Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree5Likes
Old 10-05-2011, 07:41 AM   #6541
Originally Posted by M-Technic View Post
So 930 and 119 don't have boost then? Thanks for the info.
119 was version before 211, boosted
528 and 205 are mod
508 is no timing
Electriquement votre...
Drink EARTH water and save lives! in support of WFP
olly986 is offline   Reply With Quote
Old 10-05-2011, 07:44 AM   #6542
Originally Posted by DS Motorsport View Post
I found that store but my French is a little rusty.
If you need help with the linguo I can help you, I get stuff from Wartelle myself from time to time.
But lets face it, regardless the language, all sites looks pretty similar whan you know what you are looking for.
Variateur is French for Speed controller anyway.
Old 10-05-2011, 11:07 AM   #6543
xrayal's Avatar
Default stuttering starts......
hi all, just posting this as ive tried everything i know........ i have a club member that is having trouble with stuttering starts....... if the car is stationary and full throttle is aplied, he gets either a delay or a stuttering start simialar to cogging.if the car is moving its fine. this happens in both 13.5 and 21.5, re flashed the speedo twice, reloaded software to pc twice, many different sensor leads, settings and fdr which we know are correct for our track, good lipos the only thing we hav not yet tried is changing the power cap? any ideas guys?
associated b5m
team c tm4
sanwa mt4
lrp flow tw
mardave
xrayal is offline   Reply With Quote
Old 10-05-2011, 12:52 PM   #6544
FunkyDunky's Avatar
Hi Xrayal,
I hope others can shed more answer on here, as mentioned on another site I would go for a cap replacement, I've had them cause me problems before
FunkyDunky is offline   Reply With Quote
Old 10-05-2011, 01:04 PM   #6545
Tabushi's Avatar
Send a message via AIM to Tabushi Send a message via Yahoo to Tabushi
508 is the only no-timing mode for STOCK ?, no updates on it ?
thanks,
Patricio "PATO" Concha
E-Mail : [email protected]
Facebook : http://www.facebook.com/patoconcha
Whatsapp : +56 9 66165085
Tabushi is offline   Reply With Quote
Old 10-05-2011, 02:06 PM   #6546
Trader Rating: 22 (100%+)
Is the motor an LRP?
Could be you need to try the 930 Stock software. This worked for me with an LRP.
bjspinner is offline   Reply With Quote
Old 10-05-2011, 02:32 PM   #6547
Did you reset the radio neutral ful speed and brake also? is this what you call re flashed? it needs to be done after reloading software.
Old 10-05-2011, 02:41 PM   #6548
PDR
PDR's Avatar
Trader Rating: 30 (100%+)
thanks,
If you go back a few pages, there's a link to a download that contains two files. You put these into the right directory and there's now an updated 508, prefixed with "V3.0_508". Features a stronger blink and better brakes.
Looking for chassis | Multiple Kids
2011 Slowest Winner - 21.5 Muchmore Masters & NSW State Titles Demo Class
https://www.facebook.com/phatdadracing/
Making an A Main at a Scotty Ernst event. Awesome. Scotty calling you first in A1. Priceless
PDR is offline   Reply With Quote
Old 10-05-2011, 02:45 PM   #6549
xrayal's Avatar
yep all done by the book. ill try dunkys option of a new cap as its the only thing we havnt tried........
associated b5m
team c tm4
sanwa mt4
lrp flow tw
mardave
Old 10-05-2011, 02:46 PM   #6550
xrayal's Avatar
xtreeme stock speedo and hobbywing motor.
associated b5m
team c tm4
sanwa mt4
lrp flow tw
mardave
Old 10-05-2011, 04:13 PM   #6551
COBRARACING's Avatar
Hi
since you have tried all of the above yes please install a 4 cap board this way your battery voltage will be similar or even to your esc voltage .Less ripple less heat more efficiency as caps do tend to break down the material and start to leak making them less efficient over time also please clean your sensor board hall sensors on your motors .if that doesnt fix the issue try less punch drrs as your batteries just might not have enough discharge .
when you say good lipo what do you mean new lipos high discharge lipos ?
worse case the mosfets might be damaged in the esc .
regards Angelo
Email : [email protected] or [email protected]
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Old 10-06-2011, 02:05 AM   #6552
xrayal's Avatar
Originally Posted by COBRARACING View Post
Hi
regards Angelo
i use ip intellect 5800 60c lipos. i run an extreeme stock with hw 10.5 or 13.5 i also run my local club and am good friends with stuart. it just seems very strange. my settings on his set up, my lipos, and his speedo/motor are only 3/4 months old. his 21.5 is brand new....... but we will try the power cap on friday night and see what happens. many thanks to you all for answering. it is because of this thread and the people on it that i push hobbywing products at my club and here in the uk. cheers guys
associated b5m
team c tm4
sanwa mt4
lrp flow tw
mardave
Old 10-06-2011, 03:22 AM   #6553
Default Hobbywig onto SP esc
Hi. This thread has got so long now i dont know where to start so looking for a quick answer to this question.
Can i use the hobbywing programme box and load 211 onto my mates SP LPF V2 esc?
Cheers.
scoop is offline   Reply With Quote
Old 10-06-2011, 03:27 AM   #6554
blade072's Avatar
Trader Rating: 98 (100%+)
Cheers.
if the esc has hobbywing software on it...then yes!!
David Randall
AWESOMATIX A800X ★ MUCHMORE ★ R1 WURKS ★
ROCHE RAPIDE F1-16 ★ SANWA M12 ★ SILVERBACK ★
HOBBYWING ★ RCMAKER ★ VOLANTE RC ★
blade072 is offline   Reply With Quote
Old 10-06-2011, 04:54 AM   #6555
Well it has the original SP at the mo. Can it be changed?
