Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree2Likes
Old 09-01-2011, 01:18 AM   #6091
Originally Posted by Mike-Xray View Post
hobbywing 211 or speedpassion that updated in may on their website?? i've got an xtreme stock hobbywing ESC!! where can i found the latest software for hobbwing? which are the best program running on 17.5t? sorry guys but i'm really new to eletric on road
211/213 are the latest version, use HW for HW and SP for SP do not mix them.
Electriquement votre...
Drink EARTH water and save lives! in support of WFP
olly986 is offline   Reply With Quote
Old 09-01-2011, 01:47 AM   #6092
I was under the impression you could mix firmware between the different ESC's with no problems.
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 09-01-2011, 03:53 AM   #6093
defcone's Avatar
Trader Rating: 15 (100%+)
Yes you can. Have had no problems whatsoever.
defcone is offline   Reply With Quote
Old 09-01-2011, 04:00 AM   #6094
So how do you go about updating the firmware on your ESC to another brand? I assume you just hook it up, load brand x software and go to firmware screen? Or is there a special trick to it?
Powered by Falco
Old 09-01-2011, 04:03 AM   #6095
I did not say you couldn't, but it is recommended by Angelo and HW not to use SP software and vice versa, which are not exactly the same, after you do whatever you want, it will work, but it is complicated enough to follow the software of one company, so two...
Old 09-01-2011, 04:05 AM   #6096
You need to load the sp link software etc..update your 2 in 1 box with SP and then your speedo with whichever program you want, then enter the values.
Old 09-01-2011, 04:10 AM   #6097
defcone's Avatar
If you want to load the sp software (323) and you have hobbywing(211), you have to go to an older software, say 205_MOD on the hobbywing. Then open the speed passion software and upgrade to 323. Simple really.
Old 09-01-2011, 04:24 AM   #6098
If the processor is the same it should work fine.
Has anyone tried this with the Orion software (onto SP ESC to be specific) yet?
Powered by Falco
Old 09-01-2011, 04:45 AM   #6099
defcone's Avatar
Yes I tried, it doesn't work.
Old 09-01-2011, 05:09 AM   #6100
Send a message via ICQ to vitomon Send a message via Skype™ to vitomon
i am now using sp 323 software on a spgt2pro. can i change settings with the hobbywing program box? or do i have to update anything.
Yokomo BD7 -- Hobbywing v3 -- Sanwa M11x
May the grip be with you ... always!
vitomon is offline   Reply With Quote
Old 09-01-2011, 05:13 AM   #6101
Sl I guess they have updated the hardware with the new hobbywing based stuff. Will it interface at all or just won't upgrade frmware?
Powered by Falco
Old 09-01-2011, 05:16 AM   #6102
defcone's Avatar
You can use a box with hw software
It recognizes it, the upgrade window is just greyed out.
Old 09-01-2011, 06:59 AM   #6103
ZZracing's Avatar
Send a message via Skype™ to ZZracing
GOOD! The drivers here are the products used HOBBY WING!
HOBBY WING products and services is very good! ! !
ZZracing Titanium screws /Hobby Wing /Savox /Nvaracing / Star racing/Novarossi/Sanwa/Castle/Xcore/Yeah Racing/Tianhao UFO/Q-World/Venom/Orion/Sky Rc
Email:zzracing@126.com zzracing@foxmail.com
www.rzhobby.com www.zzracing.net
ZZracing is offline   Reply With Quote
Old 09-02-2011, 01:55 AM   #6104
rc_square24's Avatar
Can the XERUN 120A run on 1S for 1/12th with booster? Does it allow for 1s lipo cut-off?
Thanks.
rc_square24 is offline   Reply With Quote
Old 09-02-2011, 03:26 AM   #6105
Jay_P's Avatar
I getting a bit lost on how different motors perform, has anyone have any suggestions on a good base setup and gear ratio for a mediun size outdoor track for the HW 21.5 in a TC
At the moment I'm running the Xtreeme Stock on 518 with the DRRS on 9, start at 3000rpm, boost at 21 deg, turbo max and ramp at 250 at a 5.1 ratio. Temps are around 70deg but its a lap and a half down on pace from the Graupner motor (RIP) I was using. Any help appreciated
Jay_P is offline   Reply With Quote
