Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree5Likes
Old 04-29-2010, 10:10 PM   #46
Send a message via MSN to hobbywing Send a message via Skype™ to hobbywing
Hello, Steliosh
Hobbywing engineers analyze the problem, and we guess the total timing is too big. If the "mechanical timing of the motor + ESC timing" is too big, it may cause problems for Sensored working mode. In such a case, the ESC will automatically change to sensorless working mode, that causes a slow speed.
please try to set a lower timing to ensure that ESC always work properly with sensored mode in the entire running time.
And the LED status can help you to know what happeded:
1) If the ESC changes to sensorless mode, both red LED and green LED will flash
2) If the ESC enters low voltage cutoff mode, only red LED flashes
3)If the ESC enters over-heat protection mode, only green LED flashes
we hope the above information is helpful. Have fun in the weekend!
hobbywing is offline   Reply With Quote
Old 04-29-2010, 10:57 PM   #47
razzor's Avatar
Originally Posted by hobbywing View Post
Hello, Steliosh
Thanks for that info.
Makes sense especially with guys trying to max out settings.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 04-29-2010, 11:39 PM   #48
Nemo racing's Avatar
Send a message via Yahoo to Nemo racing
Hi hobbywing
I try downloading the software but every time I try to open it
it will say file corrupt
Can you send me the file or can you post the link to the download site
Thank you
A800
Scorpion Power System
Nemo racing is offline   Reply With Quote
Old 04-29-2010, 11:47 PM   #49
COBRARACING's Avatar
Originally Posted by Nemo racing View Post
Hi hobbywing
Thank you
send me an email teamcobraracing@gmail.com
Email : teamcobraracing@gmail.com or ae@hobbywing.com
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Old 04-29-2010, 11:50 PM   #50
yes the software is a very big improvement but dont think that you can get blood out of a stone it wont happen im sure you know this .settings set to high will cause you problems settings depend on gearing and motor selection
Old 04-29-2010, 11:53 PM   #51
Thank you e-mail sended
A800
Old 04-30-2010, 01:19 AM   #52
steliosh's Avatar
Hello, Steliosh
Hello! Thanks a lot for your comments.
I wrote above my settings, which were exactly the starting points you give on the pdf.
Truth is I never thought to check for the leds, to see if they blink... hmmm...
On the other hand, maybe the Nosram has too much advance built in already.
I will do more running today with "softer" settings...
www.steliosh.net/rcmoto/
www.steliosh.net/rc/
KP-Designs KP10e 1/5 rc bike, Kyosho Lazer ZX-5, HPI Baja SS, Xray T1 FK05, Venom GPV1 1/8 rc bike, Anderson M5 Cross 1/5 rc bike, TT SB-5 1/5 rc bike
steliosh is offline   Reply With Quote
Old 04-30-2010, 05:17 AM   #53
eceer's Avatar
Hello, Steliosh
Thanks for this bit of advice. I lowered the timing and appears to have done the trick. Lets see how it goes on the track on Sunday
☞ Adelaide RC Team driver ☜
☞ Switchmedia ☜
☞ They're not toy cars, they are fine examples of engineering. When driven correctly are a joy to behold. ☜
eceer is offline   Reply With Quote
Old 04-30-2010, 07:15 AM   #54
Question regarding the new software...
a bunch of us in the Ohio area have experimented with the HW 1/18th scale ESC's - the:
EzRun-18A-SL Brushless ESC for 1/18 Car (Version 2) and
EZRUN-25A-L Brushless ESC for 1/18 Car (Version 2)
using 4 cell 4.8v and a 4200Kv motor. The ESC is great but both the Tekin Mini Rage and the Castle Micro Pro can push the timing past the 26.5 limitation of the HW. Will this software update affect the 1/18th ESC in sensor-less mode? Will the HW match the speed and performance of the Tekin and Castle 1/18th scale ESC's?
Thank you
Micro_Racer is offline   Reply With Quote
Old 04-30-2010, 02:32 PM   #55
I tested the new Beta today,
I switched back to 10.5 for a few runs before going back to Mod for the BRCA Nationals.
It is a HUGE Improvement!!! And now puts the ESC on a Par with the other fast makes.
Temperatures were very good aswell at around 80 degrees C
Well done guys
Stef - SP Uk
Stefan-Hpi Uk is offline   Reply With Quote
Old 04-30-2010, 10:03 PM   #56
snowman_evil's Avatar
Trader Rating: 30 (100%+)
Send a message via MSN to snowman_evil
What settings can you change with the LCD programming card? Is it just basics or can you change advanced settings such as timing, drag brake, etc...?
DEX410V3 - Tekin - Spektrum - Panther
GCRC Raceway - "Lightning"
snowman_evil is offline   Reply With Quote
Old 04-30-2010, 10:50 PM   #57
RL.2002's Avatar
The lcd program card can do both of the change which is the basic n advance setting
the passion of the slide when taking the corner....
http://www.penabai-rcdrifter.blogspot.com/
Kyosho TF-5 drift spec powered by Ezrun 35A + 9t
Tamiya TRF-416X, Tamiya TRF-417
Hobbywing Xerun 120A, Xerun 3.5t, Team Orion 11.5t, Xerun 5.5t
RL.2002 is offline   Reply With Quote
Old 04-30-2010, 10:58 PM   #58
ali_g's Avatar
can i use the 2in1 Programme box to set the turbo setting?
☆ JU.C RACING ☆
https://www.facebook.com/Ju.Cracing
ali_g is offline   Reply With Quote
Old 05-01-2010, 01:05 AM   #59
AGNO's Avatar
Yes, after the upgrade is possible
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Old 05-01-2010, 10:35 AM   #60
Send a message via MSN to Bigger Brother
Well done guys
Stef - SP Uk
Stef - what settings were you using (with 10.5)? I'm off to Brooklands next week for STCC (eek!) in 13.5 so would be really handy to have some sort of useful starting point. Any info you can give would be really handy.
Many thanks
Oli
Oli Meggitt | London, UK
.:. Essex Winter Series .:. CML Racing .:. ToniSport .:. Zen Racing .:. Moorespeed RC .:. OTM Racing .:. RC Racing TV .:. RIDE R/C Scoreboards
Bigger Brother is offline   Reply With Quote
