Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree2Likes
Old 09-24-2011, 05:24 AM   #6421
COBRARACING's Avatar
Originally Posted by scoop View Post
Is there a UK supplier for these?
Not as yet but we are working on it .
Email : teamcobraracing@gmail.com or ae@hobbywing.com
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Old 09-24-2011, 05:27 AM   #6422
Originally Posted by defcone View Post
I tried the 17.5t dualsky, and I could only get it to be within 75 deg. by turning the timing on the can down to 9-11 deg.
if your using the new dualsky motor now that's one of the best motors i have ever seen with that motor they have thought of everything .75 deg is pretty normal.
Old 09-24-2011, 06:37 AM   #6423
defcone's Avatar
Trader Rating: 15 (100%+)
Want to give me a setup? I couldn't get that motor to go quick.
Originally Posted by olly986 View Post
And what is wrong with 75 deg? this is fairly normal heat for a motor.
If you put more of your setup, fdr etc... we can guide you better
It was more helping him than anything, they come standard with 17deg. timing.
defcone is offline   Reply With Quote
Old 09-24-2011, 02:19 PM   #6424
once you update the usb link software which is actually done automatically when your connected to the internet and you have open the usb link all software like 508 and many more are updated.The only time that i will send out a control file and an ini file is when there is no usb link software update but we have new say stock or mod sotware in two files.
Thanks for the information, now just to tweek this for some 1/12 scale carpet oval
InCaRnAtE is offline   Reply With Quote
Old 09-25-2011, 12:13 AM   #6425
TeamWTF's Avatar
defcone and others....
What FDR were you using in 17.5 at Whalan? Was Dan using Hobbywing?
Cheers
Phill
T.O.P. Racing Australia www.topracing.net.au
TeamWTF is offline   Reply With Quote
Old 09-25-2011, 12:23 AM   #6426
caltek1's Avatar
Trader Rating: 33 (100%+)
Phill,
Dan was using a Venom speedie with 211 SW. I believe he was also using a Duo3 motor.
Later,
Calvin.
caltek1 is offline   Reply With Quote
Old 09-25-2011, 12:56 AM   #6427
defcone's Avatar
Cheers
Phill
I Run 5 everywhere.
Old 09-25-2011, 01:05 AM   #6428
TeamWTF's Avatar
Ahh... 211 and duo 3... Nice.
5 everywhere... I should have guessed..
Any vids of the 17.5 heats?
Old 09-25-2011, 04:39 AM   #6429
I have some news 1st week of october there will be some samples of the V3 not prototypes so we are closer to a release.
The V3 was tested by micheal at the hobbywing cup in shanghai last weekend with excellent results .Mr si zheng also known as sultan who is Hobbywings test driver will be running some tests next week .
So guys you have been patient all these months and thank you for that but we need to bring you a perfect product so nearly there .
It has been decided by the team of 4 Myself,michael,Pan and Jack that the
v3 will not be available from Hong kong especially for the 1st year of sales .
Old 09-25-2011, 04:54 AM   #6430
blade072's Avatar
Trader Rating: 98 (100%+)
should we be getting excited angelo?????
David Randall
AWESOMATIX A800 ★ MUCHMORE ★ R1 WURKS ★
TEAM XRAY X116 ★ SANWA M12 ★ SILVERBACK ★
HOBBYWING ★ RCMAKER ★ VOLANTE RC ★
blade072 is offline   Reply With Quote
Old 09-25-2011, 05:58 AM   #6431
yes :nod :
Old 09-25-2011, 10:56 AM   #6432
liljohn1064's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to liljohn1064 Send a message via MSN to liljohn1064 Send a message via Yahoo to liljohn1064
We only manufacturer the current world champion GT series nothing else .cirtix made by ZTW .
I'm trying to work on approval for Justock in VTA. They will not accept that the Justock is no timing and no boost. I will be sending one of the two I just ordered for series approval once I receive them. RobK is on the boards here and the current keeper of the USVTA rules. Maybe you could PM him and help him with the particulars of getting this approved for this spec racing series.
Thank you so much for taking the time to respond!
John Higgins
liljohn1064 is offline   Reply With Quote
Old 09-25-2011, 09:08 PM   #6433
Benzaah's Avatar
Trader Rating: 21 (96%+)
Cheers
Phill
I ran a 120 amp V2.1 with a D3 all practice at 5.1 and then dropped down to 4.9 with the revtech and 211. I could not keep up with the car set up and struggled with tyre prep and my times suffered. I did a 21.9 in practice which was around 0.6 off the event pace but my car was just as quick all weekend. Interestingly i ran 60 boost 0 turbo all weekend and only suffered in the 2nd last qualifier when i bumped up the motor timing past 1 notch looking for more speed and the car felt like it went into sensor less mode.
AERCCC - ARCR - RRCSA
Adelaide RC
Walter Rc Hobby
Benzaah is offline   Reply With Quote
Old 09-25-2011, 09:37 PM   #6434
please send me your email john .at teamcobraracing@gmail.com
Old 09-26-2011, 08:58 AM   #6435
ByteStream's Avatar
Default Major Problems
Picked up a new 1S Xerun and having problems ..
I got it out of the box, wired it up correctly, calibrated it and gave it a bench test, all seemed to be well.
I then upgraded to 508_zero, calibrated it, and the motor runs in reverse. I tried reversing the channel on the radio but that does not help, that only makes the forward position the throttle. I then took a look at the software and there is a Motor Direction box specifies CCW (Counter-Clockwise is the wrong direction), however the box is disabled and you are not able to change the setting. What's the deal?
As the fustration was growing, I decided to try and upgrade to another software version, 211_Stock, I did this and calibrated it, and all seemed good again. This software version does not have a Motor Direction box but at least the motor turns in the right direction.
Also, this has probably been mentioned but what gives with needing a 2s lipo to configure the speedo? If you set the Lipo Cutoff to anything but disabled, then you can't even get the speedo to work with a 1S, it just sounds the alert that the voltage is too low. I don't run my packs that low, so I am not overlly worried about it, but it is an advertised feature of the speedo and it does not work.
So .. I need to run blinky, was planning on using it at IIC in Vegas which is a week away. What is the solution? Currently 508 is the only approved software for blinky. I have heard another 508_zero revision is in the works, but does it address the issue I am having, and not just the sensor sensitivity issue? And will it be out before IIC?
UPDATE
I just tried loading SP 508_no_timing software .. and it works. The motor goes in the right direction. I did not change anything else other than software. The Motor Direction box specifies CCW just like the HW software, but it goes in the right direction (oposite of the HW software), again you are unable to change this setting as it is disabled in both software packages. Of course you also have to disable the Lipo cutoff feature as it does not work with 1s lipo packs as the speedo thinks even a fully charged 1s pack is too low a voltage to do anything other than beep at you.
As I see it, there are 2 bugs in the 508_zero software, Motor Direction and Lipo Cutoff for 1S applications. I hope these will be addressed in the next version of 508 in addition to the sensitivity issue improvement.
Timeframe?
ByteStream is offline   Reply With Quote
