Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree5Likes
Old 09-16-2011, 04:02 AM   #6286
Thumbs up
if It preforms like it looks, as I'm sure it will it will be a winner for every one involved .
big paul is offline   Reply With Quote
Old 09-16-2011, 04:02 AM   #6287
jake95's Avatar
Trader Rating: 27 (100%+)
WOW that is nice
XRAY✯NOSRAM✯SANWA
jake95 is offline   Reply With Quote
Old 09-16-2011, 04:06 AM   #6288
CCristo's Avatar
Trader Rating: 55 (100%+)
Will the BEC voltage be adjustable on the V3? It would be nice to set it to 7.4 volts (or whatever) to take advantage the HV servos.
Chris Cristo
Pro-Line RacingHobbywingMIPBOOMrcFutabaPT RC Racing Oils
CCristo is offline   Reply With Quote
Old 09-16-2011, 06:03 AM   #6289
Originally Posted by COBRARACING View Post
I am trying to implement 10 modes for the lcd programmer with all the software installed on the lcd this way yes you can do away with the pc and have the pc only when you need to upgrade the lcd usb link firmware and updates of new control firmware.This is my plan
This would be top Angelo, but will we be able to upgrade our actual 2 in 1 box or are you looking at a new box altogether?
Electriquement votre...
Drink EARTH water and save lives! in support of WFP
olly986 is offline   Reply With Quote
Old 09-16-2011, 06:19 AM   #6290
mingnon's Avatar
Default newbie/confussed
Hi
running extreme stock 60a esc
running in 21.5t stock class that requires "blinky" mode (no turbo etc).
have been trying to work out how to get it to flash (like others esc does) to no avail. Have got turbo turned to "off" via lcd program box, is this all that is needed for this esc in "blinky mode"
Sorry for newbie questions
---------------------------SMA The Home of GREAT Racing------------------------------
mingnon is offline   Reply With Quote
Old 09-16-2011, 06:23 AM   #6291
Originally Posted by mingnon View Post
Hi
Not sure about this model, I do not have it, but if blinky is the setup, then your speedo should have a light blinking I guess...
Old 09-16-2011, 06:35 AM   #6292
Default blink mode
Not to sure about blink mode,but if you pull the censer wire this makes the speedo blink.Like I say not to sure.
Old 09-16-2011, 06:46 AM   #6293
PDR
PDR's Avatar
Trader Rating: 30 (100%+)
Hi
You need to load the "no timing" software from your computer, via the LCD box. If you have any turbo/boost parameters available (even if they're turned off), you won't be in "blinky" mode.
If you don't have the software on your PC and an LCD card, you'll need to ask someone to help you out.
Looking for chassis | Multiple Kids
2011 Slowest Winner - 21.5 Muchmore Masters & NSW State Titles Demo Class
https://www.facebook.com/phatdadracing/
Making an A Main at a Scotty Ernst event. Awesome. Scotty calling you first in A1. Priceless
PDR is offline   Reply With Quote
Old 09-16-2011, 08:09 AM   #6294
You dont ever need to remove the plug from the receiver again as the new programming method is no longer through the rx port .the front 3 pins you see on the esc is the port for programming and a lead will be supplied so all you do is plug your lcd programmer to the esc via this cable .
What con i say. Im a happy man. Looking forward to it
scoop is offline   Reply With Quote
Old 09-16-2011, 08:29 AM   #6295
Born2Run's Avatar
Hi Guys
I have attached the original photos of one of two prototypes the first proto is being track tested in China as we speak .
It does have it's decals and graphics missing but like i have said in the past the unit is smarter,smaller,new software plus a soft switch with build in led's including a new style heatsink for all axis airflow plus the new programming method that doesn't violate any patents of any brand .
I have no confirmed date of release but im sure it wll be soon as all the work is now complete just need to get into mass production now .
Hobbywing is very serious and committed to bringing its customers the best of the best .Management would like to apologise for the time it has taken but we wanted the new v3 to be the best for our customers .Alot of you might have though why did we do all the work for other oem customers but not our own but to be honest behind the scenes there was alot going on with our design team that no one knew about and that i could not talk about but i always knew the V3 was always destined only for the Hobbywing brand .
thank you for your patients.
regards Angelo
Angelo what about the HOBBYWING SCT PRO? It's different from the v3?
Whatever
Born2Run is offline   Reply With Quote
Old 09-16-2011, 09:36 AM   #6296
tommi's Avatar
Hi
Hook the ESC to your PC/laptop via the program box, run the Hobbywing USB Link software, turn on your ESC with the battery connected, and "upgrade"/re-flash your ESC's firmware to 508 no_timing, and you're in blinky mode!
tommi is offline   Reply With Quote
Old 09-16-2011, 01:36 PM   #6297
This is a 1/8th scale
Old 09-16-2011, 01:40 PM   #6298
mingnon's Avatar
Tommi, PDR and other
THANKYOU - have been trying to work it it for ages, it makes perfect sense now
Old 09-16-2011, 02:32 PM   #6299
Do I need to run the speed controller fan on a xtreme stock, 13.5t, indoor carpet?
YZFAndy is offline   Reply With Quote
Old 09-16-2011, 03:32 PM   #6300
Too many variables to give a straight yes or no. It doesn't weigh anything and is easily added or removed. Start with it off and monitor it as you go.
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
