Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 08-19-2011, 04:07 AM   #5911
mutley001's Avatar
Originally Posted by scoop View Post
If you went with Rens settings there is no timing left to add as you can only go to 64 degrees total timing. You then have to play with settings 10, 13, 14 and 15.
Why only 64? And does that go for any motor timing that may be added too?
Paul
ARC R11 2017
ARC R10 2013
EA Motorsports www.teameamotorsports.com
Team EAM
mutley001 is offline   Reply With Quote
Old 08-19-2011, 04:15 AM   #5912
slammedwagon's Avatar
hey guys,
im from nz. i have a fleta 3.0 and have just downloaded the hobbywing software into it.
and some please help me with what program i should be running on the lcd program box and esc.
what i have so far is;
on the lcd box - hardware version: HW310 v1.0
software version: V1.07_110119
on the esc - harware version: HW427_V1.0
software version: V3.0_110211STOCK
thank you guys very much
Karl
slammedwagon is offline   Reply With Quote
Old 08-19-2011, 05:27 AM   #5913
Paul
Thats how its designed. It does say on the paperwork you get with it. Motor timing is additional. Increase the slope and reduce the revs the timing is added at for a start. I ca'nt imagine you need any more on a 30 meter straight
scoop is offline   Reply With Quote
Old 08-19-2011, 05:52 AM   #5914
venom54's Avatar
Default 10.5 and 13.5
Settings worked a treat. Cheers guys
Motor was coming off at 50 degrees with plenty of punch and good top end. Went with an FDR of 7.6. Might add a tad timing to the motor next time out.
Thanks again
Paul
Really happy to hear the results have been good. Well done.
The only options left to play with for top end speed is as noted previously 10,13,14 and 15. A play with these in small increments will help in setting for particular tracks and help in controlling temps. FDR will also help. Increasing motor timing depending on motors does not always help. The TP motor i used fell flat when i increased timing so i left it at 0 degree.
Cheers
Ren
Play hard but be nice to your parents!
VBC RACING|ASSOCIATED|XRAY|TEAM POWERS|THUNDER TIGER|HOBBYWING|HPI|WTF FANS|ORION AND MORE IN STORE.
145 COMO PARADE EAST 3195 PARKDALE VICTORIA AUSTRALIA.
www.rabhobbies.com.au
venom54 is offline   Reply With Quote
Old 08-19-2011, 10:52 AM   #5915
mutley001's Avatar
Thanks again Ren adb Scoop
Playing with 10, 13, 14 and 15 it is then! I'll let you know how I get on after practice on Tuesday next week
Paul
ARC R11 2017
ARC R10 2013
Team EAM
Old 08-19-2011, 09:54 PM   #5916
Default same for me
Originally Posted by slammedwagon View Post
hey guys,
Karl
I got the same issues - although I havent turned the car on for 5 months I could swear the last time I updated the esc the readouts allowed me to update to the 211 which is what I have
Ps what is the latest fw now?
Pss i have the Xtreme Esc with an SP LCD card
emerge is offline   Reply With Quote
Old 08-20-2011, 05:50 AM   #5917
TryHard's Avatar
That combination is the latest firmware for the LCD and ESC.
119 on the LCD, 211 for the ESC.
On another point, lower on the DDRS is working well for me at the moment. I've been playing a lot with this recently, both with 11.5 and 4.5's, keep going lower and getting smoother throttle and lower temps, and no slower... win win
HiH
Ed
Old 08-20-2011, 03:49 PM   #5918
Will somebody post a good setup for a 10.5 on a TC3 sedan using 211 stock for a medium to large track...
raypa is offline   Reply With Quote
Old 08-20-2011, 04:07 PM   #5919
what make of motor?
Electriquement votre...
Drink EARTH water and save lives! in support of WFP
olly986 is offline   Reply With Quote
Old 08-20-2011, 09:49 PM   #5920
HiH
Ed
thanks for that guys.i went out racing today and boy i had to turn the punch down alot lol and also lowered the ddrs. i am using it on off road and managed to get up into 3rd for the day
Old 08-21-2011, 04:36 AM   #5921
XSLR8's Avatar
Cool
Paul
Add 2 notches of timing on the d3 and temp it with RENs settings and watch it fly......
VBC Racing Australia.....FUTABA AUSTRALIA.....Volante tires.....WTF Fans.....R.A.B Hobbies....President www.serccc.com.au
XSLR8 is offline   Reply With Quote
Old 08-21-2011, 05:56 AM   #5922
Forget to ad is a Hobbywing 10.5 with a 60a v2 ESC
Old 08-21-2011, 06:43 AM   #5923
Funny enough, I have picked lots of different setups for HW with 10.5t, 11.5t, 13.5t motors and none are with the Hobbywing motors...
Anyone with a good 10.5t HW motor setup out there??
Old 08-21-2011, 06:58 AM   #5924
So I am starting to understand all the setups and different program options, but I came to a problem.
I bought my HW Xerun and program box second hand (Hobbywing 2 in 1 pro program box) but apparently with a Speed Passion version on V1.06_100617
Have choices:
V1.07 110119
V1.07 101224
V1.06 100512
Hardware version is: HW310 V1.0
but won't upgrade to any of these from V1.06_100617 (SP version?).
Computer usb link is: V1.63
Speedo version is:
Hardware version: HW427_V1.0
Software version: V3.0_110211stock
Choice options:
V3.0_110119 mod
V2.0_100528 mod
V1.10 090205 mod
V1_508 no timing
3 more stocks: 119,108,518
and V1.10 090323 a_m
When I connect program box to ESC only it will show SP version and when pressing any buttons it is looking for a software update and would not work, but it did work before when I installed the speedo in car last week.
I did upgrade to version 211 on ESC since from 119.
So here are my questions:
1) how can I remove the Speed Passion version altogether and replace with HW version, I was trying to get V 224 as I am using a LRP X12 and following some of the previous threads it seems to run cooler with this version, but no luck won't let me do it.
2) what upgrade is the pro box looking for?
Thanks for your replies.
Old 08-21-2011, 08:16 AM   #5925
Hi, i been running this ESC for 2 weeks on my xray T2 touring car, i got mixed feeling about this esc. :/ but im happy with performace.
sometimes turbo wouldnt kick in, sometimes it does, and it sometimes cut out. (no power to car, fan stopped)
and it has been pushing my lipo battery to 2.8v cut off point where it should stopped at 3.2v
It has latest firmware on it 110211.
If the esc isnt turboing, is that due to low battery voltage or what?
Vrooom is offline   Reply With Quote
