Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree5Likes
Old 09-16-2011, 03:02 PM   #6301
Johnny-RC's Avatar
Trader Rating: 24 (100%+)
Products I run
| Hobbywing | Gens Ace | Highest Servos | Sanwa | Team Associated | AKA |
Johnny-RC is offline   Reply With Quote
Old 09-16-2011, 06:38 PM   #6302
Guys just a quick question about the limits of the dynamic timing on the software. Someone said to me the other day that you can only go to 60 degrees of total timing. Does this mean that if you set both boost and turbo to 40 each (total of 80 degrees) you will only get 60 degrees of actual timing from the speedy? Or will you get the full 80 degrees and blow your motor?
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 09-16-2011, 08:14 PM   #6303
PDR
PDR's Avatar
Trader Rating: 30 (100%+)
My understanding is that the 211 software is capped at a total of 64 "steps". In your example 40+40 would max out at 64. Turbo doesn't start until all boost has been applied and the turbo delay has elapsed under full throttle. I don't think anyone has definitively tabled a quantitative relationship between "steps" and degrees.
Looking for chassis | Multiple Kids
2011 Slowest Winner - 21.5 Muchmore Masters & NSW State Titles Demo Class
https://www.facebook.com/phatdadracing/
Making an A Main at a Scotty Ernst event. Awesome. Scotty calling you first in A1. Priceless
PDR is offline   Reply With Quote
Old 09-17-2011, 12:50 AM   #6304
Is there any version that dosen't apply the turbo limit before full boost?
Powered by Falco
Old 09-17-2011, 02:12 AM   #6305
hacker's Avatar
Trader Rating: 140 (100%+)
in this case, boost will be the value you have selected 40. Even though you have selected 40 for you turbo, your real world value for turbo is 24 , since 64 is your magic number for the total combined timing. Hope that makes sense
hacker is offline   Reply With Quote
Old 09-17-2011, 02:19 AM   #6306
hacker's Avatar
hmmm for some reason at this time, I'm having a hard time understanding that sentence
however, I hope the following makes sense.
in version 119, turbo could be operated before full boost has been used up.
in 211, all steps of boost had to be used up, and then only turbo is applied.
Old 09-17-2011, 02:21 AM   #6307
in version 119, turbo could be operated before full boost has been applied.
thats the answer I am looking for... Any idea where I can get this version in either HW or SP software?
Powered by Falco
Old 09-17-2011, 02:22 AM   #6308
PDR
PDR's Avatar
I think the 213 version starts to apply turbo once the turbo delay has elapsed, before full boost is applied, but someone may correct me.
Old 09-17-2011, 02:22 AM   #6309
hacker's Avatar
having said that, I'm hoping off the hobbywing bandwagon due to a terrible run of luck, and gone to black diamond. I hope the BD will hold its own
Old 09-17-2011, 02:25 AM   #6310
hacker's Avatar
a few months ago, it was available on the hobbywing website. They were both(119 & 211) on the same file, along with the mod and older stock versions.
Old 09-17-2011, 02:47 AM   #6311
So does that mean there is no point in setting turbo delay?
YZFAndy is offline   Reply With Quote
Old 09-17-2011, 03:00 AM   #6312
defcone's Avatar
Trader Rating: 15 (100%+)
Hobby wing site has it just go there and go.to USB download.
defcone is offline   Reply With Quote
Old 09-17-2011, 03:03 AM   #6313
hacker's Avatar
I think you have misunderstood a little
with 211, using all the boost, turbo will come in to whatever delay you have selected
for example, you use up all your boost in 2secs. Your turbo will come in to whatever value you have selected. So if you have selected delay at 1.5sec, your turbo will come in at the 3.5 sec from a standing start.
Old 09-17-2011, 03:08 AM   #6314
hacker's Avatar
turbo kicking in before all the boost was used up.....119
or traditionally using all boost, then turbo coming in....211
I did not find any difference on the track to be honest, well at least I can say I'm not good enough to know.
Old 09-17-2011, 03:14 AM   #6315
The new system is pretty good however control of.when and where timing is applied is not as good as the r10 I am using (in most ways) however runs lower temps for better power. Its still better than the SP stock software my brother is playing with which is acting sooooo retarded. At least now I know why.
Powered by Falco
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
