Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree5Likes
Old 09-30-2011, 07:37 AM   #6466
millbank's Avatar
Originally Posted by bkspeedo View Post
Angelo,
Does this new version also solve the problem of the motor turning backwards in 508_zero?
This is very important for those going to IIC next week as this is the only blinky software correct?
508_no_timing is not allowed in blinky classes, correct?
Not sure what your issue is as I run hobbywing 508 no timing and it runs the right way. Maybe something to do with your firmware or motor?
Xray T2009 / hobbywing v3 120amp /LRP x12 6.5 / wet car
Xray t4'14 / Hobbywing v3 120amp / 13.5/ boost car
Xray t4'15 / Orca Vxx / Orca Rx3 17.5 / blinky car
TEAM DRIVER FOR MMR FLUX
millbank is offline   Reply With Quote
Old 09-30-2011, 07:50 AM   #6467
bkspeedo's Avatar
508_no_timing doees work fine, I'm also using it currently with out a problem.
It's 508_Zero that has the issue.
Brent Klingforth
Sponsors: Awesomatix USA ~ Roche USA ~ ORCA ~ AVID Bearings ~ R1 Wurks
TQ Wire ~ Montech ~ WTF ~ BSR Racing Tires ~ 2mm Design
5280raceway.com [Operated by - Colorado On-Road RC Club]
MILE HIGH INDOOR CHAMPS April 20-23rd 2017 @ www.milehighindoorchamps.com
bkspeedo is offline   Reply With Quote
Old 09-30-2011, 09:35 AM   #6468
Trader Rating: 58 (100%+)
I copy/paste/replaced new files. Then I reloaded the v1_508 on my Jusstock. Is it that easy, or did I miss something?
MC112b is offline   Reply With Quote
Old 09-30-2011, 10:41 AM   #6469
AGNO's Avatar
To me it all works well, in the new version V3 508 No timing the brake has 8 settings and the red LED flashes more.
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Old 09-30-2011, 01:43 PM   #6470
mingnon's Avatar
Originally Posted by COBRARACING View Post
As promised new software these files once unzipped need to be copied to
c drive/programfiles/hobbywing usb 1.63 your actually replacing the two older files .
These files carry 3 types of software
1.508 zero timing more brake options and less sensativity on sensor port means less errors
2.930 mod based on the 119 less sensativity on sensor port means less errors
3.930 stock based on the 211 less sensativity on sensor port means less errors
Link
re508software.zip
http://www.filefactory.com/file/ce0f...08software.zip
please send me an email to teamcobraracing@gmail.com if you cannot dowload from the link .
thank you for your patients
regards Angelo
Angelo
THANKYOU - really appreciate all the time and effort you put into this stuff
---------------------------SMA The Home of GREAT Racing------------------------------
mingnon is offline   Reply With Quote
Old 09-30-2011, 04:00 PM   #6471
chinaman's Avatar
Just noticed this on the HW website ...
What does the USB link update relate to? Cheers ...
... wyrd bi ful rd ...
chinaman is offline   Reply With Quote
Old 09-30-2011, 04:39 PM   #6472
bkspeedo's Avatar
Attachment 814560
this allows you to change settings in the ESC and update software in the ESC via your computer.
Brent Klingforth
Old 09-30-2011, 08:46 PM   #6473
Bishop's Avatar
I'm mildly concerned about the legality of updating firmwares for zero timing without any submission to ROAR about it, even if it's changes to brakes and whatnot, I worry it will be perceived as a chance to sneak in some timing by some people.
While I gather that is not the case, I just feel ROAR test and original firmware and approve that, then it gets tampered with, from what I read another brand got banned and kicked from the list for some time because they updated some firmware to something that turned out to be illegal.
Having said that, I'll have to re-check my Justock, as I can't even remember what version is on that right now, how many 'zero' firmwares do we have to use now?, as I'm getting confused.
QRCCRA
www.qrccra.org.au
www.facebook.com/englandparkraceway
www.myrcm.ch/main?pLa=en&hId[1]=org&dId[O]=4331
Bishop is offline   Reply With Quote
Old 10-01-2011, 12:23 AM   #6474
Angelo mentionned that a speedo was sent to ROAR if I can remember, it is up a few posts or a page or two
Electriquement votre...
Drink EARTH water and save lives! in support of WFP
olly986 is offline   Reply With Quote
Old 10-01-2011, 02:38 AM   #6475
hi, ive been using a duo 2 10.5 with my hobbywing 60amp esc ,but it intermitantly goes into sensorless mode ,will the new software cure this.
do i need to stick to certain motors when using the hobby wing esc
vwvrt is offline   Reply With Quote
Old 10-01-2011, 02:55 AM   #6476
a 10.5t is not the problem, at least here you will get more reply, did you try a different motor also?
And put your setup etc...as mentionned on other thread.
Old 10-01-2011, 03:40 AM   #6477
2wdrive's Avatar
I am using a 120A v2.1 and am really happy with it. The esc never get hot or does not thermal.
A fellow driver has a new 1s 120A without the heatsink or fan attached. With a 10.5 x12 and 2s the esc was getting so hot after just a couple of minutes that the temperature cut off engaged?
He still had the original insert in the motor but the motor was 75 degrees C. So that can't be it i think?
How can the esc thermal with 2s lipo and a 10.5t? Does the 1s 120A get hot that easy without a heatsink? He did reach 104 km/h with his xray x10
www.rc-lemans.de
2wdrive is offline   Reply With Quote
Old 10-01-2011, 03:46 AM   #6478
TeamWTF's Avatar
If your setup is too aggressive it can cause this...
T.O.P. Racing Australia www.topracing.net.au
TeamWTF is offline   Reply With Quote
Old 10-01-2011, 04:06 AM   #6479
I had a good nights racing on tuesday with no problems my setup was
boost 30
boost start 4000
no turbo
acc 300
punch 5
last night at my regular club bigger track my settings were
boost 37
start 4000
acc 300
punch 6
no turbo
brand new cable new sensor board
the car went into sensorless mode in 2 out of the 3 heats then again in the final
I never had this problem with my hobbywing 13.5 and 17.5 even with more aggresive settings.
Ive wasted 4 weeks of club time trying to fix this and i dont want to buy a new motor until i know what causes it, so any thoughts will be appreciated
software is 211
Old 10-01-2011, 04:33 AM   #6480
TryHard's Avatar
Originally Posted by dontfeelcold View Post
running a 4.5 with the 211 stock software. What's a safe starting point?
I've been running the following;
UFO 4.5t
FDR; 113/28 - 7.86
Running mode - 1
Drag Brake - 10%
Voltage protect - 3.2v
DDRS - 1
Brake force - 75%
Reverse force - 25%
Initial brake - Drag brake
Neutral range - 6%
Boost timing - 20
Turbo Slope - 12units/0.1s
Overheat protection - On
Turbo timing - 15
Boost start - 10,000
Turbo delay - 0.3s
Timing ACC - 100RPM/unit
Motor temp 70C
It's a bit funky to take advantage of the boost and turbo, but it's still pretty smooth. Depends a bit on the track, if you need less initial punch, lengthen the timing ACC.
HiH
Ed
