Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree5Likes
Old 09-23-2011, 07:48 AM   #6391
Default red led not blinking.
I am not getting the flashing red led when my 1-S esc is on the 508 non_timing software as required for the class.
Any suggestions?
www.norcarracing.com
NORCAR @ The Gate
old_dude is offline   Reply With Quote
Old 09-23-2011, 08:20 AM   #6392
liljohn1064's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to liljohn1064 Send a message via MSN to liljohn1064 Send a message via Yahoo to liljohn1064
Can someone confirm for me that Hobbywing does in fact create and manufacture SpeedPassion ESCs? If so what are the model differences or are they simply badged differently? Is the firmware different?
John Higgins former student of The Ian Ruggles Negative Reinforcement Driving School. The "Team Principal".
liljohn1064 is offline   Reply With Quote
Old 09-23-2011, 09:25 AM   #6393
2wdrive's Avatar
Angelo, i send you a PM regarding an EZrun 60A v2.
www.rc-lemans.de
2wdrive is offline   Reply With Quote
Old 09-23-2011, 10:04 AM   #6394
the 2.1 is basically the same as Xerun, software is very similar (not ref number) but Angelo prefers that each software is used with own speedo.
the 2in1 box is the same too but with different software again.
Electriquement votre...
Drink EARTH water and save lives! in support of WFP
olly986 is offline   Reply With Quote
Old 09-23-2011, 10:11 AM   #6395
Thank you! That's what I thought. I don't plan on messing with the firmware as it is just a stock ESC.
Old 09-23-2011, 10:29 AM   #6396
ByteStream's Avatar
Just picked up a HW 1S ESC -
Is 508_zero the software we have to use for no-timing classes (13.5/17.5)?
What is the bug in 508_zero that I saw a mention of a couple of posts back?
What is the equivalent SP software to 508_zero, and does it also have this bug as well?
ByteStream is offline   Reply With Quote
Old 09-23-2011, 01:04 PM   #6397
I just say it is preferable to stick to own software !! bug will be done in a matter of days Angelo said.
Old 09-23-2011, 02:20 PM   #6398
Originally Posted by M7H View Post
Not with the 1S, you can use a 1S lipo for that.
So you where able to do so the first time, with only 1S lipo attached?
Which FW did you flash it to?
I believe the "no-timing" firmware can only work on the 1S, with "lipo protection" switched off. So maybe hook it up to 2S, and change this setting?
I had the 508 firmware on it .... how I got it I'm not really sure .... but I think I got it when I checked for updates with the software. Flashed it back to the original firmware and now it works just fine, thanks for the info.
InCaRnAtE is offline   Reply With Quote
Old 09-23-2011, 03:48 PM   #6399
ByteStream's Avatar
That answers none of my questions.
Old 09-23-2011, 05:28 PM   #6400
COBRARACING's Avatar
We only manufacturer the current world champion GT series nothing else .cirtix made by ZTW .
Email : teamcobraracing@gmail.com or ae@hobbywing.com
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Old 09-23-2011, 05:30 PM   #6401
Not acutally a bug just to sensitive on the sensor port for some motors not all basically mod that generates very hig current flow thus interfering with the signal.
The new 508 will have more brakes and less sensitivity at the sensor port .
Old 09-23-2011, 05:33 PM   #6402
once you update the usb link software which is actually done automatically when your connected to the internet and you have open the usb link all software like 508 and many more are updated.The only time that i will send out a control file and an ini file is when there is no usb link software update but we have new say stock or mod sotware in two files.
Old 09-23-2011, 05:36 PM   #6403
Any suggestions?
Just tested it and it worked with mine will flash twice per second .Do a calibration of your radio forward,neutral ,reverse and you will see it will be fine .
Old 09-23-2011, 05:36 PM   #6404
thank you go it .
Old 09-23-2011, 06:14 PM   #6405
Hi Guys
Just making you aware of our Battery brand .I have attached two photo's for you to view .
NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE-p9216525%2520copy.jpg   NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE-saddle-new.jpg
