Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree5Likes
Old 09-19-2011, 02:28 AM   #6346
FunkyDunky's Avatar
Originally Posted by hacker View Post
turbo kicking in before all the boost was used up.....119
or traditionally using all boost, then turbo coming in....211
I did not find any difference on the track to be honest, well at least I can say I'm not good enough to know.
Biggest difference between the two is heat, 211 basically run cooler but you FDR has to be higher in order to get the best out of things eg. 119 was 5.5 when using 211 use 6.2.
I recently won a regional series here in the UK and found the 211 software to run much cooler than 119. Ask anyone that saw my car nothing was faster in a straight line or punch out of the corners. The HW speedo made an average(At Best) driver looks superb!
FunkyDunky is offline   Reply With Quote
Old 09-19-2011, 02:43 AM   #6347
FunkyDunky's Avatar
Thumbs up
I just wanted to come on here and say a big thank you to Hobby Wing! Using your ESC this year I won my first championship here in the UK (STCC TC4 Class). Nothing could touch the HobbyWing ESC for speed and punch all year with the ESC winning all but 1 of the rounds
Keep up the excellent work and I'm looking forward to running the V3 as soon as I can.
Don't forget you can check out all of my set up on my website:-
http://www.stockracer.co.uk/hobbywing.html
Thanks again!!
Old 09-19-2011, 03:10 AM   #6348
venom54's Avatar
Default D3 Fantom 13.5 Boosted.
Originally Posted by mwoods View Post
Anyone got a realy good setup using a d3 13.5 ?
2-0%
3-3.0v
4-level6
5-87.5%
6-100%
7-20%
8-6%
9-50
10-fastest
11-enable
12-14
13-9000
14-off
15-350
2 notches on motor advanced
7.2 FDR to tame punch
(to tame wheel spin)
4-5
9-40
12-24
Set up used on T3 2011 at SERCCC 17-18 September with 120 XERUN with 213 software. Driven by Michael Clarke for 3rd place.
This setup was fast, smooth and temps well below 60 celcius.
Cheers Ren
Play hard but be nice to your parents!
VBC RACING|ASSOCIATED|XRAY|TEAM POWERS|THUNDER TIGER|HOBBYWING|HPI|WTF FANS|ORION AND MORE IN STORE.
145 COMO PARADE EAST 3195 PARKDALE VICTORIA AUSTRALIA.
www.rabhobbies.com.au
venom54 is offline   Reply With Quote
Old 09-19-2011, 03:39 AM   #6349
COBRARACING's Avatar
Thanks again!!
Your welcome but more to it we would like to thank you for putting your trust,faith and confidence in our products and congratulations once again on your achievement keep up the great work .
regards Angelo
Email : [email protected] or [email protected]
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Old 09-19-2011, 03:49 AM   #6350
kermit's Avatar
Originally Posted by SeanV View Post
Hi, would you mind posting your setting please.
I am using a similar combination and still struggling to find a good setup for the ESC/Motor comno.
Atm I am getting blasted down the straight by the Tekin/X12 guys.
Thx
Try this ... NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE
Don't forget to temp it after a couple of minutes. If it's coming off cold try adding a little end bell timing.
Adelaide RC Team Driver - www.adelaiderc.com.au
XRAY T4 | Futaba | HOBBYWING | Muchmore
kermit is offline   Reply With Quote
Old 09-19-2011, 05:54 AM   #6351
Thanks again!!
How many did you get through in a season?
scoop is offline   Reply With Quote
Old 09-19-2011, 09:28 AM   #6352
FunkyDunky's Avatar
Motors or ESC?
ESC none, motors x1 Rota and x1 sensor board.
Old 09-19-2011, 09:55 AM   #6353
Born2Run's Avatar
Originally Posted by kermit View Post
I've been running the v2.1 120A esc with a Novak ballistic 17.5 for about 8 months now. It's been a great setup which has consistently kept up with the best of the rest.
