Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 09-29-2011, 03:28 AM   #6451
dontfeelcold's Avatar
Trader Rating: 20 (100%+)
running a 4.5 with the 211 stock software. What's a safe starting point?
dontfeelcold is offline   Reply With Quote
Old 09-29-2011, 03:43 AM   #6452
mingnon's Avatar
Originally Posted by COBRARACING View Post
Will be ready tomorrow
2 changes have been made
1.more brakes like the 211 stock has
2.less sensitivity of the sensor port thus all motors ca be used without the issue of esc switching to sensorless mode.
Ron schurr from roar will be doing the testing hopefully by this weekend as it needs to be roar approved before it can be run in vegas.
regards Angelo
Hi
just a quick question re the sensor issues.
Is anyone else having "issues" when running the 508_no_timing and 21.5t speed passion. Have the car fdr of 2.97 and it still doesn't run anywhere near on par with others running fdr of 3.1
Could this be the firmware or the motor? (have ordered a new hobbywing 21.5t just in case)
sorry its probably a newbie question, but am a little lost
---------------------------SMA The Home of GREAT Racing------------------------------
mingnon is offline   Reply With Quote
Old 09-29-2011, 04:12 AM   #6453
PDR
PDR's Avatar
Trader Rating: 30 (100%+)
Originally Posted by mingnon View Post
Hi
It's entirely possible that you're over geared. No big secret, but I was running around 3.4 or higher around the track at SMA and was competitive enough. The extra punch out of the corners actually sets you up better for the rest of the track. Where you have the option of adjusting the timing on the motor, I tend towards slightly more timing and shorter gearing for more punch.
I haven't run the Speed Passion motor, but this approach has worked pretty well with Tekins, LRP's and Gens Ace.
Don't over crank it either, it all just goes up in heat, sometimes followed by smoke
T4 | X1 | Multiple Kids
2011 Slowest Winner - 21.5 Muchmore Masters & NSW State Titles Demo Class
Making an A Main at a Scotty Ernst event. Awesome. Scotty calling you first in A1. Priceless
PDR is offline   Reply With Quote
Old 09-29-2011, 04:27 AM   #6454
chrisk's Avatar
Trader Rating: 32 (100%+)
Just as phil says, done overgear. I run a orion and a speedpassion both in blinky 21.5 the speedpassion i ran around 3.3 fdr, i installed the timing board that gives more timing but running it about 3/4 around as any more ave nonspeed but heaps of temp.
The orion on the otherhand i am around 2.9fdr as it works best with that motor
TAMIYA - SMOKEM - REEDY
smaracing.org
chrisk is offline   Reply With Quote
Old 09-29-2011, 04:30 AM   #6455
mingnon's Avatar
PDR
thanks for the reply, this gearing stuff is seriously doing my head in, originally had it geared at 3.65 and it was seriously slow, changed it 2 Tuesday nights ago to 3.2 and it was terrible slow still. Had a chat to a couple people and changed it down again, but still slow. Might head over to sma on sunday and race it anyways, i need the practice anyways
Old 09-29-2011, 04:36 AM   #6456
76nova1's Avatar
Trader Rating: 62 (98%+)
My son has a HW 2.1v 60a esc he installed the 508 software but the LED does not flash in neutral. The programmer shows that the 508 software is installed and it seems to be a bit slower like the timing is gone. Any help would be great.
Team Pit Racers-Fastest Guys In The Pits!
76nova1 is offline   Reply With Quote
Old 09-29-2011, 05:34 AM   #6457
I asked the question earlier and was answered. Look closely, if the red led is on in neutral, watch for a faint blink. It blinks about twice a second so it is fairly fast and with the LED being fairly dim it is hard to detect. We have several racers using them and they are all the same.
www.norcarracing.com
NORCAR @ The Gate
old_dude is offline   Reply With Quote
Old 09-29-2011, 07:23 PM   #6458
76nova1's Avatar
I will check that Thanks OLD DUDE
Old 09-29-2011, 07:34 PM   #6459
chrisk's Avatar
I was the same for a while but in 21.5 it is about consistent lap times and smooth driving.
Don't have that right and you will feel slow. Anywhere around the low 3's is the right fdr and then also make sure the car is free, good bearings, free driveline, all those things are needed in 21.5.
