Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree5Likes
Old 08-22-2011, 11:07 PM   #5971
JAM Racing's Avatar
Originally Posted by dameetz View Post
I m posting this on behalf of a friend of mine coz nothing that we do seems to solve the problem.
My friend has been using Hobbywing Xtreme Stock combo with Hobbywing 11.5T motor for the past 2 weeks which include 1 race day. For the past 4 days he's having problem with the esc somehow loosing the turbo function, its more like its switching to sensorless mode by it self. First 2-3 laps it was fine, after that the car was just crawling, then all of the sudden the Turbo is there again. This happened on and off during 5 mins drive. The ESC and Motor's temp was normal (esc 40C ish and motor 60C ish).
What have we done so far to solve the problem:
1. Change the sensor wire (a few time already which include a new one)
2. Calibrate the throttle (set to 100% during calibrating then bump it up to full 140% EPA)
3. Reflash the 518 stock firmware (twice now)
BUT the problem is still there Anyone got any more idea on what to do?
Check lipo cutout first
Walters Hobbies for all your racing needs
Serpent 411/ERYX
ORCA BATTERIES
Castle Hill Raceway
The Best in the West
JAM Racing is offline   Reply With Quote
Old 08-22-2011, 11:09 PM   #5972
JAM Racing's Avatar
Default HELP
just killed a 60 amp
Lights up ok but msfet is stuck open
can you buy the mosfet board seperately
Serpent 411/ERYX
ORCA BATTERIES
Castle Hill Raceway
Old 08-23-2011, 12:12 AM   #5973
Johnny-RC's Avatar
Trader Rating: 24 (100%+)
See the new Pro SCT esc hereon Cobra's Facebook page.
https://www.facebook.com/media/set/?...0000596&type=1
Angelo when is your web site going to be back up?
Products I run
| Hobbywing | Gens Ace | Highest Servos | Sanwa | Team Associated | AKA |
Johnny-RC is offline   Reply With Quote
Old 08-23-2011, 01:28 AM   #5974
COBRARACING's Avatar
No you can't buy the mosfet circuit board on its own you need to send it in for repair to hobbywing .
Email : teamcobraracing@gmail.com or ae@hobbywing.com
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Old 08-23-2011, 01:31 AM   #5975
Try a different battery also drop your lipo cutoff to 3.0v
Old 08-23-2011, 01:32 AM   #5976
johnny hopefully soon it will be up and running
Old 08-23-2011, 12:14 PM   #5977
Originally Posted by TryHard View Post
Scoop,
You got Pm... let me know if it helps
Regards
Ed
OMFG i appear to have done it! Many, many thanks
More questions if you dont mind. When they talk about 224 does that replace 211 for the supercharged programme ie the way it adds timing etc or 119 as in the firmware?
Cheers, Steve.
scoop is offline   Reply With Quote
Old 08-23-2011, 03:51 PM   #5978
Cheers, Steve.
It depends on what you are talking about steve, there is 224 as a usb link and 224 as speedo software.
Well to finish my 224 saga, I tried to pass the software (which is good and full) from XP to Window7, and as expected, the 224 speedo version is AWOL !!
So loaded from XP and changing values with 2.1 box.
Steve to get back to you, the reason I wanted 224 speedo, is to run my LRP cooler which is apparently better than 211 ( which is the latest version so far with 213 which is apparently very similar)
If you need to load 224, you will have to do as explain above by M7H, after all this, you will be a HW/computer wizard
Electriquement votre...
Drink EARTH water and save lives! in support of WFP
olly986 is offline   Reply With Quote
Old 08-24-2011, 02:02 AM   #5979
Default Hobbywing XERUN 120A 1S
Hi,
this year we will have rule that will allow use of 1S LiPo with 10.5T motors (until now only 2S with 17.5T).
Maybe someone have experience with XERUN 120A 1S in WGT on 1S LiPo and can share some? Settings, firmware, what motor, ect...
Thank you!
Audrius
www.rc-cars.lt - offroad in Lithuania
www.lasa.lt - onroad in Lithuania
audriusv is offline   Reply With Quote
Old 08-24-2011, 02:06 AM   #5980
M7H
M7H's Avatar
Cheers, Steve.
When people talk about 224, 211, 119
They actually talk about:
224 => 101224
211 => 110211
119 => 110119
The full number you see is the date stamp.
ESC firmware 101224 is from 24 December 2010
Actually it is V3.0_101224_STOCK, the version 3 firmware, ment for stock racing, so with more timing settings possible.
The USB computer package V1.63_110310, is put online on 10 March 2011, and contains ALL officially released ESC firmwares Hobbywing ever put on the market, for ALL updatable ESC's they have. Depending on what ESC you connect, the software will give you those firmwares available for the that particular ESC.
I hope you understand now.
Serpent
M7H is offline   Reply With Quote
Old 08-24-2011, 03:18 AM   #5981
Default HW 120a v2.1 & x12 13.5 motor
Hi
can anyone help with a good fast setup for this please as i am about to ditch the speedo and go back to a GM as the GM is much quicker on its default settings. I prefer the HW as it is so smooth and no need for laptop to program it.
i have also tried HW, GM & novak ballistic motors.
I race at Aldershot which has a straight approx 45m long (feels like 70m to me)
cheers
mcdoogle is offline   Reply With Quote
Old 08-24-2011, 04:11 AM   #5982
M7H
M7H's Avatar
Originally Posted by mcdoogle View Post
Hi
cheers
Please read the last 2 or 3 pages....
Serpent
Old 08-24-2011, 04:35 AM   #5983
NTS
Default X12 13.5 FDR?
Hi
cheers
I'm also after a good setup for the X12 13.5 but for an indoor carpet track (30m x 15m) in 1/10th touring.
I have read the previous posts and see that 224 with low boost and turbo is worth trying but it is not clear to me what sort of FDR I should be expecting to use? Sorry I'm not sufficiently up to speed with 12th rollout to understand if I should be gearing low and using the motor torque or high and letting it rev? Any thoughts 6.5? 7.2? 8? would be great.
Nick
NTS is offline   Reply With Quote
Old 08-24-2011, 05:46 AM   #5984
M7H
M7H's Avatar
Check this thread:
Hobbywing ESC Settings ONLY
Serpent
Old 08-24-2011, 06:14 AM   #5985
J SiN's Avatar
I will be getting a Xtremestock to run a 21.5t motor I hope to get a SP MMM or a Team Powers motor. What I want to know is will the stock program be ok to use or should I pick up a programe box aswell?
Thanks for the help in advance.
T.O.P. Racing Australia
R.A.B Hobbies
AVID Bearings
J SiN is offline   Reply With Quote
