Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree5Likes
Old 09-05-2011, 04:29 AM   #6151
J SiN's Avatar
I think he meant the speedpassion V3 motor
T.O.P. Racing Australia
R.A.B Hobbies
AVID Bearings
J SiN is offline   Reply With Quote
Old 09-05-2011, 04:42 AM   #6152
chrisk's Avatar
Trader Rating: 32 (100%+)
Thanks for the help guys, running an orion vortex and reverse is at 100% already.
Capacitor is standard 1 that came with the just stock speedy.
I wont have time to try a bigger capacitor before tommorow night but will for next run and hopefully the update then as angelo says will give better braking
Just driving to fast i think
TAMIYA - SMOKEM - REEDY
smaracing.org
chrisk is offline   Reply With Quote
Old 09-05-2011, 04:43 AM   #6153
defcone's Avatar
Trader Rating: 15 (100%+)
Yeah.
defcone is offline   Reply With Quote
Old 09-05-2011, 09:11 AM   #6154
Originally Posted by mwoods View Post
yeah running 500 acc will make the motor cooler then running say 300
Thats what i did. Made no difference. Can you take the fdr too low and create heat? With the 17 pinion i was running 8.4.
scoop is offline   Reply With Quote
Old 09-05-2011, 12:21 PM   #6155
NTS
I tried the bigger capacitor on my Extreme Stock to improve the braking but it made no difference
It seems some people have good brakes and some don't, I'm still looking for a solution...
NTS is offline   Reply With Quote
Old 09-05-2011, 01:26 PM   #6156
Barry_Hughes's Avatar
Originally Posted by FunkyDunky View Post
+1
+1
Built it !
Raced it !
Wrecked it !
Barry_Hughes is offline   Reply With Quote
Old 09-05-2011, 01:36 PM   #6157
Scoop.
80c is fine
re settings try taking some of the boost and or turbo off.
I am now running a GM 21.5 and found that if I run the maximum 64 the motor gets hot (have had a 120c)
taking some of the boost and turbo off made the car quicker and a lower temp, so a double gain
also start rpm makes a big difference try getting the boost coming in at a higher rpm
this is with 211 stock
Built it !
Raced it !
Wrecked it !
Old 09-05-2011, 01:55 PM   #6158
Originally Posted by Barry_Hughes View Post
Scoop.
80c is fine
hi barry , can u email me ur final setup for colchester , wudnt mind trying it with a d3 21.5 motor.
stcc ssb tires, ko ,gm motors, demon products lipos, hobbywing speedo
mwoods is offline   Reply With Quote
Old 09-05-2011, 09:16 PM   #6159
Scoop.
80c is fine
We dont have problems with 211 only 518 but, we prefer the way 518 runs on carpet. I think its gonna have to be big fan or 211
Old 09-06-2011, 12:19 AM   #6160
COBRARACING's Avatar
Originally Posted by defcone View Post
Yeah.
my misunderstanding my fault sorry
Email : teamcobraracing@gmail.com or ae@hobbywing.com
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Old 09-06-2011, 12:23 AM   #6161
Hi Guys
Just some info for all of you to know so there is no confusion the orion esc is a 2.1v hobbywing not a V3.
Hobbywing software will not work on the orion or the orion on the hobbywing not even the 2 in 1 programmer will work .
thanks guys
Angelo
Old 09-06-2011, 12:27 AM   #6162
Default V3 ESC
Are there any news about the smartphone connectivity on the new V3 speedcontrollers?
Will we be able to change settings in the ESC from the drivers stand?
Log data in realtime on the phone?
Let the info flow...
snabbgas is offline   Reply With Quote
Old 09-06-2011, 01:04 AM   #6163
defcone's Avatar
Originally Posted by COBRARACING View Post
Hi Guys
thanks guys
Angelo
Are the internals the same? Just different board layout?
Old 09-06-2011, 01:49 AM   #6164
Benzaah's Avatar
Trader Rating: 21 (96%+)
Set the Reverse force to 100%
Great work guys with the support of other hobbywing users on this thread excellent work .
Defcone, Seeing as your in a helpful mood have you got a starting set up for 17.5 boosted at Whalan??? We are expecting to go through a few motor's with that back straight...
AERCCC - ARCR - RRCSA
Adelaide RC
Walter Rc Hobby
Benzaah is offline   Reply With Quote
Old 09-06-2011, 01:55 AM   #6165
P.I.M.P's Avatar
Trader Rating: 14 (100%+)
hi bud i to have had the same problem dose your breaks work good for about 1-2 min of run?i have short mine when i was running stock
Vbc wildfire D06
clinton livingstone
P.I.M.P is offline   Reply With Quote
