Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree2Likes
Old 10-02-2011, 01:26 AM   #6496
Trader Rating: 48 (100%+)
Originally Posted by J SiN View Post
what would be the best software to use with a 21.5t sp v3 motor
930/211/213
have only tried 211 but im lacking alot of top end atm
I have been using 213 since april and its been going well
crazydave is offline   Reply With Quote
Old 10-02-2011, 01:59 AM   #6497
Craig W's Avatar
Send a message via MSN to Craig W Send a message via Skype™ to Craig W
is 930 out on download and were can i get 213 from
plus im looking for setting for thunder power 17.5t
Craig W is offline   Reply With Quote
Old 10-03-2011, 12:44 AM   #6498
Geberit's Avatar
Originally Posted by COBRARACING View Post
V3 to be released end of october 2011
Will the V3 be a whole new concept (looks, hardware, software)?
I'm very interested in the product since the price is good and the support too. But from the top racers no one is using it!? Can it match brands like SpeedPassion, LRP, Team Orion, Novak ....
Geberit is offline   Reply With Quote
Old 10-03-2011, 12:48 AM   #6499
COBRARACING's Avatar
yes all new from the ground up but just to let you know speed passion,Hpi and Team orion are all Hobbywing oem's design of hardware and software is Hobbywing's innovations .
Email : teamcobraracing@gmail.com or ae@hobbywing.com
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Old 10-03-2011, 12:50 AM   #6500
send me an email teamcobraracing@gmail.com
Old 10-03-2011, 01:06 AM   #6501
Geberit's Avatar
Then I'll just have to give it a shot. I hope the price will be in the range of V2.1
Old 10-03-2011, 01:44 AM   #6502
Send a message via ICQ to vitomon Send a message via Skype™ to vitomon
hi guys,
i installed the "blinky" software and ran it with a sp 13.5T v3. worked like a charm. however, i noticed that with my programm box i could adjust "DRRS" levels even with blinky software. is this normal?? what das it do?
i have never run blinky software before so thats why i am asking.
cheers
Yokomo BD7 -- Hobbywing v3 -- Sanwa M11x
May the grip be with you ... always!
vitomon is offline   Reply With Quote
Old 10-03-2011, 03:09 AM   #6503
J SiN's Avatar
Hi all still trying to get to end speed out of my 21.5t speed passion V3 motor. Have tried a lot of setting and have found a little more speed but its getting hot (75c after 5 mins) but I want it to be lower temp wise and make it too 6mins.
My current setting are:
Motor timing 10 deg
FW 213
FDR 6.3
1 For/Brake
2 Drag Brake 0%
3 Voltage Prot 3.0v/cell
4 "DRRS" Punch Level 1
5 Brake Force 37.5%
6 Reverse Force 50%
7 Initial Brake 0%
8 Neutral Range 6%
9 Boost Timing 40
10 Turbo Slope 6
11 OverHeat Prot Enable
12 Turbo Timing 10
13 Start RPM 5000
14 Turbo Delay 0.3sec
15 Timing ACC 350
I have tried more and less boost and it didnt change the temp but more wasn't any quicker.
I tried going to 6000 on the turbo timing and it came in almost at the end of the straight. 4000 was quicker but temp after 3 mins and it was at 75c.
I tried the DRRS punch up higher, but it made the motor run hotter.
Where I am with the setting is only 4th's a lap off the fastest guys but I loose about 3 to 4 meters down the straight every lap. As its holding the car back with my driving is really good atm at worst my consistency is .1 to .2 in a run.
Should I gear it up?
The car (TOP Photon) has all new bearings and nothing is binding and is very free.
Any help would be great
T.O.P. Racing Australia
R.A.B Hobbies
AVID Bearings
J SiN is offline   Reply With Quote
Old 10-03-2011, 03:12 AM   #6504
caltek1's Avatar
Trader Rating: 33 (100%+)
Have you tried a different brand of 21.5 BL motor. Some seem to rev out more than others. I have used the SP 21.5 and found it to be not as fast as some other brands.
Later,
Calvin.
caltek1 is offline   Reply With Quote
Old 10-03-2011, 03:14 AM   #6505
J SiN's Avatar
the 2 guys quicker than me are using the same motor.
I have tried and killed a SP MMM and a Team Powers motor
R.A.B Hobbies
AVID Bearings
Old 10-03-2011, 03:26 AM   #6506
jake95's Avatar
Trader Rating: 27 (100%+)
anyone got a setup for a speed passion 4.5 v3 with 211 stock software
XRAY✯NOSRAM✯SANWA
jake95 is offline   Reply With Quote
Old 10-03-2011, 03:44 AM   #6507
Trader Rating: 22 (100%+)
Motor timing 10 deg
FW 213
FDR 6.3
1 For/Brake
2 Drag Brake 0%
5 Brake Force 37.5%
6 Reverse Force 50%
7 Initial Brake 0%
8 Neutral Range 6%
9 Boost Timing 40
10 Turbo Slope 6
12 Turbo Timing 10
13 Start RPM 5000
15 Timing ACC 350
If you are 4/10ths of the pace and you are 3 to 4 meters down on spped at the end of the straight you should possilbly look at the corner speed of your car!
If the quick guys carry 1 meter more speed through the corners it all adds up as speed is lineal, more speed in the corners equals more speed in the straights...
bjspinner is offline   Reply With Quote
Old 10-03-2011, 03:56 AM   #6508
J SiN's Avatar
I'm quicker through the infield and able to pass the quick guys but soon as the straight comes they just drive straight they drive past me like im standing still.
Only thing different is the speed controller they are using a tekin I think
This is the track in question
R.A.B Hobbies
AVID Bearings
Old 10-03-2011, 05:24 AM   #6509
Originally Posted by vitomon View Post
hi guys,
cheers
Without DRRS also know as punch/instant torque start mode all motors would start cogging on a very soft start as brushless motors are known more as stepper motors.DRRS is not timing its your initial start mode and only works on start doesnt function while the car is in operation.you can adjust from 1 to 9 but you need a good quality high discharge battery on high settings or the motor will cog .
Old 10-03-2011, 07:14 AM   #6510
DS Motorsport's Avatar
Default Racers in exile??
I recently (22-09) ordered a 1S speedo from racersinexile.co.uk but I haven't received a single response from them.
I've sent them several emails and tried calling them several times but no response at all?.
Did anyone have the same experience recently or know what is up with that shop?.
I will try calling them again today but if I can't contact them today I will put in a paypal dispute, first time I ever have to do that.
Next time I will order in Hongkong like I always do, never had an issue with HK shops.
P1-RC.com
DS Motorsport is offline   Reply With Quote
