Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree5Likes
Old 10-19-2011, 01:23 AM   #6721
Originally Posted by bkspeedo View Post
I am running a 3.8 FDR but my other ESC's work fine with this FDR. This other ESC had the same problem in the beginning and it took them quite some time to fix it.
Hopefully the Hobbywing group can figure it out sooner than later.
I have the same problem with FDR 3.39 (66T spur, 37T Pinion), i can match top end speed with other guys but i have to brake so early to try and get round our hairpin that the other guys have left me :-(
mcdoogle is offline   Reply With Quote
Old 10-19-2011, 02:47 AM   #6722
Barry_Hughes's Avatar
Originally Posted by mingnon View Post
I prefer to use drag brake, dont know why, just fits my driving style. Having changed to the hobbywing esc, it isnt and strong as others. Me personaly, would prefer it to be more effective and adjustable
Drag barake force is adjustable second step of programming
Built it !
Raced it !
Wrecked it !
Barry_Hughes is offline   Reply With Quote
Old 10-19-2011, 04:40 AM   #6723
Isn't drag brake a percentage of the full brake force? I thought I read that somewhere and I will do a test to confirm it.
I just loaded the new v3 stock software into my ESC and set the drag brake to my previous value. It was much more effective and I reduced my setting from 30% to 15%. I am running the 4 capacitors though.
www.norcarracing.com
NORCAR @ The Gate
old_dude is offline   Reply With Quote
Old 10-19-2011, 10:43 AM   #6724
mutley001's Avatar
Default 211 vs 930 stock
Hi guys
Just a quick question. I have been running 211stock software and have just changed to 930 stock. What differences will I feel when running the same settings? Anything?
Cheers
ARC R11 2017
ARC R10 2013
EA Motorsports www.teameamotorsports.com
Team EAM
mutley001 is offline   Reply With Quote
Old 10-19-2011, 11:21 AM   #6725
have u got the 930 on ur laptop yet ? if u have cud i update mine on sunday
stcc ssb tires, ko ,gm motors, demon products lipos, hobbywing speedo
mwoods is offline   Reply With Quote
Old 10-19-2011, 12:25 PM   #6726
need a setup for xtremestock with speed passion 17.5 boosted ASAP!
indoor carpet, small to medium size track
Team Associated TC7.1 - Hobbywing - Highest - Sanwa - Gens Ace
Team Associated B5R - Hobbywing - Highest - Sanwa - Gens Ace
Bappe is offline   Reply With Quote
Old 10-19-2011, 01:46 PM   #6727
Trader Rating: 17 (100%+)
I have a problem with my extreme stock ESC , it won't run unless it is given a push first, then it will run until it comes to a complete stop
I have changed motors and sensor leads and the problem is still there, have even re flashed speedy
Any suggestions
Team Awesomatix
R1 Wurks
RC Maker.com
Southern Tasmania Model Car Club
lethallee69 is offline   Reply With Quote
Old 10-19-2011, 05:30 PM   #6728
COBRARACING's Avatar
Any suggestions
try another battery with a higher discharge rating and also drop your punch level .by two so if your running 9 got to 7 .
Email : [email protected] or [email protected]
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Old 10-19-2011, 05:46 PM   #6729
bkspeedo's Avatar
Any suggestions
Along with Angelo's comments it may be a bad sensor wire or board in the motor. It either of these are bad it will try running in sensor-less mode. With high wind motors the ESC has a hard time starting the motor due to not enough feedback from the motor coils.
Brent Klingforth
Sponsors: Awesomatix USA ~ Roche USA ~ ORCA ~ AVID Bearings ~ R1 Wurks
TQ Wire ~ Montech ~ WTF ~ BSR Racing Tires ~ 2mm Design ~ Helix Designs
5280 Raceway
MILE HIGH INDOOR CHAMPS April 19-22nd 2018 @ www.milehighindoorchamps.com
bkspeedo is offline   Reply With Quote
Old 10-20-2011, 12:25 AM   #6730
Have tried different motors and sensor cables, it still runs with boost mode it's just that it won't take off without a push first
Team Awesomatix
R1 Wurks
RC Maker.com
Old 10-20-2011, 12:52 AM   #6731
If you have reflashed it and reset your end points then I would be looking at the batteries
scoop is offline   Reply With Quote
Old 10-20-2011, 04:29 AM   #6732
toby333's Avatar
Next step change the cap's and if that doesn't help most likely the esc is faulty. Goodluck.
toby333 is offline   Reply With Quote
Old 10-20-2011, 04:37 AM   #6733
xrayal's Avatar
had exact same problem. widen your deadband and if you have reverse enabled, disable it. try it
associated b5m
team c tm4
sanwa mt4
lrp flow tw
mardave
xrayal is offline   Reply With Quote
Old 10-20-2011, 08:33 AM   #6734
roger999's Avatar
Any suggestions
Try to play with th-trim. Give there +1 or +2.
facebook.com/rogergrafix
roger999 is offline   Reply With Quote
Old 10-20-2011, 11:35 AM   #6735
Madulla's Avatar
Tried the V3 no timing on the Just Stock last night. Couldn't tell if the brakes were stronger. My lap times are the same but the temp went down 20F. Really happy with the update. Good job.
Hobbywing North America Team Driver
hobbywingdirect.com
Madulla is offline   Reply With Quote