However lately I've had problems where part way through a race the speedy drops into what feels like non boosted mode. Often but not always turning the switch off and on again solves problem. In some cases no amount of on/off switching will fix it. I tried changing the sensor wire but it made no difference so I swapped to a D3 motor and the problem went away. Today I bolted in a brand new Novak and it worked for a run or two before the problem returned again. The speedy had a constant frequency flashing green light when the car is in neutral.. Any idea what this means?
One of the guys at the track suggested running less end bell timing which seemed to help (I ran 25 deg instead of the default 30 deg on the novak). Although I'm not sure if it was the timing or the reduced tension on the end bell screws which helped more, but the problem didn't return for the rest of the day
Has anyone else experienced this problem before?
I have the same problem with a Bullistrorm 4.5T motor.Running less end bell timing (-1) helps a lot but the problem returns again after 4-4.30 mins.I excluded the sensor cable and the sensor board as i tried both with another motor and they're working OK.Next step is to reduce my boost and turbo settings by 3 units each as well the lipo cutoff from 3.2v to 3v/cell and finally if all these don't fix the problem i'll try a different shimming on the rotor.I cannot think something else and i want to turn back the end bell timing to 0 because on -1 i noticed a significant drop in performance otherwise i have to buy another motor.
Whatever
Born2Run is offline   Reply With Quote
Old 09-19-2011, 10:06 AM   #6354
roger999's Avatar
Default settings for 10.5
hi, just wanted to find better settings for my 10.5 motor, at the moment i used stock 211:
drag - 10%
ddrs - 7
boost timing - 50
turbo open - 18/0.1
turbo timing - 14
boost - 4000
turbo delay- 0.2
boost timing - 500 rpm/deg
fdr - 7.9
I could feel that car had a "kick" too late, i mean it was on the half of the straight, i need to change something to get a "kick" faster... Mayby boost on 1000 or 2000? change fdr on 8.3? Or mayby more punch like 9?
Chacked the temp of the motor was about 44 C.
facebook.com/rogergrafix
roger999 is offline   Reply With Quote
Old 09-19-2011, 11:40 AM   #6355
Originally Posted by venom54 View Post
2-0%
3-3.0v
4-level6
5-87.5%
6-100%
7-20%
8-6%
9-50
10-fastest
11-enable
12-14
13-9000
14-off
15-350
4-5
9-40
12-24
Cheers Ren
ill give that a try next weekend also will it work with 211 firmware
thanks
stcc ssb tires, ko ,gm motors, demon products lipos, hobbywing speedo
mwoods is offline   Reply With Quote
Old 09-19-2011, 02:04 PM   #6356
drag - 10%
ddrs - 7
boost timing - 50
turbo open - 18/0.1
turbo timing - 14
boost - 4000
turbo delay- 0.2
fdr - 7.9
Turn your turbo delay off and reduce the boost timing to 350. You have got the rev start setting very low. I would lower it 6000. Watch the motor heat.
Old 09-19-2011, 02:05 PM   #6357
Motors or ESC?
Thats impressive
Old 09-19-2011, 02:25 PM   #6358
FunkyDunky's Avatar
Thats impressive
However I did blow 6 other motors in testing throughout the year trying to get them to go as fast as a Corally. It just isn't going to happen though.
Old 09-19-2011, 03:05 PM   #6359
drag - 10%
ddrs - 7
boost timing - 50
turbo open - 18/0.1
turbo timing - 14
boost - 4000
turbo delay- 0.2
fdr - 7.9
Roger what is your motor? and chassis, 8.3 fdr is too much, 7.50/7.70 wouold be better
Electriquement votre...
Drink EARTH water and save lives! in support of WFP
olly986 is offline   Reply With Quote
Old 09-19-2011, 06:00 PM   #6360
rc_square24's Avatar
XERUN 120a w/prog. box for sale if anyone is interested, other stuff as well.
M11x / LRP Touch / Photon / 12R5.1 / Batteries / Tire Truer / x12 13.5 / ESC + MORE!!
rc_square24 is offline   Reply With Quote