If you need any tips I am there of a Tuesday as well, come and see me
Chris
PDR
smaracing.org
Old 09-29-2011, 09:48 PM   #6460
mingnon's Avatar
PDR and chrisk
thanks for you help with this stuff, still trying to get my head around it.
Going to just run the serpent in the 21.5 class on sunday and tuesday night and see how it goes, and work on it from there.
Really appreciate the time you guys give us newbies at sma
Cheers
Old 09-30-2011, 12:13 AM   #6461
Originally Posted by Benzaah View Post
I ran a 120 amp V2.1 with a D3 all practice at 5.1 and then dropped down to 4.9 with the revtech and 211. I could not keep up with the car set up and struggled with tyre prep and my times suffered. I did a 21.9 in practice which was around 0.6 off the event pace but my car was just as quick all weekend. Interestingly i ran 60 boost 0 turbo all weekend and only suffered in the 2nd last qualifier when i bumped up the motor timing past 1 notch looking for more speed and the car felt like it went into sensor less mode.
Hi There
Myself and a friend were running the Trinity D3 and Hobbywing 120 amp esc combination last weekend and he unfortunately cooked his motor in the last heat. These are our settings we were trying
17.5 duo 3 standard timing
ddrs 5
boost timing 40
turbo slope 18
turbo timing 25
start rpm 4000
turbo delay 0.1s
timing acc 300
fdr 5.7-5.9
hobby wing 211 stock software
This was the first time out for us using the Hobbywing escs and we could use some help.
People running Tekin escs and Lrp motors were running 4.0 fdr
Toolmannz2 is offline   Reply With Quote
Old 09-30-2011, 05:14 AM   #6462
venom54's Avatar
Default D3 MOTORS
Originally Posted by Toolmannz2 View Post
Hi There
ddrs 5
boost timing 40
turbo slope 18
turbo timing 25
start rpm 4000
turbo delay 0.1s
timing acc 300
fdr 5.7-5.9
The last setup we tried with a D3 had the motor temp at 59 Celcius. below is the specs.
ddrs 5
boost timing 50
turbo slope 18
turbo timing 20
start rpm 9000
turbo delay 0.1s
timing acc 300
Fdr 6.9 to 7.4 depending on track.
Hobby wing 211 stock software
Cheers Ren
Play hard but be nice to your parents!
VBC RACING|ASSOCIATED|XRAY|TEAM POWERS|THUNDER TIGER|HOBBYWING|HPI|WTF FANS|ORION AND MORE IN STORE.
145 COMO PARADE EAST 3195 PARKDALE VICTORIA AUSTRALIA.
www.rabhobbies.com.au
venom54 is offline   Reply With Quote
Old 09-30-2011, 07:00 AM   #6463
COBRARACING's Avatar
As promised new software these files once unzipped need to be copied to
c drive/programfiles/hobbywing usb 1.63 your actually replacing the two older files .
These files carry 3 types of software
1.508 zero timing more brake options and less sensativity on sensor port means less errors
2.930 mod based on the 119 less sensativity on sensor port means less errors
3.930 stock based on the 211 less sensativity on sensor port means less errors.
please send me an email to teamcobraracing@gmail.com and i will email you back the files.
thank you for your patients
regards Angelo
Email : teamcobraracing@gmail.com or ae@hobbywing.com
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Old 09-30-2011, 07:17 AM   #6464
J SiN's Avatar
what would be the best software to use with a 21.5t sp v3 motor
930/211/213
have only tried 211 but im lacking alot of top end atm
T.O.P. Racing Australia
R.A.B Hobbies
AVID Bearings
J SiN is offline   Reply With Quote
Old 09-30-2011, 07:45 AM   #6465
bkspeedo's Avatar
regards Angelo
Angelo,
Does this new version also solve the problem of the motor turning backwards in 508_zero?
This is very important for those going to IIC next week as this is the only blinky software correct?
508_no_timing is not allowed in blinky classes, correct?
Brent Klingforth
Sponsors: Awesomatix USA ~ Roche USA ~ ORCA ~ AVID Bearings ~ R1 Wurks
TQ Wire ~ ProtoForm ~ BSR Racing Tires ~ 2mm Design
5280raceway.com [Operated by - Colorado On-Road RC Club]
MILE HIGH INDOOR CHAMPS April 20-23rd 2017 @ www.milehighindoorchamps.com
bkspeedo is offline   Reply With Quote
