Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Like Tree5Likes
Old 08-21-2011, 07:45 AM   #5926
EUREKA !!
Well for others that might have the same problems, after looking around this is what I did.
Loaded "old" Speed passion 1.02 version from SP site, loaded 1.02 instead of 617 (twice to be done and after a couple of tries) then open HW usb link, loaded version 1.07 110119 impossible to load 101224, well it is possible to load it on pro box but then it ask to update software when plugged into speedo, so far no luck to load it on, so I am back to 110211 which is fine as I race 10.5t.
one thing, you need to upgrade twice every version, it even stopped half way (error in communication) everytime I try to upgrade, just do it again.
Maybe someone can explain why the incompatibility to upgrade from 110119 to 101224 ?
At least now my program box says Hobbywing rather than Speed Passion and everything is back to normal.
Electriquement votre...
Drink EARTH water and save lives! in support of WFP
olly986 is offline   Reply With Quote
Old 08-21-2011, 07:51 AM   #5927
Originally Posted by Vrooom View Post
Hi, i been running this ESC for 2 weeks on my xray T2 touring car, i got mixed feeling about this esc. :/ but im happy with performace.
sometimes turbo wouldnt kick in, sometimes it does, and it sometimes cut out. (no power to car, fan stopped)
and it has been pushing my lipo battery to 2.8v cut off point where it should stopped at 3.2v
It has latest firmware on it 110211.
If the esc isnt turboing, is that due to low battery voltage or what?
Hi
Give us your full setup, you probably have a setting that is wrong, and what motor are you using?
Old 08-21-2011, 08:25 AM   #5928
My setup are :-
Xray T2 009
Hobby wing xtreme stock ESC with HobbyWing 17.5T motor senored
Vapextech 30C 2s 7.4v 36.5Wh 5000mah Lipo
on 27mhz reciever / tx ( will upgrading soon)
ESC:-
Hardware version: HW427_V1.0
Software version: V3.0_110119STOCK
Program box:-
Hardware version: HW310 V1.0
Software version:V1.07_110119
Esc setting is:-
Running mode: forward only with brake(*)
Drag brake force: 0%
low voltage cut off: 3.2%
"DDRS" start mode: Level 9
maximum brake force: 50%(*)
Maximum reserve force: 25%
inital brake force : 0%
netural range: 12% wide
Boost timing: 46 degrees
Turbo open time: 18%/0.1 sec
Overheat protection: enable
Turbo timing: 0 deg
Boost start RPM: 4000
Turbo open delay: 0.3 sec
Boost timing ACC: 350 rpm/deg
Vrooom is offline   Reply With Quote
Old 08-21-2011, 08:40 AM   #5929
My setup are :-
Xray T2 009
ESC:-
Program box:-
Esc setting is:-
Turbo timing: 0 deg
Well you have 0 turbo timing
try to put 15-20 turbo timing
reduce turbo time a little 12% and DDRS to 6
the rest is about right depending on your track and you could probably update speedo to version 211.
Old 08-21-2011, 08:47 AM   #5930
Thanks for suggestion, i just upgraded the fw to 211, and changed the setting.
The track is around 20m straight with very fast right hander, layout alway changes but straight stays same.
Do esc dont go into turbo mode when battery get low ?
I came first in final without boost :P
Old 08-21-2011, 08:54 AM   #5931
roger999's Avatar
Looking for starting settings for 10.5 motor, medium size carpet track with medium grip. software would be stock 211. Or mayby use standard settings when i load software?
r o g e r g r a f i x . c o m
facebook.com/rogergrafix
roger999 is offline   Reply With Quote
Old 08-21-2011, 09:53 AM   #5932
Would try to read 10 pages back.....
My advice would be:
Boost 40
Turbo 30
acc 150
delay 0.1
start rpm 1000
doesn`t matter which fdr...
rbakker is offline   Reply With Quote
Old 08-21-2011, 10:01 AM   #5933
twalace's Avatar
Questions??
Have one of these 60a with a 17.5T motor in my sons B4 buggy, ran fine for awhile and now runs at about half speed, any ideas???
Losi 22 / Novak SS 17.5 / Novak Havoc / FlySky FS-GT3B
Associated B4.1 / Bullistrom 17.5 / FlySky FS-GT2
twalace is offline   Reply With Quote
Old 08-21-2011, 10:10 AM   #5934
Try to charge the battery
Old 08-21-2011, 02:11 PM   #5935
All so check the censor cable.Make sure the plugs are in correctly or try an other cable.I also had this problem my fdr was to high changed this and happy days.
big paul is offline   Reply With Quote
Old 08-21-2011, 02:25 PM   #5936
My advice would be:
Boost 40
Turbo 30
acc 150
delay 0.1
start rpm 1000
Boost and turbo = 70, max is 64 I thought...
this sounds like your motor will get hot with this setup, especially if you run LRP X12 10.5t.
the best is to try this and check your temp after 2 minutes.
FDR should be around 7/8 and run 211
Old 08-21-2011, 02:27 PM   #5937
Default Cant upgrade!!!
Just loaded the disc from my 2 in 1 box and restarted the laptop. When i go on the link it says its found updates so i click to upload them but all it does is tell me that it failed. Over and over again!
Help me please. I want to get 119 mod on my 60amp 8.5 ezrun.
scoop is offline   Reply With Quote
Old 08-21-2011, 02:33 PM   #5938
Hi Scoop
Did you read my post above?
I had problem to load software, make sure that you choose again 119 from the list when you try to load the second time, as it might not give you that choice automatically.
Mod on a 60A, make sure you have everything well setup...
What is the version of link you have on compy?
Old 08-21-2011, 02:52 PM   #5939
Im a total computer numpty. Ive just followed what ever came up on the screen. It says i have 119 firmware but the only software option is 512 and it wont let you load 512 when 119 is the firmware!
Im lost
Old 08-21-2011, 03:10 PM   #5940
Im lost
I know I found all these software versions a bit of a nightmare to sort out.
Remove the software you loaded with disc first.
Go to HW site and download link usb V 1.63, then you should have 3 versions on, 119, 224,512.
upgrade to 119 if this is the one you want.
Do all this and get back to me.
