13) then it will only be effective up to THAT rev range. Setting 7 or 8 seems to be the best compromise and a lower figure can often lead to better lap times due to the better overall stability of the car under power out of slow corners.
As an aside if your car has masses of rear end grip then this can be used to 'push' the rear out to increase steering but obviously be careful to be able to catch the slide before it goes too far. Rule of thumb = more DDRS (4) more low end 'rip, less =less QED
Old 07-06-2010, 06:48 AM   #673
defcone's Avatar
thanks...
David
You'll get the 120Amp one if you decide to run mod later, otherwise the 60a has been proven to be enough for 10.5t.
Old 07-06-2010, 06:51 AM   #674
mr.preay's Avatar
thanks...
David
Extreme Stock
Old 07-06-2010, 06:52 AM   #675
blade072's Avatar
thanks for that DEFCONE!!! and mr. preay have asked greg from feral to let me know eta on the xtreme...I WANT BLACK LOL
David Randall
